simcam68 Posted February 17, 2012 Report Share Posted February 17, 2012 Finally did the upgrade last night... Worked like a charm. When from 1.000 on a Z110 to the 3.000 no problems at all. Thanks to all, expecially Shortfuse! Best $11 i've ever spent! Now to get the unit into the car again... been sitting on the shelf since Feb 2010 when my old car got bent in half by the stupid old woman in the mercedes that thought crusing throught the stop sign at 35mph into the door of my car was a good idea. B1tch... Quote Link to post Share on other sites
RonS Posted February 17, 2012 Report Share Posted February 17, 2012 She was probably watching a DVD on her bypassed Z130 Quote Link to post Share on other sites
olmyt Posted February 17, 2012 Report Share Posted February 17, 2012 I was unable to get the US torrent (CNSD-210FM) to start downloading, it just says error. Where can I get the file? Thanks!!! O Quote Link to post Share on other sites
wayeasy308 Posted February 24, 2012 Report Share Posted February 24, 2012 First off I would like to thank everyone that has contibuted to this topic. I have a Z120 and am running the update from Pioneer last August, 2.003 i belive. (Unit is at home and I am at work) I want to install the US CNSD-210FM this weekend and have downloaded it and the 2.004 hacked files. I have been reading all the posts here and am still not clear if I am correct on how to upgrade my Z120. Is it as simple as replacing the two files in SD1 with the files in 2.004 then installing SD1 then SD2 as I allready am updated to 2.003? Or do I have to start with AVICZ110BT? Quote Link to post Share on other sites
RonS Posted February 24, 2012 Report Share Posted February 24, 2012 Is it as simple as replacing the two files in SD1 with the files in 2.004 then installing SD1 then SD2 as I allready am updated to 2.003? Or do I have to start with AVICZ110BT? No, that's not even close. You need to download 2.003 from pioneer. Follow their instructions on creating an SD, except replace the two files with the ones from your 2.004 hack. Then insert the SD and let it update (for all of these updates, make sure your battery is charged and that you don't loose power). After you have 2.004 installed, then insert CNSD-210FM SD1 and let it install. Enter "PASSWORDPASSWORD". After rebooting, insert SD2, then go to your settings/Bluetooth Settings and scroll down to the firmware update selection. Press it and follow the prompts/messages. Quote Link to post Share on other sites
wayeasy308 Posted February 24, 2012 Report Share Posted February 24, 2012 Thanks RonS! I really appreciate your help on making this clear and simple. I read every post and couldn't find anything stating how to start from already having 2.003 installed so i wasn't 100% sure. I will give it a go tomorrow and post how it went. Quote Link to post Share on other sites
wayeasy308 Posted February 28, 2012 Report Share Posted February 28, 2012 Well I did the update on the weekend and all went well. Only took about 40 Min. total. Thanks again to RonS for making this a simple upgrade. Quote Link to post Share on other sites
hanokgeorge Posted April 12, 2012 Report Share Posted April 12, 2012 In case anyone was interested, here is the manual released with the CNSD-210FM upgrade: http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/CNSD-210FM_UpgradeInstructions.pdf Quote Link to post Share on other sites
hanokgeorge Posted April 12, 2012 Report Share Posted April 12, 2012 Thank you everyone who donated and made this happen. It works perfectly! Quote Link to post Share on other sites
94b20gsr Posted April 26, 2012 Report Share Posted April 26, 2012 Just wanted to say thank you to everybody that made this possible! Everything is working correctly for me. Quote Link to post Share on other sites
hateplow Posted May 6, 2012 Report Share Posted May 6, 2012 ive made 3 sd cards.. one with the shortfuse and then i have the sd1 and sd2. but its not working.. i mean i put the card in and nothing happens.. cept some chinese or something talking and high pitch sound.. i have no clue what im doing wrong. or what i doing right at this point. Quote Link to post Share on other sites
RonS Posted May 6, 2012 Report Share Posted May 6, 2012 ive made 3 sd cards.. one with the shortfuse and then i have the sd1 and sd2. but its not working.. i mean i put the card in and nothing happens.. cept some chinese or something talking and high pitch sound.. i have no clue what im doing wrong. or what i doing right at this point. Put SD1 back into your PC, using Explorer - open the drive of your SD1. What files/folders do you see? If the HU doesn't find the upgrade files in the right place, it assumes it is a media disk and it scans the SD for playable media files - and plays them. Quote Link to post Share on other sites
hateplow Posted May 6, 2012 Report Share Posted May 6, 2012 SD1 Firmware Update caredinfo.cfi Quote Link to post Share on other sites
RonS Posted May 6, 2012 Report Share Posted May 6, 2012 SD1 Firmware Update caredinfo.cfi Are you saying you have a folder in the root of your SD called SD1? BTW, what is your current installed version number? Did the Shortfuse hack install OK? Check the version number of your current software by completing the following steps: Press the “HOME†key Select the “Settings†tab Select “System Settings†Select “Service Information†Press & hold left upper corner of the “Service Information†screen for a few seconds What is the Application Version that is displayed? Quote Link to post Share on other sites
hateplow Posted May 7, 2012 Report Share Posted May 7, 2012 nothing worked.. none of the sd cards i made. appver 1.000 platform 1.001 bt fm 2.50 Quote Link to post Share on other sites
