420Coupe Posted September 6, 2011 Report Share Posted September 6, 2011 I had a question in all the videos and pictures i've seen for the brake bypass every one has a white AV harness, mine is black and does not have any extra room to be able to move a 'mute' wire over which it does not have only 1 yellow wire which is the power source. My question is, is this a different version of the Avic Z120BT it says it was manufactured Nov 2010 on the sticker on it. This is a black av harness that has a little tab to hold the fuse above it in place as shown circled in the picture below. is there supposed to be something connected to the AV in/out. i have not got to use it extensively and check to see if it was bypassed while driving as i turned it in to the shop for engine work. Quote Link to post Share on other sites
JasonH Posted September 6, 2011 Report Share Posted September 6, 2011 Yes, you need the RCA harness that plugs into the white connection. Quote Link to post Share on other sites
420Coupe Posted September 6, 2011 Author Report Share Posted September 6, 2011 Yes, you need the RCA harness that plugs into the white connection. thank you. Although question would i connect these to the front speakers as well as they are already producing sound, or only for when i install aftermarket speakers ? Quote Link to post Share on other sites
JasonH Posted September 6, 2011 Report Share Posted September 6, 2011 The RCA harness is for additional/aftermarket speakers/subs/amps. Quote Link to post Share on other sites
Shane H Posted September 13, 2011 Report Share Posted September 13, 2011 Wouldn't this be easier? http://avic411.com/index.php?/topic/22920-avic-z110btz120bt-bypass-instructions/ Quote Link to post Share on other sites
420Coupe Posted September 14, 2011 Author Report Share Posted September 14, 2011 Wouldn't this be easier? http://avic411.com/i...s-instructions/ that in no way answered anything of what i needed. Thanks for the useful input. as i was MISSING this harness. Quote Link to post Share on other sites
grendel Posted October 22, 2011 Report Share Posted October 22, 2011 Any ideas where to get an extra harness plug? I want to revamp my harness. Quote Link to post Share on other sites
RonS Posted October 22, 2011 Report Share Posted October 22, 2011 Are you wanting just the connector or the whole harness. Probably impossible to just get the plastic/nylon housing - and I doublt you'd save much. You can find the harnesses on ebay. Get the part number from the Installation manual or just search by model no. You can probably sell the extra wires removed from the harness for people doing the bypass. Quote Link to post Share on other sites
grendel Posted October 22, 2011 Report Share Posted October 22, 2011 Are you wanting just the connector or the whole harness. Probably impossible to just get the plastic/nylon housing - and I doublt you'd save much. You can find the harnesses on ebay. Get the part number from the Installation manual or just search by model no. You can probably sell the extra wires removed from the harness for people doing the bypass. Yeah, just the plug would be perfect, since I am removing 3/4 of the harness to clean up behind my AVIC. Quote Link to post Share on other sites
rrolff Posted November 2, 2011 Report Share Posted November 2, 2011 Yeah, just the plug would be perfect, since I am removing 3/4 of the harness to clean up behind my AVIC. There's a guy selling harnesses on EBay for $40. take it to a local stereo shop, and they'll move the pin for a few $$ Quote Link to post Share on other sites
