JohnSCS Posted May 21, 2016 Report Share Posted May 21, 2016 Thank you. Just unlocked my F930BT. Link to post Share on other sites
GreyMatter Posted May 21, 2016 Report Share Posted May 21, 2016 i just tried this with my 930bt and its telling me my micro SD card isnt compatible for the headunit. i bought my truck with this head unit, and liked my other pioneer better so i swapped into the truck im selling, but its asking me for the password any ideas? Link to post Share on other sites
lmb1510 Posted May 22, 2016 Report Share Posted May 22, 2016 Huge thanks to IAmSuperBleeder for the detailed instructions. Bought a second hand Seat Exeo a couple of months ago and I've just had to remove the battery to unblock the bulkhead drains. The previous owner couldn't remember what he'd set as the password and you've just saved me a fortune as I would have had to remove the factory fitted 930BT from the car and send it to Pioneer. Once again. many, many thanks. Link to post Share on other sites
lmb1510 Posted May 22, 2016 Report Share Posted May 22, 2016 i just tried this with my 930bt and its telling me my micro SD card isnt compatible for the headunit. i bought my truck with this head unit, and liked my other pioneer better so i swapped into the truck im selling, but its asking me for the password any ideas? Try using a small capacity micro SD card (around 4 - 16GB) and make sure it's formatted to "MS-DOS (FAT)", It's just worked perfectly for me. Link to post Share on other sites
pyrojarjar Posted May 24, 2016 Report Share Posted May 24, 2016 Hey thanks for this thread. Special thanks to IAMSUPERBLEEDER for the step by step. Thanks again. Link to post Share on other sites
tjh7455 Posted May 27, 2016 Report Share Posted May 27, 2016 Thank you for this recovery procedure 3 minutes start to finish ,had a harder time finding a micro sd card than doing the hack. thanks again Link to post Share on other sites
snpmzcla213 Posted June 9, 2016 Report Share Posted June 9, 2016 I need the password for "HACKMODE.KEY". I thought it was avic411 but it's definitely not that. Can someone please point me in the right direction? I have the pioneer avic-x930bt Link to post Share on other sites
3scobar Posted June 9, 2016 Report Share Posted June 9, 2016 Hey new here is this the right test mode key for a avic f900bt...because im.having trouble getting it to boot on test mode thanks in advace..if is not can someone point me to the right direction thanks again.. Link to post Share on other sites
chalkcarxb Posted June 24, 2016 Report Share Posted June 24, 2016 Hi there!!! Directions worked perfectly! I got the password, but it won't work. any tips? Okay, let's simplify this a little more; might help some others. Pictures have always helped me out in situations like this, so let's do this.Working with an X930BT in this how-to. Read all of these instructions all the way through before attempting it.First off, you'll need a micro SD card; size isn't extremely important, the size of the files you'll be putting on it are less than 14mb, just choose one that your unit can support if it has a size limitation. In this instance I used a 32gb the first time around, but I'll be using a 16gb in the photos below; again, it really doesn't matter as long as it's at least 14mb, and I think the smallest you can get is 2gb now anyway and they're only like $5, lol.Next, you'll need to download the files required to booth the unit into testmode. In the original post there's a link to another thread which has about 5 different download links in it, and I know that can get confusing... The one you want is the HACKMODE v1.4 BASE. Click on that link and you will download the .zip file containing the files you need. Once the download is complete, unzip the contents onto your micro SD card.The .zip file is password protected and when you go to extract the files it will prompt you for the password. The password is "avic411" (without the "" obviously...)The files should be place in the root of the card, not in another folder on the card. I'm not sure if it's required (although it probably is) but have nothing else on the card at the time. The only thing that should be on the micro SD card are the files located in the .zip that you downloaded.At this point, it's time to make your way to the password protected unit with the micro SD card you just place the files above into.With the unit powered off (key in the OFF possession, or just no power supplied if your doing this out of the vehicle), load the card into the device. Power the unit on and wait for it to boot, at which point it should boot into testmode.Once in testmode, on an X930BT, and I would imagine it would be the same for all of the X9X0BT series, the only buttons and actions that will be needed to navigate the screens are the following:*HOME - escape/cancel/go back*MODE - enter/select*Volume down (left) - move selection on screen down*Volume up (right) - move selection on screen upI CANNOT STRESS HOW STRONGLY I RECOMMEND THAT YOU DO NOT MESS WITH ANY OTHER FILES IN HERE IF YOU DO NOT KNOW WHAT YOU ARE DOING!!! IT IS VERY EASY TO BRICK YOUR UNIT USING TEST MODE!!! I TAKE NO RESPONSIBILITY IF YOU SCREW THINGS UP; YOU ARE DOING THIS AT YOUR OWN RISK!!!Move the selection on the screen down to #11, File MaintencePress MODE and you will enter the File Maintence screenNow select User and open itNow select System and enter itNow go to security and enter itThe only thing on the screen at this point is Password, so enter itThere is only option on this screen that you you are concerned with here, a text dump. You do not have to move the selection around, just press MODE to perform the text dump, and VIOLA, the password that the unit is locked with is displayed near the top left of the screen!(I've blurred my password out here for obvious reason)Write this password down (unless is something you can remember), then just back out of all the menus using the HOME key until you get the the first screen, at which point you can power the unit off and remove the SD card. With the card removed, power the unit back up and enter your recovered password when prompted, and enjoy If you're not going to remember the password you just recovered, I'd suggest changing it. Take a look in the owners manual for those instructions.Hope that helps everyone a little more!by the way, I think this thread should become a sticky... Link to post Share on other sites
machighlander Posted June 24, 2016 Report Share Posted June 24, 2016 When i try to do this it does not go into the test screen, it asks if i want to enter hackmode, which i do, but from there i can see nothing to indicate what i am meant to do now. what am i doing wrong? Link to post Share on other sites
BlakeStone Posted June 24, 2016 Report Share Posted June 24, 2016 It's because your not supposed to use hackmode. It's a dangerous tool that has bricked many users units. You only need testmode. It's still dangerous if you push the wrong buttons, but not an automatic thing like hackmode is. Then just delete the file password.dat and you won't need to figure out if there are spaces at the end of the password or something like that. Link to post Share on other sites
akaRhino Posted June 25, 2016 Report Share Posted June 25, 2016 Would you have any idea on how to recover the password on an AVH-X8650BT? I had to change the battery in my car and now I have the problem of being locked out of my device by a password that I do not remeber setting. Link to post Share on other sites
BlakeStone Posted June 25, 2016 Report Share Posted June 25, 2016 I'm sure it's the same process for your unit. You just need to find a testmode.key that works with it. The one I linked works on a lot of units, but I'm guessing not yours. Link to post Share on other sites
PSD462 Posted June 30, 2016 Report Share Posted June 30, 2016 A Big Hats Off to IamSuperBleeder. My company purchased a used Ambulance from a Local Fire Company and we converted it to a Service Truck, The Ambulance has the X930BT Head and we replaced the Battery for the truck not knowing to keep the radio powered nor did we know it had a password so when we installed the new battery...wham...Password needed and we didn't have it. Used the Hack and retrieved the password. Radio is Back working. Thanks Guys. Link to post Share on other sites
Brandon_2000GT Posted June 30, 2016 Report Share Posted June 30, 2016 Anyone have an issue with it not accepting the sd card? Is it a specific card I need to use or will any micro sd work Link to post Share on other sites
