H3blue Posted January 25, 2007 Report Share Posted January 25, 2007 probably go with what you know and what has been told to you to do would work best Sorry if my post confused you. I think what tillithz is trying to say with this (and other) cryptic post is go back to his(?) original post that said turn on the A/V input. Not the AUX input. Same thing I said, but I think I gave a bit too much information. Quote Link to post Share on other sites
Dubbedown Posted January 25, 2007 Author Report Share Posted January 25, 2007 probably go with what you know and what has been told to you to do would work best thanks, will do! btw, love your sig. i think the newest sti is by far the best looking one. i'm not sure if you have any performance mods, but stock with just good audio/radar setup is pretty nice too. only have the rx65 but does the laser blocking really work??? Quote Link to post Share on other sites
tillithz Posted January 25, 2007 Report Share Posted January 25, 2007 ty ty, havent had a chance to 'test' the blocking, but by all reports it should. ironically i wont be driving as much as i use to, so i wont even be needing the rx75. ahh well, you live and learn Quote Link to post Share on other sites
Dubbedown Posted January 26, 2007 Author Report Share Posted January 26, 2007 ok, so here's my update. pull the hu out and i see 3 sets of rca plugs. with aux "enabled", i try the first set of plugs which has a sticker around the wire "audio inputs." turn on mp3 player, nothing. so i try 2nd set of plugs, i hear faint sound, but ONLY from rear speakers. figure, that's strange but i go ahead and try the 3rd set of plugs. on the 3rd set, i get full (louder) sound from the front, but fronts ONLY. so my question, what am i doing wrong? was my hu wired up incorrectly b/c it seems like i can only get my aux input to either come out either through fronts or rears only, not both. if i try one front, and one rear plug, then only 1 side of the front comes out, and only 1 side of the rear comes out (duH!). and the rears are always much fainter than the fronts. fyi this was installed on a 04 vw passat sedan (comes with monsoon amp/speaker setup). i also have a jl sub hooked upto to sub output, and pioneer 12disc changer via ip-bus cable. Quote Link to post Share on other sites
cntrylvr79 Posted January 26, 2007 Report Share Posted January 26, 2007 Yes I can help. The rcas have to be plugged into the av input on the d1. THen you'd do as jimmy303 said and turn on the a/v input. Since you have a changer in there your only option without buying more expesive parts is the a/vinput. Quote Link to post Share on other sites
Dubbedown Posted January 26, 2007 Author Report Share Posted January 26, 2007 Yes I can help. The rcas have to be plugged into the av input on the d1. THen you'd do as jimmy303 said and turn on the a/v input. Since you have a changer in there your only option without buying more expesive parts is the a/vinput. ok sounds easy enough to do. connect back to audio input rcas, enable av in setup screen. will try again after work... but with this will i get sound from all speakers? Quote Link to post Share on other sites
tillithz Posted January 26, 2007 Report Share Posted January 26, 2007 yes you should. Quote Link to post Share on other sites
Dubbedown Posted January 27, 2007 Author Report Share Posted January 27, 2007 it works, thanks everybodY! Quote Link to post Share on other sites
tillithz Posted January 27, 2007 Report Share Posted January 27, 2007 right on! Quote Link to post Share on other sites
cntrylvr79 Posted January 28, 2007 Report Share Posted January 28, 2007 right on! Right Off!! at any rate glad to hear it worked out for you. Quote Link to post Share on other sites
Join the conversation
