faizathman Posted October 6, 2013 Report Share Posted October 6, 2013 SUCCESS ON AVIC-F30BT without any problems !!! PERFECT !!! many thx. Quote Link to post Share on other sites
Travolta Posted October 6, 2013 Report Share Posted October 6, 2013 How do I extract the five separate files to make one file? As Saman said, or download 7zip its free and right klick extract here. Then you will have UPDATE and FIRMWARE folders also CARDINFO.cif. But all these to the root of your SD-CARD. Regards Quote Link to post Share on other sites
bsmile000 Posted October 6, 2013 Report Share Posted October 6, 2013 Succesfull update on my F40BT. Great that I now have updated maps. The explaination here on how to do the update was excellent and I had no problem at all. Thanks again! (and I've donated of course....) Quote Link to post Share on other sites
saman Posted October 6, 2013 Report Share Posted October 6, 2013 Travolta, do you know maybe which version DB from NQ is inside, if i remember previous 2012 maps were 2011.Q3? Is now there maybe 2012.Q3 or 2013.Q1 NQ? p.s. for author of OP, you made mistake in writing instructions, wrote "route", instead files to be added on root of SD card , probably you though root of SD CARD . Quote Link to post Share on other sites
Travolta Posted October 6, 2013 Report Share Posted October 6, 2013 do you know maybe which version DB from NQ is inside, if i remember previous 2012 maps were 2011.Q3? Is now there maybe 2012.Q3 or 2013.Q1 NQ? Seems to be 2013 Q1, new streets and points weren't available until November 2012, but now are available. I've noticed by my self. for author of OP, you made mistake in writing instructions, wrote "route", instead files to be added on root of SD card , probably you though root of SD CARD . Thanks, will be changed. Quote Link to post Share on other sites
matteusz Posted October 6, 2013 Report Share Posted October 6, 2013 hi, guys. can anyone tell will this all work on f3210bt (or 320bt)? Quote Link to post Share on other sites
Fantasy-bart Posted October 6, 2013 Report Share Posted October 6, 2013 The updated works on my f920BT But Bluetooth i got 3.11? Not 3.32? Did i do something wrong? Quote Link to post Share on other sites
frisk Posted October 6, 2013 Report Share Posted October 6, 2013 to update BT, you must do it manually as it's independent from the map update. go to th BT parameters and you'll find an "update" option... Quote Link to post Share on other sites
Fantasy-bart Posted October 6, 2013 Report Share Posted October 6, 2013 oke and then? Use the same files? From the first post? EDIT: I see it ty, going to update this! Quote Link to post Share on other sites
saman Posted October 6, 2013 Report Share Posted October 6, 2013 Yes, same update files contain files necessary for BT softw. update. Seemsto be 2013 Q1, new streets and points weren't available until November2012, but now are available. I've noticed by my self. Thanks, will be changed. Nice news, 2012 were with very old db if i remember 2011.Q3, bad coverage, specially for EE. Hope now is better, i'm sure its better if inside is 2013.Q1. Tnx for info! Np Quote Link to post Share on other sites
matteusz Posted October 6, 2013 Report Share Posted October 6, 2013 hi, guys. can anyone tell will this all work on f3210bt (or 320bt)? Downloaded, copied over and tried with both .cif file versions. Nothing happens though upon inserting/restarting the device. Doesnt fit f3210bt or other issue? Anyways, if this cannot be installed can some share a thread for newest update available for this unit (f320bt or f3210bt) please? Quote Link to post Share on other sites
Travolta Posted October 7, 2013 Report Share Posted October 7, 2013 I think you can install IGO, Navitel, Navigon and a lot of other software with the newest maps on your F320BT. Just search for igo and F320bt. Regards Quote Link to post Share on other sites
mitchellsx Posted October 7, 2013 Report Share Posted October 7, 2013 Thanks for your help Quote Link to post Share on other sites
matteusz Posted October 7, 2013 Report Share Posted October 7, 2013 I think you can install IGO, Navitel, Navigon and a lot of other software with the newest maps on your F320BT. Just search for igo and F320bt. Regards Thanks Travolta. Will try, if wont find a way to update navgate as Id rather have this one updated, instead of having to fire up a seperate navi app.. Quote Link to post Share on other sites
mitchellsx Posted October 7, 2013 Report Share Posted October 7, 2013 is it possbile to update my F930bt to the latest igo maps? ive upated to the maps on this thread, but want to update the latest igo maps? can this be done? Quote Link to post Share on other sites
