RPyfrom1 Posted April 12, 2007 Report Share Posted April 12, 2007 Not all BBY's are worthless. It just depends on the installer... My BBy has a master that has been installing for 15 yrs. Some bby's are good others not as much... lol Quote Link to post Share on other sites
cntrylvr79 Posted April 13, 2007 Report Share Posted April 13, 2007 Sounds like the famous ron gold. Quote Link to post Share on other sites
Jef Posted April 26, 2007 Report Share Posted April 26, 2007 I had mine installed at CarToys. They initailly didn't hook up the illumination wire at all. I took it back and they wanted to charge me $50 to hook it up. They said it was because of the way GM did the light control through the brain. After an hour of arguing they said they would hook it up. It now works with the headlight switch turned on but not when the automatic headlights come on. I can hear the relay clicking when the headlight switch is turned on. So I'm going to listen to the clicking and find the relay... and then hopefully find the right wire to connect it properly. I don't believe the installer really knows how to hook this up or I'd take it back again. I think I can figure it out easier than I can get them to. Quote Link to post Share on other sites
action Posted April 26, 2007 Report Share Posted April 26, 2007 Couldn't you tap in directly from the headlight? I don't know if the illumination wire can get too much power, though. One of the "install gods" on this forum probably has a better idea. Quote Link to post Share on other sites
ducatiboy Posted April 26, 2007 Report Share Posted April 26, 2007 Couldn't you tap in directly from the headlight? I don't know if the illumination wire can get too much power, though. One of the "install gods" on this forum probably has a better idea. Yes, you probably could, unless you have HID's which have very high voltage after the module going to the headlights. But if you have regular incandescents (or halogens) the power wire to the head light is just +12. It doesn't matter if that line can supply 1mA or 30 amps, the avic will "get" as much power as it was designed to tell it that it's +12. All it needs is a voltage level (with the ability to deliver a very little amount of current) and any wire that goes between 0V and +12V will work for the ILL wire. Quote Link to post Share on other sites
Join the conversation
