Jump to content
AVIC411.com
godzilla
New Release F20BT F30BT F40Bt F920BT F930BT F840BT Etc 2017 Release
On 12/21/2018 at 3:20 PM, spoonavic said:
i try update but update stoped to 98% ..pioneer is blocked and ask for sd ...how can i relolve it, please ?
Your problem is caused by something is wrong with the update SD. Very possible that you didn't use the correct password when you unzipped the file. So some files are missing. This advice has been posted here many times.
If the map update fails to complete and you are stuck with a wrong or incorrect SD or similar message:
  • boot into testmode.
  • go into file maintenance
  • remove the file USER\SYSTEM\Download\StartKnd.log
This will kick the unit out of upgrade mode, and it should restart into regular mode on next power up (remember to remove the TestMode SD). You should still be running with your previous firmware and maps.
Share this post
Link to post
Share on other sites
Hello. I apologize for repeating myself, but I am asking for one specific answer contained in one post - I think that it will also be useful to others.
I have a Pioneer Avic F920BT navigation. Currently has original software. Please inform me what to do STEP BY STEP because after many attempts described in various posts,
e.g. I have not found in the file RenewalIFLib.dll all values of 0350A0E3
From what I read it is:
- to upload ShortFuse to SD, run
- on the second SD, upload the map (three files: firmware, update, cardinfo). The cardinfo file with changes on X07EURX27EURX30EUR and then update
Please reply. Thank you
Share this post
Link to post
Hello
A question. Is a Superfuse necessary with a F940Bt? Or can I take the cardinfo from the 2015 update. Firmware is 6.00
Thank`s for reply
Cu
Digger500
Edited by digger500
Share this post
Link to post
1 hour ago, digger500 said:
Hello
Thank`s for reply
Cu
Digger500
If you mean Shortfuse, yes it is necessary. Cardinfo is only to identify which AVIC models the update supports. Since you have an F940, you should not change the Cardino.cif that comes with godzilla's files.
Share this post
Link to post
Hello Ron
Its right I mean Shortfuse not Superfuse. Sorry
I`ve think Cardinfo is only for one HU 940 or 930...
Update 2015 was very simply, the three files on SD card and update... no problem.
Will try it with your Shortfuse
Thank`s for replay. Excuse my bad English.
Cu
Digger 500
Share this post
Link to post
Thank you for this amazing update!. Works flawless.
*Unpack shortfuse on 4Gb sd formatted with clustersize 32kb insert and install
*Unpack 2017 update to 16Gb sd formatted with clustersize 32kb insert and follow instructions
Succes......!
Share this post
Link to post
Looking for some advice here after I followed instructions to update my 920BT unit. Performed the Shortfuse hack and this was successful. Loaded Cardinfo.cif file from RonS which should work for 920BT together with Firmware and Update files using new SD card. Update took 30 min and was successful I thought but then after it restarted I was asked for language option? English was the only EU language greyed out so could not actually select that. I did not select anything and pressed OK to move on. The unit then gave me foreign language..... maybe German or Dutch. Anyone who has done the EU update advise me please what I did wrong and how do I reverse the language option back to English. Can I undo the update and have another go?
Thanks so much
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
