i must be stupid because i have read the entire thread about 3 times for changing the clock colour, adding the cancel button and adding on the km/h reading. And i am still puzzled to where i have to insert those lines to. can someone lead me in the right direction pleas?
Here the steps:
On your AVIC you have to get into testmode (the Windows screen). Do that by putting the testmode and MitaCap folders on your SD card. Use the stylus and triple-click on any folders. When you are there, hit start, go into Windows Explorer, then "My flash disk", then "iGo", then "APL2". In there, there is a file called simply "DATA" with a generic windows icon. THAT is the key file where most of these changes are being made. Either copy that file to your SD card (open up another Windows Explorer box) and click on your SD card, OR use one of the ones we have posted in the thread.
Take that data file on your PC and explore it, do NOT extract the files. In there, click on ui_pioneer, then 800_480. In that folder you see a bunch of BMP's and SPR files. That's where you drag the killroute.bmp into. Then click on the ui folder and click on "navigatemap_800_480". That's where you change fonts, sizes, add the delete route code, etc.
I'd copy the original "navigatemap_800_480.ui" file to a safe place. When you have made your changes, save it with a ui extension to the desktop. Then drag it where the real navigatemap_800_480 file is and say yes when it asks if you want to replace.
Take the new data.zip, copy to your SD card, go back to the original DATA file, rename it, then drag the DATA.zip from the SD card into where the old DATA file was.
Boom, the AVIC uses the modded DATA.zip.
To add the lines of code for the delete route button, copy and paste Stephanie's code into navigatemap_800_480.ui right here:
;time
map.ISROUTEVALID vValidRoute vDeletableRoute
runif vValidRoute 1 sc_btnARM_Itineary_OnRelease
Geatly appreciated thank you so much lemonhead. I know how to get in to test mode just was unclear of where to place the files. Thanks again am in the process of trying it now
