I did the software bypass, and grounded my parking brake wire to the frame of the car where there is contact, but my stereo complains that the parking brake wire isn't installed correctly (or something to that effect).
What am I doing wrong, and does it have something to do with the softmod, or is it an independent problem?
Also, I used the data file that someone else made. It puts the value at "256.0" I was surprised to see the ".0" at the end. Is this correct?
btw, if this is a binary thing, 255 would be a much better choice because 256 takes two bytes. 255 is the biggest number that fits in one byte, so if there is only 1 byte allocated for the number, it could exceed the limit and change a byte somewhere else in the program.
*note: I don't know if this number even has to be binary-friendly in the first place.
