ullull,
I am not 100% sure if you need to ground the parking brake lead in conjunction with the software mod, but I believe you must.If it is in fact mandatory, I'm sure someone will chime in. Having said that, I finally successfully did it today(mine is the F90, just like yours), and will share with you how:
From what I have read on this forum, you can either do one or the other, hardware mod or software. That being said, in both cases I believe you MUST ground the parking brake (green) lead. If you want to enjoy video while in motion, you cannot hook the parking brake wire to the actual parking brake.
This is the constant.
From there, you can either: Add to the equation grounding the mute (yellow/black) lead, but it must first be moved from its original pin location. Take it out of where it is(farthest pin on one end), and move it to [opposite row, count 4 in from the same end]. Here is a rough diagram- *******O
****N***
where O is the original location, and N is where you are to relocate it.(the rows are depending from your point of view, i.e. which way the connector is turned. All you need to know is that from wherever you take it out, it goes on the OPPOSITE side, 4th one in.
OR, you can simply do the software mod. This is where you can seek verification, but as I understand it, the parking brake lead MUST STILL BE GROUNDED. You can find how to do this by searching the mod faq on the forum's wiki. Basically you need to download the testmode rar, unzip it, and place the two folders onto an EMPTY SD card. when you boot your AVIC with the SD card in the slot, you will automatically tap into the Windows CE environment within your AVIC. You need to go into the MY FLASH DISK folder, and from there, its APL2 > IGO > DATA.ZIP > project_config > pioneer.ini. Scroll down, and change the line: parking_brake_speed=16.0 to parking_brake_speed=128.0(use this number to stay within the binary code, just in case it is mandatory). once you change that, shut off your AVIC and reboot without the SD card in it, and you should be good to go. You can also simply copy the entire MY FLASH DISK to your SD card and make your change on your computer, then go back into the Windows CE of the AVIC and rename the original DATA.ZIP something else, and copy the new DATA.ZIP in its place. Either way is fine, but I strongly suggest you make a back up first!! To do this, simply copy the MY FLASH DISK onto the SD card and unload it onto your computer. DON'T SKIP THIS!! If anything were to go wrong, you can always use your back up!! Otherwise you can end up with a bricked unit, and that would be bad
Of course, you can try to do this without first grounding the parking brake lead, who knows maybe it will work. I have not read a thread anywhere that specifically said that it does not. If it doesn't, no harm no foul, you can always ground it later. Maybe you will get lucky and not have to open your bezel at all.If this is the case, please share it with the forum.
I know the frustration involved in this, I thought I would never get it, but today I surprised myself and got it, and it's awesome. And all I did was follow the threads. If you are having trouble, you can email me, or even email me for my number as I would be glad to walk you through it and share my happiness at success. I know how to do this step by step no worries, and if you need clarification on any of these steps, let me know. [email protected]. Good luck and let me know how it works out!
Jay
