Thanks for the great write up. Grounded the green and performed update and can CONFIRM on F500BT that this works. It's great when things go the way they should.
Software mod "bypass" confirmed - Put away your wi
Thanks a million to avicf700bt on page 10, who did the step by steps for someone who knew nothing about the machine. Very easy to do because of him. Thank you.
Ok so my installed says he grounded the parking brake
Now when I start moving and I hit like 10 miles an alert comes up saying that there's an improper parking brake wire instalation
is this going to go away once i do the software bypass?
thanks
Ok so my installed says he grounded the parking brakeNow when I start moving and I hit like 10 miles an alert comes up saying that there's an improper parking brake wire instalation
thanks
Only grounding the parking brake wire will not be enough. Either do the software bypass and complete the hardware bypass and it will work fine.
Thanks but that wasn't my question
As far as i understand the software bypass requires grounding the parking brake wire.
So far I have the parking brake wire grounded, but havent modified the .zip file. My question is if the warning that is comming up now will go away once i do the software modification
tHANKS
Thats the point of the mod
Well I just came back from my car.
Put the SD with the unziped files to boot up in test mode.
Windows does boot up in thest mode. but then it says copying... copies something and when I press the start button the bottom of the screen turns green and gets stuck
any ideas?
Thanks guys
edit: btw, i tried to close the window with the ex in the right top corner but nothing happens...
Recalibrate your screen prior.
Thanks but that wasn't my questionAs far as i understand the software bypass requires grounding the parking brake wire.
tHANKS
So how did what I said not answer your question? "Do the software bypass or complete the hardware bypass and it will work fine". working fine includes no messages coming up.
i just got this system in the mail (avicf90bt), and im going to get it installed at a shop tommorow. is this data zip file located on the screen or something or do i bypass this with the sd card? sorry but this is probably a stupid question but im a noob to this kind of stuff. i want the people to bypass it at the shop, and i want to print out something for them so they know how to do it
thanks
All Done. I managed to close the copy window by recalibrating the screen. And everything worked perfectly
Thanks everybody
I have confirmed that changing the parking_break_speed value in the DATA.zip file (/project_config/pioneer.ini) does in fact bypass the video/gps restriction without changing any wiring. I set the value to 128.0 (thought it odd that they picked 16, so I assumed they were using the standard 1,2,4,8,16 binary notation so I chose a number that would fit in that series, hence 128).
I know this works because I just installed this unit 2 days ago and did NOT use any bypass. With the change made to the ini file, I can now enjoy video while traveling up to 128 MPH
hello ok i have no idea where to get the file forom can some one help me pls?
yiyasss
read throught the whole post and you will find it.
Thanks guys the software bypass worked great for me once I finally used winrar instead of winzip. Lovin every minute of it.
I've read through this entire thread (more than once) and it has alot of very useful info. I had a question as a nubie. My HU was installed professionally and I asked him to ground the parking brake (which I read here) because I plan on doing the software bypass. Right now, when I get to about 10 mph the "parking brake not properly attached" message comes up, does this mean it is successfully grounded? I saw someone who asked this question but I didn't see an answer. My next step is the software bypass but before I do that I wanted to confirm that the parking brake is grounded. If this isn't the case I plan on taking it back to the installer to see about getting it done correctly or do it myself if I don't have to take the dash apart.
My HU was also installed professionally. As it stands right now, I can only view a movie when my parking brake is on. Once I do the software bypass, is it going to work fine, or am I going to have to do something regarding the parking brake? Thanks in advance.
I'm ready to take the heat for being the novice here. I installed F90BT system except for connecting the pink and green wires (GPS and Brake) I recently found your site and began reading. The solution for DVD and setting GPS while on the go seems simple enough. However, like I said I'm a beginner. Somehow, I go into the files on the system (HOW??)and update it to read about 128 on the parking_brake_speed value and then connect the brake (green) wire to ground. What about the GPS (pink)wire? And is that all I need to do? Thanks for the help. I have a 2008 Ford F-150. Plain old work truck.
no just the parking break wire, and thats all to bypass.
just do the hardwire bypass, its easier and faster and cause since you are grounding the parking break wire, WHY NOT ground the mute wire as well? i mean your already grounding one thing, how much trouble is it to ground another? the hardwire is much easier
Since your unit is already connected up, then yeah, software might be your best bet now. cause it would be a hassle to pull the unit back out.
*edit* Whatever that pink wire is, connect that crap. you might need it
Another reason to do the software bypass instead of moving the mute wire is that a number of people on this forum have messed up the mute wire pin in the process of moving it to the bypass location. This results in a failed or unreliable bypass.
Hey. I did the update and everything correctly. I can drive and I have a msg @ the bottom of the main screen saying System Setup Please Wait. It will not go away. Every button works except for Phone and Settings @ the bottom. The DVD playback works above 16mph fine, but then all of the sudden it goes black and resets everything. The back to square 1. "System Loading Please Wait"....It continues over and over....BTW all this happpened after i changed the data.zip file..
PLEASE HELP
THANKS GUYS
I did the bypass and it works, but then realized it was just for video an not other items such as changing nav points and such while driving. I corrected this issue by simply updating all .ui files inthe 800 400 ui folder, replacing USE_SEPARATED_SAFETY_MODE=1 with USE_SEPARATED_SAFETY_MODE=0.
It works beautifully, but the only thing I could not get unlocked while driving where the Nav and System setting icons. Any idea where those values are stored?
Edit: While street and city can be entered, I cannot enter the address number while not in park as well. Any ideas here?
Ceger
Ceger
Ummm... your bypass is not correctly made. USE_SEPARATED_SAFETY_MODE works off of parking break signal.
Here, if the instructions on this forum cannot help you then its time to go to ebay
http://cgi.ebay.com/ebaymotors/New-Pion ... ioQ5fVideo
the instructions here only cost 24 dollars and plus shipping!
I've modified the pioneer.ini file but how do I releoad it? I have already installed the 2.0 update.
Ceger
In the thread on mute/unmute nav voice, it was found that to have buttons activated even with setting the parking_break_speed value for the bypass from 16 to 128, you still needed to update the variable in the Pioneer.ini for USE_SEPARATED_SAFETY_MODE to be 0 for buttons to work or not. Thus any screen buttons coded specifically in the ui files with USE_SEPARATED_SAFETY_MODE = 1 maintain being unusable.
I did the change as described here in this thread, and found that I needed to do the USE_SEPARATED_SAFETY_MODE overwrite as well.
To be clear, reading through this thread seems to indicate that the bypass is not software only; you need to ground the parking brake. That is not part of a valid install you will get from a place like Best Buy. My modifications has allowed alot more functionality than I had before, all software driven.
Ceger
Hey I didnt read thru this entire thread so I dont know if its been said already, but I asked my parents, who both have programming degrees and they told me that the top number possible in an 8 bit system is 255, not 256. I just tried this in the hack and went 60 miles an hour with no messages and all features availiable so I guess that they are right. I hope this is helpful, since I know I didnt want to have a top speed of around 80MPH
~RossGo
~RossGo
Where does the assumption that it must be an 8-bit number come from?
TO THE PROs: worked the very first time, thank you very much.
ATTENTION MAC USERS, do it on a PC with winrar
