Version 2.0 is LIVE!
By JasonH · Oct 29, 2008in General💬 236 posts👁️ 91,515 views
Page 4 of 10
Posted Oct 30, 2008 · 01:07 UTC#76
Just updated mine and found all my presents for XM and FM and AV settings all retained :) Also my background image was not reset.
The phone contacts are still there, but not accessible til after phone is added.
Took a quick look around and though I saw new options under XM > Func > Memo? I don't remember the Alert on/off or what appears to be the ability to select/deselected individual songs?
Also doesn't seem to have the continued slow response after the booting message disappears like before where it would take several minutes before performance was "normal"
Posted Oct 30, 2008 · 01:13 UTC#77
The phone contacts were wiped...
Your XM or Sirius presets are saved in the actual XM box.
Posted Oct 30, 2008 · 01:13 UTC#78
The system does load quicker and gets rid of that "System Starting Up" message.
IPOD
From the measurements I took, Ipod with VR cataloging turned off, the Ipod starting playing in around 25 sec. I have not tested the SD card yet because the 2.0 firmware was on there. The Ipod didn't disconnect one time while I was testing the new firmware but only time will tell on that too. Bluetooth connectivity after about a 80 seconds.
Navigation
Still doesn't tell you what side of the street the destination is on, but I would suspect that is a problem with the version of iGo. The system still give you a whole lot of direction too, I call it beating you up with directions. The system did reboot once while inputing in a point of intrest.
Hope this is not a problem. Again no heads up in 2 d mode.
Button response
Seems to be pretty responsive, only time will tell.
Screen Brightness
Can't really tell the difference but it is night time here in New Jersey.
Bluetooth
Contact are still duplicated however there is a the word "mobile" "home" indicating which number you are dialing. (nice)
Other than that I didn't have any problems with my HTC xv6800 phone. But I'm ridding in a 2007 Mercedes, so the ride is pretty quite. And I didn't have a issue after the first update.
Finial thoughts
Just to wrap this thing up I have a F90bt, 5th Gen IPod 80 GB, 12" Kicker L7 with a 1000 Watt MA audio mono block amp. 10 Farad Capacitor.
Wish List
1. Navi update so it tells you what side of the street your target is on.
2. A little less directions ( don't need an update every 50 ft, seriously)
3. Way to download radio setting to (SD Card, so you don't have to configure everything when you do a reset)
4. Diagnostic screen (like n3, where you can see signals, voltages, stats)
Thanks Pioneer for supporting your product.
Posted Oct 30, 2008 · 01:21 UTC#79
Just did a 5 mile loop around my neighborhood with nav on to "Return Home", and FINALLY, once the unit tells you "You have arrived at your destination" it turns off the directions...... the fact I had to manually "delete route" before 2.0 was flat out frustrating!!
Posted Oct 30, 2008 · 01:22 UTC#80
Do you happen to have an iPod connected? did it fail a connection?
Posted Oct 30, 2008 · 01:24 UTC#81
Does the software bypass still work with the new update?
Posted Oct 30, 2008 · 01:24 UTC#82
My blackberry 8130 seems to hold the connection now!!! Just still cannot get the phone book to transfer!
Posted Oct 30, 2008 · 01:31 UTC#83
Hardware bypass still works.
Posted Oct 30, 2008 · 01:35 UTC#84
Bluetooth
Contact names remained unchanged for me and no additions of "mobile" "home" etc.. I also cleared the memory on the unit then transfered the phone book again, but no change... BTW I am AT&T w/ Motarola V3xx
I was really hoping this would be fixed
Posted Oct 30, 2008 · 01:41 UTC#85
Just installed and it does look *much* better but two notable exceptions:
No track-up on the 2D map (already mentioned).
No station info on the HD radio preset screen.
Posted Oct 30, 2008 · 01:42 UTC#86
I'm sure no one has an answer for me but I figured I'd ask anyways:
For those who have bricked units that died without any hacking or anything, I know there were a few of us that had common problems where the unit would restart constantly, does this update revive our dead headunits?
Posted Oct 30, 2008 · 01:55 UTC#87
Ok what a difference in start up time. (like mentioned above no more dumb system start up box)
I have not hooked up my I touch 2nd gen but it work flawless before (I will try that in a min).
Button and touch screen response also much better.
Screen brightness I used to run it @ 8 or 9, now it is set at 6. It is night time (i'll see what it looks like tomorrow in the daytime)
Blue boxes on map screen bye bye..... Very cool
BT Motorola Z3 connected perfect and phone book transfered no problem.
Ahh one more thing.. I was able to get a new MSN direct key and activate it for the free 3 months. I had to send my unit it for repair a few days after the install, my eject button was broke and I could not reactivate the unit when it came back the key was missing. So its up and running again :D
If I was ever thinking of the Kenwood 8120 before, I sure as hell am glad I went with this unit now!
Posted Oct 30, 2008 · 01:58 UTC#88
Heh, funny story about that:
Since i had so many "drops" of iPod usage, I bought a 4 gig SD card months ago and have been using that exclusively for music...... i will for sure hook up my Nano or Classic or iPhone to test for USB drops..... it was the worst with the Classic....
Speaking of music off SD, i was hoping this update would continue a song upon powering back up, but it doesn't, still restarts the song that was last playing....
ah well, it's better than my old Jensen unit that would forget where it was all together
Posted Oct 30, 2008 · 02:06 UTC#89
That's weird. My bootup time is definately better, but i still get the "system startup in progress" box
Posted Oct 30, 2008 · 02:13 UTC#90
Is it there all of the time, or only once the UI pops up? It used to be there all of the time (which meant the bottom of the boot screen wasn't visible), on mine it doesn't show up until the UI loads (which makes sense, as it's telling you the system is still loading).
Posted Oct 30, 2008 · 02:16 UTC#91
My startup time is better and the contacts all say the location, but I still have the green/blue boxes on the map screen all the time.
Anyone else?
Posted Oct 30, 2008 · 02:18 UTC#92
I also get that box, but i can live with it for these sweet boot times.
My favorite part of the installation? I was able to listen to the FM radio while it was copying the files over. Sweet!
Posted Oct 30, 2008 · 02:30 UTC#93
No ipod dropouts here, and it was almost unusable before. Awesome!!!
Posted Oct 30, 2008 · 02:30 UTC#94
Mine installed nicely. Made the unit even better. Was surprised it retained my background.
I wonder if this will solve the random reboots as well.
Posted Oct 30, 2008 · 02:36 UTC#95
Ok I do see the system start up box only for a few seconds after the splash screen... I did change my fonts on the navi no problem, but when I put the Windows Vista theme by marmski back on, the the return button on the top right of the screen, pretty much in all of the menus, is a tad off now. There seems to be one and a half images of the button now... weird
Posted Oct 30, 2008 · 02:36 UTC#96
Welp, they still havent fixed the text issue with the pre sets on HD Radio unit, but I can live with the improved performance and bootup times thumbs up.
I carry up to three cell phones at a time and I wish there was a way for the unit to automatically sync up to Cell phone B if I left cell Phone A at home, etc.
Posted Oct 30, 2008 · 02:54 UTC#97
Looks like the "system is starting up" box doesn't show up at all if there's an iPod selected as source on startup. Very cool.
Great update.
Posted Oct 30, 2008 · 03:00 UTC#98
Boot time is faster, still unacceptable at 30 seconds. No other navigation system takes 30 seconds to boot.
Buttons are still laggy for a long time after bootup.
Overall, not a major improvement, except for cutting some time off of the boot.
Posted Oct 30, 2008 · 03:25 UTC#99
Is sombody having problems with the grey boxes (buttons) that hold the Func and EQ buttons on the ipod screen???? on mine it looks like they moved to the outside of the screen, also the "back" button it looks like that image moved. I was putting back the mods I had but used the "old" image.res file I had before the update (if the update modified the image.res to a new one is what I mean.) I didn't do a backup of the files after the update I used the old ones (I know, I know....) so if anyone would be so kind to upload the original Image.Res file of the new update so I can check that that is what caused the problem (hopefully). Thanks.
Posted Oct 30, 2008 · 03:37 UTC#100
is only the update files allowed on the SD? I have the Launcher files and was wnderingif i had to remove those files before attempting the update.
Page 4 of 10
