Using Europe Map on US F900BT
By ydokter · Nov 12, 2008in Hacks/Mods💬 181 posts👁️ 65,930 views
Page 6 of 8
Posted Mar 19, 2009 · 20:34 UTC#127
where do you find maps and poi files??? I have been looking for them with emule but I can´t find anything......................could you help me about it?????????????? Best Regards
I dont know if I am allowed to post external links??? But I found them here.
Posted Mar 19, 2009 · 21:03 UTC#128
Hi,
Can somebody help me finding the right adapter for AVIC F-700BT. I know this post does not belong here but in this Thread you find all people with US AVIC in Europe. So you might have gone through same situation.
I posted my question in http://avic411.com/forum/viewtopic.php? ... 59#p154759
Thanks for your help.
Posted Mar 28, 2009 · 12:57 UTC#129
Hi,
I installed everything as mentioned in the thread on my F700BT. But I can not navigate???
I copied the worldwide license, and replaced EZRIDER. Copied maps of Germany, deleted all US, Canadian Maps. Copied POIs, Buildings. After restarting the system. I was in normal menu and when I go to DESTINATION, I can not put any address??? The address field is dead. Neither can I go to Navigation settings, I have only access to AV settings!!! But if I go to Map, it shows me my location ...
So, I am only able to play radio, SD, etc. No Navigation ... did I do something wrong? Is it because I copied worldwide license not the european one???
BUT if I boot my system in Testmode and go to folder iGo and start run Ezrider.exe from there, the navigation programm starts and I can put address as well BUT this way I can not go to Main Menu, cant play radio, etc. its only navigation software???
Help me.
Posted Mar 29, 2009 · 21:22 UTC#130
Can some one please help me with mylast post???
Posted Mar 30, 2009 · 17:13 UTC#131
Have you installed the base map and European map too?
Posted Mar 30, 2009 · 23:26 UTC#132
yes I also installed base map and West Europe Major Roads along with Germany Map.
Posted Apr 06, 2009 · 07:27 UTC#133
Hi there :)
Sorry if offtopic but I can't figure it out how to make my Mio Moov 330 runs IGO 8? Can someone point me to some step-by-step tutorial or explain me how to do it?
Best regards,
MIljan
Posted Apr 08, 2009 · 03:57 UTC#134
I tried the Hack on an AVIC-F700BT US Version, and downloaded the Middle east Maps, and it works perfect.
Thank u much
keep the good work
Flash
Posted Apr 12, 2009 · 15:25 UTC#135
Need Help Updating Maps...
I've downloaded the 2008.1 maps here
http://turtrek.googlepages.com/countries2008:voorigo8
Thought it odd though that there are 14, not 13 parts that are discussed in this thread.
When I unzip the files, they all want to overwrite each other, as they appear to be all the same files. What am I doing wrong?
Do I only need one of the 14, er..13 parts? Do I unzip before transferring to the f700bt or do I load all 14 .zip files into the "Maps" folder on the unit?
Could someone please spell out directions step by step for this nimrod?
Posted Apr 12, 2009 · 16:46 UTC#136
Download all the RAR's. Use ExtractNow (as recommended by another member here, sorry don't remember who) to unzip them all at the same time. The program does the work.
Posted Apr 12, 2009 · 18:37 UTC#137
Hello!
Would other maps like Europe and Australia work on a US F90BT even though these aren't sold there?
Posted Apr 28, 2009 · 08:31 UTC#138
Hello every body
I am going to buy a avic f90bt (buy in USA for europe use), i read all this post ;), i only have a last cuestion, if the unit cames with 2.0 firmware instaled...-> it means a problem for me?, can i change the maps, or it is not posible if the unit has 2.0 firmware.
Thaks a lot for your help
Posted May 07, 2009 · 16:56 UTC#139
Hi guys,
want to thank everyone in this thread for their input, have a US import F700 in my Lexus GS300 in the UK, hacked using 2008.07 UK Maps, and even managed to get a free years UK speedcam subscription from Pioneer website, works superbly!
Posted May 07, 2009 · 18:59 UTC#140
what have you done for speedcam suscription from Pioneer????
Regards
Hi guys,
Posted May 07, 2009 · 19:06 UTC#141
For uk -
Visit pioneer uk website, and register, then go to avic page and click on '1 Years free safety camera subscription' go through the process however leave serial number field blank and it will give you the access code for the POI Warner website (pioneer give you the link to download). After this, put an sd card in your unit, power it up so the unit writes a license file on the sd card the speed cam software can identify. Then start the POI Warner software and follow instructions to write speedcam data to the card. After this insert sd card and boot the unit, it should then show UK speed cams.
Let me know if it works for you.
Posted May 07, 2009 · 19:31 UTC#142
Hi,
I tried it on the dutch pioneer side and it work's.
Thx for the tip :D
Posted May 10, 2009 · 15:51 UTC#143
Hi folks,
I'm new on this forum, and I have the f900bt model.
I live in Ireland and the unit is the US version.
I spent some time reading up on loading EU maps on the unit but I found it little bit confusing :oops:
So far I managed to download igo8 maps for Ireland file name: Ireland83_2008.10_081212 (would that release work on the unit?)
Inside that folder I have :
Ireland.3dl
Ireland.fbl
Ireland.poi
There is no license file or anything.
From what I could understand I should do the following:
Boot unit in test mode
Open APL2\IGO folder and make back up copy of the ezrider.exe
Then I have to paste the ezrider.exe taken from ir.zip (that can be found on the forum) to the APL2\IGO folder over the original ezrider.exe that I copied.
Take the license file also found in ir.zip and copy it to APL2\IGO\license
Copy Ireland.fbl and paste it to APL2\IGO\Content\Map
Reboot the unit and the maps should be working
Is that right?
Should the Ireland.poi go to APL2\IGO\Content\POI?
If yes what about the Ireland.3dl?
Thanks for any info in advance :)
stan-the-man
Posted May 10, 2009 · 17:45 UTC#144
Hi folks,
Ireland.3dl
Ireland.fbl
Ireland.poi
Is that right?
stan-the-man
Sounds about right. The .3DL file would go into building folder (these are landmarks).
Posted May 10, 2009 · 18:53 UTC#145
Cheers for that Boris, will go at it so and see what happens. :D
Regarding different European maps: can these be added the same way as this one, using the same license?
Thanks again :wink:
Posted May 10, 2009 · 19:21 UTC#146
Yep, you can update all the maps in the same way.
Regards.
Brian.
Posted May 10, 2009 · 19:29 UTC#147
Sorry Stan just re read your last post, you do not want to dowload the 83_2008.10 files, the ones that will run on your F900 are the 8_2008.10. The 83 maps will not work, they are for the newer IGO based systems.
Regards.
Brian.
Posted May 10, 2009 · 20:20 UTC#148
Thanks for the heads up Brian and all your help too :D8) .
stm
Posted May 12, 2009 · 14:29 UTC#149
hi, im new to this im trying to add a UK map on to a US model of the avic f90bt, iv got the test mode files and the igo8 files on a sd card, i put the sd card into the machine boot it up it copies the files then once its finished it goes away but leaves a green box behind. i then try to go to start all progs then exploror but it seems to crash and i cant close the copy screen down to see the desktop what ever i seem to click either leaves a green box behind it or crashes the system
any help would be great also im new to this got the unit yesterday had a look last nite for a few hours and need some help.
just a few questions if people dont mind thanks,
is the igo8 software an updated of the original navigate maps already on the system ?
what do i actaully need to add a uk map is it the same as tom tom you just write over the existing maps on the system folder with the ones i want and it will change them ?
the maps i have found on the net are named "UnitedKingdom8_2008.04_080526" is this correct for uk maps ?
To install the maps do i have to be in testmode or can you do it from the standard screen which it loads ?
last question, the igo8 prog lanuncer is this instead of the origianl front end software which came with the unit or is it used to add items to the pionner software already installed
Thanks agian for all your help if you can email me post in here be so greatfull my email is [email protected]
Thank again sebastian
Posted May 23, 2009 · 10:23 UTC#150
im having a miserable time doing this
i followed the instructions, nothing
i have maps for germany from igo and a generic license
nothing
someone help
can someone put it together for me so all i need to do is copy over what they send me to the sd card and then just copy it over into the head unit?
i will paypal some cash for this, seriously
Page 6 of 8
