1. See IDT's post. They are Igo formatted so you need special software to read them.
2. Not sure what you mean by borders, the rounded corners and white lines are all in my custom bmp images.
3. Can't remember if I kept copies of the originals in my data.zip, if I did they will have the same name with something like _orig tacked on the filename. If not then just get them from your data.zip backup (although I probably changed the position of the boxes slightly so the originals might not fit perfectly)
Thanks for your answers Matt/IDT. I've stopped being dense now and worked out what I needed to do. I've created my own custom boxes and icons too so it sort of matches my car. Went for a greyish silver look instead of the orange but I'm pleased with it now....almost! Added a nav settings and day/night button too when no route is active. I do have 3 more issues, would be great if you could help....will go for A B C style questions this time
A. The '2D/3D' icon and the 'info' icons always fade after several seconds to a more translucent state, where as all the other icons don't. At first I thought it was because they are those 3 icons in 1 .bmp's which have different alpha channels, so I made all 3 images the same but still didn't work. I can't work out what controls the translucent effect. I've noticed IDT's icons dim when inactive.....so guessing it's possible to stop icons dimming too.
B. Same 'info' icon (or 746_32K_OM-013_32b.bmp) doesn't seem to line up on the screen where I tell it to. I've tried renaming it (and updated the navigatemap_800_480.ui file accordingly) but no joy. Why is this one being awkward?
C. What file controls the poition of the route boxes? i.e. 'info_bg.bmp' in your data.zip.
Thanks alot, I'll post pics when it's all done so you can see what a mess I've made
A. tha fading of the buttons are controlled by a script in navigatemap.ui,for the rest of your buttons to fade you will have to declare all those buttons and include them in the script in the navigate.ui, you will have to check m ythread if you're not sure what i'm talking about
