GTIMatt's Mods
By GTIMatt · Mar 23, 2009in Hacks/Mods💬 346 posts👁️ 60,843 views
Page 13 of 14
Posted May 12, 2009 · 23:19 UTC#301
GTI,
i've redone my my speedcam settings and removed some stuff, the spoken warning has an on/off option instead of the having the custom in the audible warning and proper spoken anouncement will be called depending on the regional unit settings, the one thing i can't figure out is the setting of the spoken warning volume, could you tell me what i have to look for, been busy the last few days redoing the speedcam settings and a little help would be appreciated
so anything?
I haven't changed much here from the original mod posted by Boris. What I have done is add the slider to the settings screen which sets the variable vSpeedcamAlertVolume. This variable is then used in script sc_SetSpeedcamSoundVolume in speedcam.ui to set the sound level. Previously the variable was originally set to 32 in model_variables.ui and could not be changed without editing the ui file.
Hope this helps.
thanks, so far here's what i've done, removed custom warning, added an on/off option in the warning settings for the spoken alert, spoken alerts units are now dependent of the unit settings, tried to set some valuemodels on the spoken alert volume but having problems with it,
Posted May 15, 2009 · 04:01 UTC#302
GTIMatt,
I just wanted to post a HUGE thank-you from an F-Series noob!
I dropped your data.zip and font file onto my new F700BT, and what a difference! The Map UI changes would have been worth it for me if only for the much-improved clock visibility, but the whole map interface is just amazing, compared to the shoddy job done in the stock software. Now that I've hacked/fixed my phonebook database and had the installer do the bypass, the whole F700BT experience is truly first-rate.
Bravo!
-chinapaulo
Posted May 18, 2009 · 21:16 UTC#303
Hello GtiMatt.
I installed your data and I'm very happy with it. Additionally, I modified the sys.txt to see the sky, and looks fantastic.
I have a question. My Avic is a F500 , and I have the problem of the icon of the battery charge. Appears above the box of arrival time data. Is there any way to remove this icon, or move to another location?
Thank you very much!!!
Posted May 20, 2009 · 16:47 UTC#304
Does anyone has updated pictures of GTI Matt's mods?
i noticed a small new box for the clock... is it enlarged?
Posted May 20, 2009 · 22:15 UTC#305
Easiest way....... go to Top Menu > Settings > System Settings > Battery Status > Battery Power Indication, and press Off
Posted May 21, 2009 · 11:51 UTC#306
Nothing has really changed from the pictures on page 1. The clock isn't any bigger than it is there.
Posted May 21, 2009 · 17:39 UTC#307
but now its in a separate box correct?
cause from your first mod, i made a red theme for it but with the new set, i dont have the clock box prepared for it thats all. I was wondering where it would be or what it may look like so i can get working on that too.
(lost my previous color formulas)
Posted May 21, 2009 · 18:32 UTC#308
No, the clock is still in the same box as in post 1 together with the speed limit and compass. I can't remember the name of the box but it's something like st_info.
Posted May 21, 2009 · 19:05 UTC#309
oh okay cool, thanks matt. cause i was kinda wondering what this guy was... i turned him into a jpeg so you could see it.
"clock_bg.bmp"
this one is a new one... havent seen that one on there before
Posted May 21, 2009 · 20:41 UTC#310
"clock_bg.bmp"
ah yeah, I remember now! Before I originally released my mod I had the clock in a separate box but couldn't fit everything on the screen nicely so created a bigger box and put the clock, compass & speed limit in it. clock_bg is left over from this and no longer used.
Hope that helps.
Posted May 21, 2009 · 20:41 UTC#311
"clock_bg.bmp"
Hope that helps.
Posted May 21, 2009 · 20:49 UTC#312
Hey matt,
I'm a fellow dubber myself 2009 Rabbit.
Quick question I loaded your data.zip but didn't load the font.
I also change the break speed since I did the software bypass.
And noticed today while driving on i-95 my system keeps restarting could that be because I did not load your font? The problem started the 2nd day after your data.zip was loaded. What ya think?
Posted May 21, 2009 · 22:07 UTC#313
Hey matt,
that would be it, most probably when you were driving on the highway a speed limit was available and when it called for the font used (transport font) it did not find it that's why it rebooted, load the font included and you'll be fine
Posted May 22, 2009 · 13:24 UTC#314
Hey GTI Have you any ideas on how to move the phone info out of the way when in map mode? or just shrink it?
Posted May 22, 2009 · 15:06 UTC#315
not possible as no one has hacked the phone software yet
Posted May 22, 2009 · 15:46 UTC#316
If your talking about the black screen that comes up when you make a call then yes... its possible in a way...
I changed that box to a puffy grey box but i have been thinking about making it transparent lately.
while it would show up more info, im scared that it would make the screen look too cluttered.
i might give this a try.
Posted May 23, 2009 · 23:59 UTC#317
GTIMATT,
I think i have found some errors with your DATA.zip that might alienate your file from US users. I am surprised that no one pointed this out.
I noticed that UK and US uses different bmps to display boxes... so your blue boxes does not display to match. I noticed this when I installed your very first data.zip but it didnt bother me because i changed them all to red anyways.
I just recently installed your newest one, without touching anything and this is what it looks like to US users:::
Also I noticed that i lost the function of 3D buildings compared to your first data.zip, i dont know how that happened but its gone now. Then again, even with the previous data.zip, i had to mod for that too. :?: confused :?:
Posted May 24, 2009 · 01:31 UTC#318
I had noticed that when I stole his graphics a few months ago. A few small changes to navigatemap.ui fixes the issue. Change:
runif vBeta "0" 'sprNMRCockpit.bmp "746_32K_OM-002_32b.bmp",sprSecCorner.bmp "746_32K_OM-004_32b.bmp",sprNMINextStreetBG.bmp "746_32K_OM-006_32b.bmp"'
else_run 'sprNMRCockpit.bmp "746_32K_OM-003_32b.bmp",sprSecCorner.bmp "746_32K_OM-005_32b.bmp",sprNMINextStreetBG.bmp "746_32K_OM-007_32b.bmp"'
To:
Posted May 24, 2009 · 02:37 UTC#319
yeah, thats a good piece of code, maybe i can use that but i can fix this too by simply duplicating the pictures since there are 2 sets, one for UK and US (same thing too). But the problem here is that many people on the forums here cannot. They just want a simple data zip to c/p.
but its funny no one pointed this out... after 22 pages of comments. I had to point it out after loading up his newest data zip.
Posted May 26, 2009 · 08:59 UTC#320
Thank you very much! Not thought of it ...
Sometimes we try to sort things hacking and changing files, and the simplest things we do not .. :mrgreen:
Posted May 28, 2009 · 10:33 UTC#321
Hey Matt, I need help with something here.
You notice that when driving, the first two buttons on the right side dim down after a while. the 2D/3D button and the POI. While that might be cool, its not consistent with the theme. Any way to make them all just solidly on there, without the fading?
i tried looking at several Uis. but no good leads help?
also is there a way to get more street names? mainly the bigger ones?
Posted May 28, 2009 · 15:34 UTC#322
check your your navigatemap.ui, and search for this scripts
script sc_NaviMenuAlphaDown
and
script sc_NaviMenuAlphaRestore
that controls the dimming of the buttons, if you add the name of the 2D/#D button or whatever button on both it will dim it our and restore it on mapclick
Posted May 28, 2009 · 19:37 UTC#323
and
So do i opt them out? or what should i do to make them solid? because those two buttons are the ONLY buttons that do that.
and dietrying... i gotta tell you, you have a have a crazy amount of knowledge with these codes. it almost scares me. lol
Posted May 28, 2009 · 21:36 UTC#324
and
if you'll check those scripts it has the names of the other buttons, so if you want the 2d/3d button and the poi button to act the same way you just add thier names on both script and just follow how they being set,
so these are the scripts
so if you want to dim a button on your mapscreen just add their names on the two scripts and then add the .alpha value
Posted May 28, 2009 · 22:04 UTC#325
And delete or opt them if i dont want? Cause i made a mistake, what happens is the 2D and 3D button and the info button DIMs after a while. and i dont think i want that. i just want them to be on.
Page 13 of 14
