Diaftia's Hybrid mods V1 - UPDATED: 12/1/09 FINAL
By diaftia · Aug 12, 2009in Completed Mods/Themes💬 950 posts👁️ 132,666 views
Page 21 of 38
Posted Oct 08, 2009 · 19:38 UTC#503
what mode are you in with the green buttons?
Posted Oct 08, 2009 · 19:54 UTC#504
Flyover or Simulate route.
Posted Oct 08, 2009 · 20:27 UTC#505
Well it doesn't work with a simulated route.
Posted Oct 08, 2009 · 21:08 UTC#506
Spoken directions? If so, I figured. I think one of those older threads might need to be revived. It doesn't seem as easy as just changing the voice file.
Posted Oct 08, 2009 · 21:12 UTC#507
Hi.Can you please tell me what the car symbol is for on the lower right of the Nav screen?Thanks.
Posted Oct 08, 2009 · 21:20 UTC#508
It appears when you move the map. It recenters the map to the position of your car.
Posted Oct 08, 2009 · 21:23 UTC#509
OK Thank you.
Posted Oct 08, 2009 · 22:20 UTC#510
I noticed that almost everything has some transparency to it except for the next turn, and destination time/distance boxes and the other buttons below them, can they be made transparent also?
Posted Oct 08, 2009 · 22:22 UTC#511
I am having issues after doing this mod.
I did exactly as it lined out on page 1 with the new updated links, and for some reason now i cannot add any favorite destinations
I have to say that when i was deleting all the save data, i did not see a favorite.dat to keep so i deleted everything in the save folder...
Did i do something wrong?
Please help....Thanks in advance
Posted Oct 08, 2009 · 23:18 UTC#512
Try the full screen cockpit mode.
Posted Oct 08, 2009 · 23:33 UTC#513
I see the settings for smart zoom, but can I turn it off?
Posted Oct 09, 2009 · 00:04 UTC#514
Not currently that I see. I will look into it.
Posted Oct 09, 2009 · 00:58 UTC#515
POI button in the quick menu and then the info button. Either that or go into Plan mode and then click on the cursor icon that is second from the bottom on the left.
Posted Oct 09, 2009 · 01:23 UTC#516
Unbelievable work! Donation to your paypal acct. forthcoming!
I also noticed that the option to toggle smart zoom off was gone, making it impossible to hold the horizon where you want it. Am I missing a setting somewhere, or did you do this for a purpose?
Posted Oct 09, 2009 · 05:36 UTC#518
Hey Diaftia, just wondering if this is the link for the 3.0 update for my device..
viewtopic.php?f=34&t=25838&hilit=f500bt+3+0+3+0+f500&start=45
i really do appreciate all that you've helped me :)
Yep, don't trust me for sure as I don't have a 500, but it looks right to me. Looks like there is a post from yeek with the directions on how to do it about half way down. Nice find.
Posted Oct 09, 2009 · 05:37 UTC#519
I think I have the smartzoom setting working. I will test on the way to work tomrorow. But testing in an emulator seems to work good.
Posted Oct 09, 2009 · 06:30 UTC#520
When i input an address through going to destination and then address, it does not give me an option to save as a favorite.
I see in the mod that you can manage your favorites, but do you add them through address?
Posted Oct 09, 2009 · 11:10 UTC#521
Great! Just yell when it's a go. I assume I'll just need to re-download from page 1 to get it???
Also, could you please re-post your payPal info...there may be others who want to contribute as well if they see it.
Posted Oct 09, 2009 · 16:21 UTC#522
Not too sure what you are asking for. The path that I gave you above leads you to an add to favorites icon. It will then have you pick what spot to save it in and then take you to an address entry screen. By default the current location is populated but you can delete that and enter the address of your choice in. If that is not what you are looking for let me know and we can go from there. :)
Posted Oct 09, 2009 · 16:25 UTC#523
What is the elevation of the guidance when not using the autozoom feature? When I turn off autozoom it fits the route on the screen and then you have to zoom in to see the street level detail each time. I have a feeling this is not normal? I always use autozoom so how does it normally behave. Not sure if there is a sys.txt variable I am leaving out.
paypal info is [email protected] :)
Posted Oct 09, 2009 · 17:27 UTC#524
I really like the mod. The new cockpit view is awesome. The only feature I would like to see added to the cockpit view would be a mute button. Also, is there a way to have a button to switch from normal navigation view to overview, so you can either see current location or the full route plotted out?
Thanks again. A modest paypal donation is on the way.
Jim
Posted Oct 09, 2009 · 18:00 UTC#525
Jim
Hey Jim-
The purpose of the cockpit mode is to keep things clean. If you click on the route direction icon you will get an avoid screen. At the bottom of that screen is a mute button. Pretty easy to get to.
As far as seeing the route just click the quick menu and to to the plan screen. That will show the while route on a map.
Page 21 of 38
