You can just install the image.res file into the APL folder.
Thank you, and all of Diaftia's latest mods will remain the same?
Yes just the colours change,not the mod itself.
Alex,
Thank you for all the hard work. Your mods have transformed my X910 into the unit it should be and makes the AVIC one of the best GPS units out there. I finally felt guilty enough about enjoying the mods to send a token of my appreciation - you have a new donation on your paypal account.
Regards,
Ken
Well this will be for all of the settings and sat radio/ipod stuff. All of the navigation side of things will remain the same. If you want to change all of that too then you need to run the full pack. In the image.res files the images stay the same name they just change the color/look of them so they are fully compatible.
Alex,
Regards,
Ken
Thank you very much for the donation Ken! Always greatly appreciated!
hi Alex,
can you tell me why (on IDT's mod) why when i long press the compass (to get to the speed-o screen)it crashes and then hangs on splash screen?
i have to delete user save files to get it back up and that is a drag cause i have to redo a lot of the POI icons.
Just asking cause i seen you were online...
Oooomf.
So i completed this. Not sure i see anything different. Admittedly the biggest thing I was looking for was to play video without my e-brake on.
But that still doesnt work.
ill have to see if anything else seems like it updated.
-R
Oooomf.So i completed this. Not sure i see anything different. Admittedly the biggest thing I was looking for was to play video without my e-brake on.
-R
yup it looks like the other changes work but not the play video while Ebrake is not engaged.
Weird. Could version 3.020100 have anything to do with it?
Very weird.
Whats the best way to bring up a list of the nearest POI's?
For example... say I'm parked (for legal purposes:)) and I want to look for the nearest Starbucks. I press the quick menu, then POI, then...? This is where I get a little confused. And do you know if there's a way to always have the turn by turn directions set to off rather then muting it all the time on a new route?
I would go for poi search then type in starbucks.It will list all the starbucks with the nearest at the top of the list.As for your second point,just don't plan a route then you won't get either the turn directions or the voice prompts?????
Thats the way I've been doing it, wasnt sure if there was another way.
I noticed that when Im driving and on that search screen, the miles to the destination dont update. Is that done on purpose? My standalone NAV would count down the miles if I were driving towards it, and remove from the search if I drove passed it.
hi Alex,
Hmm... not too sure. Going to have to take that up with IDT. Sounds like there may be a coding issue someplace.
-R
Very weird.
Spoke to you offline. You might want to hold the reset and eject button for 5 seconds after doing my update. I should put that in the install instructions.
For the nag kill look at carvers thread. Either way you are going to need to ground your parking brake wire.
There is a search for POI's around cursor in the quick menu. You can also go to the route planning screen and click on the search button there too.
As far as the mute all the time, that is in the next release.
Thats what Ive been doing as far as POI searches.... only thing Im running into as an issue is when I do a search for something, one would think that it would sort by closest and as I was driving (while still in the search results screen) the distance would get smaller since I was driving towards that POI, and if I passed that POI then it would go away from the search field and then the next closest would appear. This doesnt seem to be the case now. And if I do a search for Starbucks while I'm driving, I honestly dont know where its pulling my location or the POI location because it doesnt seem to be close to where I'm actually at. But it does however show the miles as 2-3 miles away, but the city/address is incorrect. I dont think this is a "theme/mod" issue but possibly a POI issue?
Im using the branding file located here:
All of that and more is defiantly in the new version. Putting the final touches on the POI code at the moment
Cheers
34by151
Cheers
34by151
I have the "latest" version... unless there was an update that I'm unaware of?
Cheers
34by151
The new version isn't out yet 34x151 and Diafia are working on it......
ovalball: The new version isn't out yet 34x151 and Diafia are working on it......
Awesome.... I would def. love to see that feature. Its a pain when you have to cancel out of the search listings and search again while you're moving.
On another note, is there an easy way to delete a via point via the quick menu? Im deleting the whole destination, then re-adding it now.
The other feature that is coming that I absolutely love and have seen in other nav systems is an arrow showing what direction the POI is in. My big thing is if I search for a gas station and there are 2 chevrons within 2 miles of me I don't rightfully want to go to the one that is behind me.
As for the via, go to the route button then I believe its edit route. From there you can delete a via or reorder them. You can also click on it in the route planning menu and use the expandable menu at the top to remove via.
That sounds awesome too... seriously, what are you guys waiting for? JK Beta testers? Count me in hehe.
The new iGO Primo will have that stock... whenever it appears.
On current iGO it is possible through some fancy skin design. However, it is only accurate if it know which direction you are facing, and we all know that map can spin when you are stopped...
If you have an active route, it also shows the detour distance as well as the total distance and direction. Yo can teh sort on any of these
Cheers
34by151
Ok so I really want to make this my full time mod .... but 1 thing is killing me I have been back and forth between this and IDT's mods and mapchanger , Navteq , Teleatlas..
I want Daftias w/9.6 teleatlas and most importantly the subaru impreza ....I have no problem fixing the sys.txt with other mods for some reason I just can't get that car on Daftias.....
I have the .mdl , .tex files in gfx , 3dcars, apl2/igo folders and I get the start up screen
If anyone could help me out that would be awsome (before I wear out my SD slot.....lol)
I have tried these two methods and more:
