Diaftia's Hybrid mods V2.3 - UPDATED: 01/14/10
By diaftia · Dec 01, 2009in Completed Mods/Themes💬 1,194 posts👁️ 195,795 views
Page 41 of 48
Posted May 30, 2010 · 01:00 UTC#1001
Something must be wrong with me..... I'm 41 and I check this thread for v3.0 three times a day!!!!!
Posted May 30, 2010 · 07:19 UTC#1002
You're not alone. Thought it was just me
Posted May 30, 2010 · 11:33 UTC#1003
Guys, This is not going to be ready for quite some time and when it does, it will be put up in its own thread as was explained several times here. According to 34X151, this is a whole new rewrite of the code which does not happen overnight. Also, this is probably going to be different than Diaftia's mod here that you are familiar with so you may not even like it. We do not know what to expect as there were a couple requests for screenshots and those requests were denied, so please! be patient. personally, I would have preferred this mod to be modded with a slightly new graphical interface and the new features rather than rewriting a whole new code which may, or may not be completed depending on bugs and errors. But, to each their own, and I wish them the best!
Comments like what you posted are more considered spam than anything as it has no relevency to this thread and the topic on 'when' has already been discussed time and time again. Be patient! Look in the completed mods section and when it is out, it will be out
Posted May 30, 2010 · 12:01 UTC#1004
Something must be really wrong with me, spent the whole day debugging code!!!
To clarify abb1's comment, The look and feel of the mod is retained so things will be familiar to everyone.
Cheers
34by151
Posted May 30, 2010 · 12:08 UTC#1005
Cheers
34by151
EXCELLENT!! :)
Posted May 30, 2010 · 12:49 UTC#1006
Same here and I'm 47 :roll: Would be nice to have it for the holiday season.
I appreciate your hard work, so don't take me too serious
Jörg
Posted May 30, 2010 · 18:57 UTC#1007
Hello, for the life of me I cannot get any applications to run, even after following these directions "
To run any application you must copy it in any next folder
\Storage Card\Programs\
\Usb Disk\Programs\
\My Flash Disk\Programs\
and rename it into "application.exe"
it will run :-)"
I copied the applications to the \My Flash Disk\Programs\ folder, nothing. I renames the .exe files to application.exe, nothing. I place a subfolder under \My Flash Disk\Programs\ named applications.exe and my files inside that folder, and nothing. Did anyone get the "Run Application" to work properly? The directions are too vague or incorrect because no matter what I try I have no luck. Can someone please point me in the right direction?
Posted May 30, 2010 · 21:32 UTC#1008
Cheers
34by151
Thanks 34by151, I'm not sure what abb1 meant by my comment being spam? Nor am I impatient. I was simply stating how excited I am for the next update..
Keep up the great work.
Scott
Posted May 30, 2010 · 21:32 UTC#1009
Cheers
34by151
Scott
Posted Jun 01, 2010 · 09:44 UTC#1010
Cheers
34by151
Scott
I'm with you gibear2k5 and probably many others who are patient but excited awaiting the release of the new mod. Nothing wrong with a bit of friendly conversation. :D
Posted Jun 01, 2010 · 10:06 UTC#1011
I have a few little problems whit this nice mod and my f900bt europ
- when bluetooth is on the unit only reset him/his self?!? on SD card are a lot of POI's
- I am missing the possibility "travel through" it is when I use a poi but not with a address
- is it simple possible to have your complete route map on the screen?
Tanks a lot
Ron
Nobody a suggestion?? :shock::cry:
Please (and tanks)
Ron
I am having a hard time understanding your problems:
1. Reset bluetooth? What do POI's have to do with bluetooth. Can you clarify for me?
2. Travel through? Do you mean add a via?
3. Yes. Go to the route planning screen and click the on the bottom right shown here:
file.php?id=8876&t=1
I'am sorry for my bad written in your language.
== no he reset the complete 9000 when bluetooth is on ===
2. Travel through? Do you mean add a via? === Yes I'm sorry the right name is via.===
3. Yes. Go to the route planning screen and click the on the bottom right shown here: === thanks I have found it . But is it possible with one button on the driving/normal screen? ===
A new one.
- I have troubles with 3 D. I can not see the building pictures and al the levels I have tray. Complete to the left to the right and everything between this
- when the new version is coming is he also ready for Europe to use?
- Is there a Europa (dutch?) user from the 9000BT they have a good back-up from his original system? I have lost my SD-card with the back up :oops::? (I will pay for it)
Thanks again
Ron
Posted Jun 01, 2010 · 14:07 UTC#1012
I was wondering is this mod will work on the 2010 model of this avic the F920BT?
Posted Jun 01, 2010 · 18:02 UTC#1013
I don't know for sure for the F920BT model but it is a NO for the X920BT anyway, because it uses a different OS therefore it cannot be modded.
EDITED: It turns out that the F920BT is the european version of the X920BT, so not moddable!
Check here: http://avic411.com/forum/viewtopic.php?f=50&t=31205&p=213434&hilit=x920bt+confirmed#p213434
Posted Jun 01, 2010 · 20:40 UTC#1014
allright.. thanks mate...
Posted Jun 04, 2010 · 01:05 UTC#1015
It should be a no brainer for your guys ... simple question:
I have smartzoom enabled but I find that the default zoom is too far (I want the view to get closer to the car or the arrow). What is the [smartZoom] parameter that I have to adjust in order to default a closer zoom distance? This should be set in the SYS.TXT file.
Thanks for any help.
Posted Jun 04, 2010 · 03:39 UTC#1016
Try:
[interface]
defaultzoom2d=1000 ; Set whatever you prefer here
defaultzoom3d=500 ; Set whatever you prefer here, 800 or 1000 is default IIRC
Posted Jun 04, 2010 · 12:48 UTC#1017
Thank you FourG, I will try that out!
Do you also know how to control the zooming in at the time of a navigation maneuver? I mean when the vehicule reaches the zone when that is a turn, my setting is that it zooms very quickly to it then retracts immediately back to normal view instead of (my preference) going smoothly then returning smoothly, and of course, during a long lap of time.
Thanks again.
Posted Jun 06, 2010 · 01:05 UTC#1018
Try:
[interface]
Hi FourG,
Strange enought, I put defaultzoom3d=100 or 2000, it doesn't make any difference. :evil:
Hmmm, any idea?
Posted Jun 07, 2010 · 01:58 UTC#1019
Try:
[interface]
Hi FourG,
Hmmm, any idea?
Idea 1: Google "sys.txt iGo 8", pay more attention to results from XDA-developers if they pop up.
Idea 2: Retire the spoon, try eating with a fork or chopsticks for a bit.
Posted Jun 07, 2010 · 02:39 UTC#1020
I search already ... so I opt for idea 2: I prefer chopsticks.
Thanks anyway.
Posted Jun 08, 2010 · 08:05 UTC#1021
Awesome mod guys, the best out there! Maybe its late, and I'm blind....lol I've been reading for hours and cant't find what I'm looking for. When in rout, at the top of the map there is what looks like a small thin progress bar with what looks like a green dot progress indicator. How do I get rid of this? Again, awesome work!!!!!
Posted Jun 09, 2010 · 19:06 UTC#1022
Is there a way to change the color of the map? In day mode it shows up as Gray and i'd like it green like fields or grass.
Posted Jun 09, 2010 · 21:11 UTC#1023
Search up for SCHEMES and GFX, there are a tone of them. Some good one from Abb also.
Posted Jun 10, 2010 · 02:50 UTC#1024
My schemes, even with the GFX folder will NOT work with Diaftias mod!
Posted Jun 10, 2010 · 12:25 UTC#1025
Why is that? Because it also needs ui_igo8 as well?
Page 41 of 48
