FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 31 of 36
Posted Jul 30, 2012 · 03:04 UTC#751
downloading now, is this the best firmware for the x910bt?
http://thepiratebay.se/torrent/5546342
Edited Jul 30, 2012 by jcorkin
Posted Jul 30, 2012 · 06:09 UTC#752
HELP! My F90BT was working perfectly when running V 2.0, but I needed new maps and would like the faster startup speed with V 3.1
Succeeded with all of the steps (hold reset,maps,eject,menu/format SD/copy&paste"MY FLASH DISK") until the restart. Now it wont stay on for longer than 15-30 seconds :shock:
...I've repeated the steps about 3 or 4 times now and its driving me crazy. All the other V 3.0 downloads have been blocked or not found.
Can ANYONE HELP ME PLEAASEE!? :oops:
Posted Jul 30, 2012 · 08:33 UTC#753
NM I got it, thanks anyway. Shes up and running better than ever!
Posted Jul 31, 2012 · 06:09 UTC#754
when i try to copy the files it says there isnt enough room, previous owner tried to update maps and he messed something up so i picked up my x910bt cheap, im wondering what all info needs to be on it? where should i go from here? when i got it it would cycle through the pioneer screen repeatadly and do nothing more. i can get into testmode and everything is going well till i click and drag the storeage card and drag it to the my file disk file and then it tells me there isnt enough free space, i continue anyways just to see whats going to happen and it gets to the extradump files right at the end and runs out of space. then when i reset i get the pioneer screen for about 10 seconds when i turn it on and it goes completely black after that. any ideas?
Edited Jul 31, 2012 by jcorkin
Posted Aug 02, 2012 · 03:01 UTC#755
UPDATE - This was an excellent source for a fix. Only problem I ran into on my X710BT was that the flashdisk on the WinCE drive was only 1.8GB and the files in the flashdisk directory needed more space. This resulted initially in an error during the copying of the flashdisk directory on the MultiMedia Card to the flashdisk on the AVIC flashdisk directory....it would not copy the userdata directory....turned out to be not enough space. I deleted some of the other language files on the multimedia card and then redid the install with the reduced file counta and presto....works great
AWESOME and thanks....you saved my bacon!
Posted Aug 02, 2012 · 03:08 UTC#756
Read the post I just added. I had the same problem. On the multimedia card you made for this install go into the "Myflash" directory, then to "APL2\igo\content\voice". I deleted the mex and french files. I also deleted some other language files in:
Myflashdisk\APL2\VBT\Speech\components..I deleted all the vf_***** files. Then reuse this disk to perform the entire install again. You will now have enough room on your AVIC "myflash" drive
Posted Aug 02, 2012 · 16:14 UTC#757
i deleted the maps for the district of columbia, hawaii, and alaska and then i had enough room to install it, but after installing and resetting it all i got was the pioneer screen for about 10 seconds and then it went black, nothing after that. any ideas on that? i did notice that there were a couple of .bin files that didnt un zip, do they need to be un zipped? im going to try and find a program to unzip them and see if it will work.
I am using a mac to unzip the files via the unarchiver, if that matters at all.
Edited Aug 02, 2012 by jcorkin
Posted Aug 03, 2012 · 17:02 UTC#758
got it figured out, she is working now with the exception of no sound when playing the ipod, im going to do some reading and see what i come up with for answers.
Posted Aug 24, 2012 · 00:52 UTC#759
hope this still works,
Edited Aug 24, 2012 by kevinr1
Posted Aug 24, 2012 · 02:58 UTC#760
It does.
Posted Sep 20, 2012 · 23:46 UTC#761
A BIG Thank You. You made this boarder line POS radio functional. THANK YOU THANK YOU THANK YOU.
AVIC F90BT is now bad ass. Just hope I don't crash while watching videos from my 4S while driving.
Posted Sep 22, 2012 · 07:52 UTC#762
Got it to work, file must have been corrupted, when i downloaded it again that one worked. The new 2010.6 maps worked on it nicely.
do you still have to none corrupted file ? i am having the issue as you when booting up. i think it a bad file .
Posted Sep 23, 2012 · 19:33 UTC#763
When i do this i am not able to get into test mode at all.. Just a black screen.. what am i doing wrong? my SD card looks as follows...
Testmode
My Flash Disk
WINCEIMG.BIN
WINCEIMG.CKS
device.nng
Someone please help!!
Posted Sep 24, 2012 · 01:38 UTC#764
Testmode
My Flash Disk
WINCEIMG.BIN
WINCEIMG.CKS
device.nng
All set on this! wow long two days, the copy exe file was missing from the tesmode. once this was in it got me right into test mode..
Posted Oct 23, 2012 · 16:21 UTC#765
I have read as much as i can handle about 30 pages!
after I am in service mode, it reads image no problem, but stops at 5% when writing image
I have just a black screen no splash screen on a f900bt
I have tried multiple sd cards, and multiple wince imgs 1.006, 1.008. 3.1
i think this unit is f'd!
Posted Oct 28, 2012 · 22:58 UTC#766
Any body with any suggestions?
Posted Nov 08, 2012 · 22:25 UTC#767
Just had to say thank you for this thread! My F90BT would just go to a black screen after showing the Pioneer splash screen. After screwing around with the formatMBR/SDMLC sticky in the troubleshooting forum all morning, I decided to give this thread a go. Worked perfectly! Simple and effective. I reloaded WinCE with the two files included in the torrent on the first page (make sure you select upgrade from SD (format)). Then once loaded up into WinCE, I opened up "device" using the shortcut on the desktop and navigated to the SD card and copied all the files over just as described in the first post. I lassoed all the files and had to use a stylus to be able to select "edit" in the top toolbar, as it was mostly cut off the screen for some reason. Copied. Back out to the local disk and use "edit" to select paste. Allow it to overwrite all files and then wait about 25-30 minutes for it to complete. Held reset and viola! Thanks again!
Posted Nov 11, 2012 · 16:53 UTC#768
Thanks for the still uploaded files. I had bought the Pioneer CNSD-100FM update for my 900 since my only update was the software from Pioneer for the 2.0. After getting into the 2nd SD card it stopped at 3% and wouldnt do anything after that. I had to swap out the 900 for my other one that was for my new car. I just got around to looking whats going on with this one. After numerous topics and files yours worked great. Unit is back up and running. Now just searching for newer mapping. Thinking of trying out the NavTeq 2011 4q mapping that was posted.
Thank you very much for not deleting that torrent or the files. Much appreciated.
Posted Nov 29, 2012 · 14:36 UTC#769
Can someone please help out with seeding? I have a server that stays up 24/7 that will continue to supply everyone the torrent once I get it.
Posted Dec 27, 2012 · 16:47 UTC#770
would really like if someone would seed this so i can complete the download, at 41% and im trying to get my unit working again...
Posted Feb 27, 2013 · 00:38 UTC#771
if anybody has this, can you please seed
Posted Mar 02, 2013 · 04:58 UTC#772
I started having issues with my unit consently rebooting every 20sec's.  I would have just restored from my backup but it got accedentaly deleted.  So I just wanted to say thanks this worked perfectly and now I am up and running again.  Also I am seeding this! Thanks Again
Posted Mar 10, 2013 · 19:28 UTC#773
My 910bt has been having the restart bug and finding this fix was a godsend! Please seed! I will return the favor
Posted Mar 10, 2013 · 20:09 UTC#774
sorry, was gone for the weekend and shut the computer off, seeding now
Posted Mar 11, 2013 · 02:08 UTC#775
Thank you!! Fixed my problem and then some. I just want to point out that my unit only had 1.78 gb free, so I deleted the Canada maps/POIs (My Flash Disk\APL2\iGo\CONTENT) and then was able to copy everything over. Works great now.
Page 31 of 36
