FX3.1 Complete Firmware Image
By Retell · May 09, 2010in Hacks/Mods💬 895 posts👁️ 443,952 views
Page 33 of 36
Posted Jun 10, 2013 · 20:18 UTC#801
This didnt work for me, got to the part where I choose the upload from sd and it says winzip missing or something like that. I formatted the as card and tried everything but not working. Any suggestions?
Posted Jun 11, 2013 · 03:55 UTC#802
double and triple check to make sure you are not missing a step somewhere
Posted Jun 11, 2013 · 04:06 UTC#803
I downloaded it and used winzip and transferred it to my sd card. Keyed it on and followed the instructions. Did I miss something? I'm not computer shabby but I think the winzip worked because the icon changed to books rather then a folder
Posted Jun 13, 2013 · 15:53 UTC#804
If you use winzip to unzip a rar file you will in most cases encounter a error of some sort. My suggestion would be to unrar it with winrar and the errors should go away as long as you follow the proper steps.
Posted Jun 13, 2013 · 19:03 UTC#805
can this be done on any firmware or do you have to be running on a specific firmware? i hate how all of these don't say that information D:
cause i know for regular firmwares you need to do one by one..for instance if you want v4 and you're on v1 you need v2 then v3 then v4...
so...what about this firmware? :) Thanks!!!
Posted Jun 14, 2013 · 01:32 UTC#806
it doesnt matter what version you are running, you just need to run the update to windows, then you are over writing your flash drive with the image of an updated 3.1 flash drive. its not like the system is updating the firmware automatically, your just placing a whole set of system files and erasing the originals...
Posted Jun 14, 2013 · 02:19 UTC#807
I wonder if where I downloaded it from caused an issue. I got it off pirate bay. I tried to do everything correctly but still got the issue
Posted Jun 14, 2013 · 14:31 UTC#808
Still works! Thanks!
Posted Jun 26, 2013 · 00:12 UTC#809
I put the sd card into my Mac to delete the fx3.1 off of it since it didnt work. And it says that it's locked. Maybe that is the problem? Lol
Posted Jun 26, 2013 · 02:18 UTC#810
did you slide the lock switch off of the SD card and try it?
Posted Jun 26, 2013 · 02:26 UTC#811
Yes it's off.
Posted Jun 27, 2013 · 01:28 UTC#812
well thats interesting, I guess it could have something to do with it if it was locked and not allowing the files to be read
Posted Jun 30, 2013 · 21:03 UTC#813
How would this work out on a MacBook
Posted Jun 30, 2013 · 23:08 UTC#814
Alright I'm downloading again on my desktop. I downloaded winrar as well. The containing folder has the winrar logo (3 books stacked) so I guess it Auto winrar'd it? Anyway do I just drag the containing folder to the sd card, or do I have to open the containing folder and drag a secondary folder to the sd card?
Posted Jul 01, 2013 · 01:27 UTC#815
You Fixed my radio! Thank you!!
Posted Jul 03, 2013 · 02:41 UTC#816
My Avic F90BT went out last week for the first time.  I'm trying to upload the 3.0 version right now.  It appears it's going to take about 2.5 hours.  Is this normal?
Posted Jul 26, 2013 · 17:23 UTC#817
http://avic411.com/index.php?/topic/27807-fx31-complete-firmware-image/?p=218239
Hey
I did everything as the link above said and i have problem with turning on my AVIC F500 BT
When it turns on (the pionieer start up screen) Its only on for about 3 seconds, then it turns off automatically...
Do you know any solution to the problem that i have?
Thanx alot.
Posted Aug 01, 2013 · 09:05 UTC#818
Okay so what I've done is simple, I took what I considered to be the basic mods that would be appealing to almost everyone, without drastically changing the look and feel of the system.
This download contains:
Windows CE firmware
X Series 3.0201 update
Complete TA 2009.6 Map Upgrade (USA & Canada)
No nag screens
POI Branding
Speed camera/red light mod
Software speed bypass
Download: <!-- m -->http://thepiratebay.org/torrent/5546342<!-- m -->
You need only a single SD card, at least 2gb in size. Copy the entire contents of the RAR file to the root of SD card.
1. Insert SD card into AVIC and turn it on.
2. When the pioneer logo comes up, press and hold the menu, map, eject and the reset buttons at the same time. When your screen goes completely blank, let go of the reset button but continue to hold menu, map, and eject buttons. This will bring you to a blue screen, telling you to reset the unit (ignore this), you will have to enter the service combination. Press the volume knob in this sequence and you will see * signs for each push: Up, Up, Down, Menu, Left, Right.
3. Select Wince Upgrade
4. Select Update SD Format
5. Wait until it says restart in the bottom center. Reset the unit and leave the SD card in.
6. You should be greeted with testmode (It will look very similar to normal windows). Open Explorer and copy the contents of the "My Flash Drive" Folder from the SD card to the "My Flash Drive" that is located on the unit. Overwrite everything. (It will the copying will take 140min but will only take about 20)
7. Press and hold reset for 5 seconds.
8. Select your language and voice options.
Tested on AVIC-f90bt. 05/08/10
FAQ:
How do I extract this rar thing?
<!-- m -->http://www.rarlabs.com/download.htm<!-- m -->
In test mode it says there isn't enough space to copy the files, how come?
This means you didn't select the SD format option in step 4, select everything on the "flash disk" and delete it, then copy your new files over
How do I know if my download completed properly?
The reason I stored everything in the RAR is because Winrar checks to make sure the download is perfect, if it didn't download properly, you would receive an error when extracting.
My unit just keeps booting to test mode?
Take your SD card out and then reset.
Why did my unit take so long to start the first 2 times?
That is normal, all the software is adapting to your AVIC
this does not work on x910bt
Posted Sep 23, 2013 · 01:31 UTC#819
thank you so much! tried to delete the gpspara files to fix my constant reboot with no avail this worked great!
Posted Sep 27, 2013 · 02:52 UTC#820
Mine starting rebooting again last night and can't find my fx 3.1 file... having trouble with the link, though... is there a new one?
Posted Oct 12, 2013 · 08:36 UTC#821
I'm also looking for the FX31 file. Does not seem to be available anymore. Can anyone share again?
Posted Oct 18, 2013 · 05:03 UTC#822
I have the comple FX31.rar on my server again. Its 1.71gb in size, and kills my badwidth when its shared and downloaded. If you would like to donate a few bucks to help with the cost of hosting a large download, I would greatly appreciate it.
Donations via Paypal: [email protected]
Download Link: http://www.deserttuners.com/FX31.rar
If a mod or admin would like to add the links above to the main post, they are more than welcome to do so.
Edited Oct 18, 2013 by EcoCav
Posted Nov 03, 2013 · 15:40 UTC#823
Just installed my F700 yesterday, and then upgraded to the FX31.
Everything works great!
Thanks AVIC :)
Posted Nov 03, 2013 · 20:48 UTC#824
got what i was thought to be a bricked 700 and thanks to yall its alive!!!! thanks again
Posted Nov 10, 2013 · 21:21 UTC#825
I will add this to my server for download.  I would really like someone to update the maps in this package.  Anyone willing?
Page 33 of 36
