this does not work on x910bt
What did yours do?
What did yours do?
The stylus refuses to click on the edges of the screen in testmode. So I can't click on the start menu or the top of the window icons!
any way to make the resolution less to increase icon/taskbar size?
Until I figured out how to work the dos looking file manager to copy the files I was going nuts without more control.
Runs great! some much more snappier than official release
I need a seeder, please
I have a avh p4100dvd, ive searched everywhere, does anything similar to this exist for my unit, if anyone has info on custom operating system modding please pm me
Hey thanks for all that work on the files and uploading it to the torrent site, I did everything and it went how it should but after resetting and removing the SD card the boot logo comes up and stays there, I left it running over 30 minutes and the boot logo never went away, reset again and same thing...what should I do?
I think I got it figured out. When I went to press format it would read anywhere from 30-60 percent depending on how many times I tried so it never even tried to start formatting, got into windows CE, deleted all the files, showed not enough room to copy new files, showed hidden files, still saying not enough room. Then I opened up the Total commander icon or whatever its called on the CE desktop, had the left pane showing the files on the SD card and the right pane showing the files on the radio. Removed all the files on the radio and highlighted all the files on the SD card that needed to be copied, then dragged all of those to the left pane and clicked move. It did its think until it started to transfer the XM image files (.bmp) and gave an unable to move error with an OK button to press, had to press that OK button a million times since theres a bunch of images, then it did it again with the last few files in the root of the my image folder from the new FW...once you press ok enough to let it bew done copying press and hold the reset button and it worked ![]()
this is all I need but I cant download it
So I just attempted the update on my avic x9115bt and it's not working. Now, the pioneer splash screen will no longer load. Any recommendations? Anyone have the original firmware that I can possibly try to reinstall? Thanks.
i did this upgrade now i get a laguage error when splash boots, anyone know why?? help.
** update **
i figured out the problem with the language, i was using a mac to unzip the file, i read somewhere that need to use a windows to do it, luckily i have windows on my mac using parrellels and worked like a charm. been at this all day and finally finished (12 midnight) and took it for a quick test drive.
response is way faster, everything works perfect and looks like more added options. for this unit being so old, works perfect for my little get around truck i bought. so hopefully if anything reads this, use windows, i was able to download the file searching thepiratebay, looks like original topic starter is still uploading, i will seed as well.
Hi.
I´m Angel, I´m from Spain and I have an AVIC F700BT with troubles.
Some days ago I updated it and now it gives me a message (the machine is starting up, please wait- more o less) and in 4 or 5 minutes, it reboots.
I need the FX3.1 to fix the problem. but all links I found are broken. Can someone help me?
I have seen on ebay an Ãtem that says fix the problem, but I don´t know if it works or not. (I can´t paste the link, I don´t know why.)
Thank you very much and I apologize for my English.
I´ve download it.
Thanks.
So I'm definitely not a computer expert but I downloaded the file and put it on my SD Card. Follow the steps and punch in the up,up,down,menu,left,right. It gives me an option 0=wince Upgrade so i select that. Then it has options 0=wince by SD/MMC (format) or 1=wince by SD/MMC. I've tried both and when I select them a red message pops up on bottom and says (Can't find WINCEIMG.CKS file!) Any key to continue. PLEASE HELP!
Thank you!! Fixed my issue!!
I got as far as picking my language and voice and it froze on the pioneer logo screen please help
Hi, i have pioneer avic f910bt and i dont have backup from firmware
I install fix3.1 on this but navigation work and tel but the audio and tuner not working
Can any bady help me or did any bady have a backup of original pioneer avic-f910bt
Thinks and sorry for may english
I need some help trying to find this file for my F90BT. Anyone still have this file?
Can anyone help me. Trying to get testmode files but can't find them any where. I come across dead links. Please help
Please is there someone that can send a torrent link of download link? No links are working here.
I have F700BT
Firmware 2.009.000
Card version: 01.000800
I want to upgrade to firmware: 3021000 but that is only possible with card version 02.XXXX
So my following question is:
Can I first put cards + License + hacked EZrider.exe in the iGo Folder? And after that update to Firmware 3021000. Or is it not possible to update anymore after installing hacked EZrider.exe?
Thanks in advance, Kajoe
Hello, I have broken avic f700bt and I do everything exactly step by step like in this topic,
but when I turn on my unit, choose a language, unit stuck on splashscreen and thats all.
After same time unit reboot an round robin.
When I try to start some application from testmode level (for example Av.exe)
unit show me very quick information (Application Av.exe has performed an illegal operation
and will be shut down If the problem presist, contact the program vendor Program:Av.exe Exeption: 0xC0000005
Adress:o2BD56F4" and after that unit reboot. Only thing I can do is start MainMenu.exe and go to Settings, nothing else.
Before this I try to fix unit with 2.x windows and 2.x pioneer update and I have simmlar problem.
Someone help me please, I dont want to spend cash to service :/ You thing this is software or hardware problem???
Sorry for my bad English, I hope You will understand me
Have nice day.
Hi your problem was simple to abort take a sd card copy this files inside with testmode use total commander
you put my flash disk inside your avic copy all files inside your flash diskafter you copy my flash disk copy this files it's polish lang and voices put them inside your avic (open apl2 after open igo and content and put the folder lang inside lang and voices inside voices folder )after you do this tell me the result
Thank You for Your respond.
I update windows CE from Your files,
and copy all to to "my flash disc" (overwrite all)
but I still have the same problem, unit stuck on splashscreen.
Earlier I was angry and try everything,
maybe I broke something in service menu?
But service menu, and testmode works good.
hi take this folder nammed lpue080 inside you have a folder nammed PLT inside you have 2 winces files take them and copy alone in sd card
https://drive.google.com/file/d/0B4MAukIOceEXbTFCZURPRWR1ZFU/view?usp=sharing
insert sd card in your avic turn on your avic and press 3 touch (map,menu,eject) in same time and reset with stylet
when screen was black retire stylet and you have a blue screen retire fingers of 3 touch
avic try a code do this with joystick (up,up,down,touch menu,left,right) and press center of joystick to confirm
choice after 1 and let avic read sd card after message restart your device turn off your avic retire sd card and restart
