2013 USA/CAN Maps Download
By misterwoofwoof · Mar 08, 2014in Hacks/Mods💬 317 posts👁️ 150,467 views
Page 10 of 13
Posted Nov 11, 2014 · 00:50 UTC#226
Having the same issue also.
Posted Nov 14, 2014 · 03:49 UTC#227
Does the Firmware of the unit affect this update?  For example, can I update the firmware to support a Iphone 5+ after I installed the Map Update first?
Map Update + Hot Fix
Firmware from Pioneer V5.100
Posted Nov 16, 2014 · 05:02 UTC#228
So I did this update and the firmware and maps installed flawlessly I updated the bluetooth and the version updated but now the unit will no longer connect to my phone. When selecting the unit via my phone it says unavailable! And second off I'm gonna get the new iphone 6 so do I just need a lightning adapter? It's a x930bt that's been upgraded to a x940bt with the current software any help appreciated thx
Posted Nov 29, 2014 · 17:40 UTC#229
Have an x930bt upgraded to x940bt. Curious will Iphone EVER play Pandora through Bluetooth such as my current Galaxy Nexus (without a direct connection)
I would like to be able to see the Pandora app on my deck and not just play audio through the Bluetooth Audio app.
Posted Nov 29, 2014 · 17:41 UTC#230
I am actually debating about picking up an iphone 6 as Verizon (IDIOTS) have no released the info on the Nexus 6.
Edited Nov 29, 2014 by Remha
Posted Nov 29, 2014 · 19:53 UTC#231
Ok so update. With this update, I was able to play any audio (ie pandora, youtube on my unit and see the artist song and track, HOWEVER, no thumbs up/down functions available on IPHONE as I had it connected through bluetooth AUDIO APP!
However, with android, NO PROBLEMS with Pandora even thumbs up and down functions are present on the pandora APPLICATION!
Posted Nov 29, 2014 · 19:54 UTC#232
Anyone know if the Pandora application works via bluetooth in our cars with the iphone???
Posted Nov 29, 2014 · 20:07 UTC#233
FYI I did this with x930BT and Iphone 6 connects fine with the 3.34 updated BT software. However I cannot get the Pandora app to connect. The only way you can connect BT audio with the iPHONE (Iphone 6 in my case) is via the Bluetooth Audio appication.
Posted Nov 29, 2014 · 20:07 UTC#234
Was anyone able to add Appdata via the 5.1 update to get the BT audio to work with thumbs up/down through a Pandora app?
Posted Dec 06, 2014 · 10:18 UTC#235
I would like to thank everyone that helped me on this.  I guess the 5th time is the charm.
Steps I did for the X920BT:
1.  Downloaded the file using Firefox version 29.
2.  Did a reg. format to FAT32.  (Not quick format)
3.  Extract the zip file using 7-zip file program (freeware).  I got no errors this time, even tested the file.  Extracted right into the microSD card. (SanDisk Ultra 32GB Class 10)
4.  Inserted the microSD card into unit, Update menu appeared. Whoa!!! Yup!!
5.  Ran all updates time duration was like 30 mins.  Plus the Bluetooth upgrade firmware also.
Tip:  Make sure your car battery is in good condition, my car battery was weak last night running it.  Ran 4 times trying to update the 2013 map.
Everyone have a wonderful weekend!!! Peace!  :-P8)
Followed this for a 930BT, worked flawless.
1) Format 4GB SD card 16K block fast format FAT32
2) Extracted to desktop with 7zip
3) Copied Firmware, then Update then Cardinfo in that order individually
4) Put SDCard in car, ignition on, asked for update, then rebooted and did the update.
5) Did BT update afterwards
Great stuff...donation coming.
Posted Dec 10, 2014 · 03:31 UTC#236
The download link for the maps seems to be broken. Can someone please fix the link. Thank you in advance!
Posted Dec 10, 2014 · 13:23 UTC#237
Nothing wrong with the link. Just click "download" and ignore the errors/warnings,
Or try this one directly to Google Drive. https://drive.google.com/file/d/0B3ckB07Umie-UVM4bnRVdUpJbjQ/edit
Edited Dec 10, 2014 by RonS
Posted Dec 11, 2014 · 01:39 UTC#238
Thank you RonS!
Posted Dec 16, 2014 · 04:37 UTC#239
I think I was able to soft hack for the Safe-Mode toggle, just by changing the following:
Around offset 15aef0, change the value from 02 00 56 E3 to 09 00 56 E3.
However, I'm not sure why it was recommended to change the following value as well (because I didn't, and I still got the toggle):
offset 15aee0, change the value from 01 10 A0 E3    to    00 10 A0 E3.
Edited Dec 16, 2014 by piranha
Posted Dec 22, 2014 · 02:54 UTC#240
Hi  Piranha ,
      I am using firmware version 5.0 . I couldn't find the value '02 00 56 E3' for the offset 15aef0 in navi.exe located in USERS/PRG1.
But I was able to find it navi.exe located in USERS/PRG0.But I am suppose to modify  navi.exe in PRG1 as I have the  PRG.FLG .
Please let me know which navi.exe did you modify.
Posted Dec 22, 2014 · 21:40 UTC#241
 I was able to fix it after 15 hours of troubleshooting and created a new thread for the Avic411 users.
Posted Dec 24, 2014 · 21:25 UTC#242
Wow, too easy, Lunch is on Me!
Posted Dec 26, 2014 · 19:41 UTC#243
Hello. I tried to update using the instructions and files from the original post for my x930bt but now it says update failed due to error. Now its stuck and i cant get past that screen even after turning radio off and back on
Posted Dec 27, 2014 · 06:58 UTC#244
Never mind. It took quite a few hours and cigarettes and beer, but I got it
Posted Dec 28, 2014 · 17:13 UTC#245
Where is the blue tooth update? =/
Posted Jan 20, 2015 · 03:19 UTC#246
How come after the update (and maybe before)...my Service Information Screen only shows VERSION and DEVICE NUMBER?
Posted Jan 20, 2015 · 18:45 UTC#247
Has anyone done this update on their x930BT with a handbrake bypass(hardwired)? Did the handbrake bypass still work after the update?
Posted Jan 20, 2015 · 20:11 UTC#248
yes I did it to my x130BT.   unchanged behavior after the software update to 5.1
Posted Jan 23, 2015 · 18:11 UTC#249
is this still the most up to date maps.. 2013? my city has been under massive construction last couple years and this still doesn't have the new routes. Thanks
Posted Jan 29, 2015 · 04:33 UTC#250
Upgraded to 5.0 with no issues.
I noticed people are selling this update on SD cards via ebay. Kind of shady.
Page 10 of 13
