AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 16 of 39
Posted Dec 03, 2017 · 19:46 UTC#376
Ð”Ð»Ñ Ð½Ð°Ñтройки времени Ñамое главное удалить gps антенну и отключить питание на 5-10мин
Hi Ilnur,
First of all, thanks for the video. Should I remove the GPS antenna from the back-side of the device? In that case I have to remove the device from dashboard. After adjusting time, is it possible to connect GPS antenna back? On the other hand, from the video we can see that UTC Offset is +540 mins. Most probably this value is taken from a file, if we manage to find this file, without removing anything and just by modifying this file problem can be fixed.
Thank you very much for your help Ilnur. May be DZO can help us about finding this file which consists UTC Offset.
Posted Dec 04, 2017 · 04:05 UTC#377
Да антенну gps необходимо извлеч из уÑтройÑтва.
ПоÑле наÑтройки времени еÑли её подключить обратно то Ð²Ñ€ÐµÐ¼Ñ Ð°Ð²Ñ‚Ð¾Ð¼Ð°Ñ‚Ð¸Ñ‡ÐµÑки ÑтановитÑÑ ÑпонÑким, поÑтому пока не решена Ñта проблема Ñ Ð°Ð²Ñ‚Ð¾Ð¼Ð°Ñ‚Ð¸Ñ‡ÐµÑкой наÑтройкой на ÑпонÑкий чаÑовой поÑÑ Ð²ÑтавлÑть антенну не рекомендую.
Ркакой нам ÑмыÑл от gps антенны еÑли Ð²Ð¾Ð¿Ñ€Ð¾Ñ Ñ ÐºÐ°Ñ€Ñ‚Ð°Ð¼Ð¸ навигации до Ñих пор не решён
Posted Dec 04, 2017 · 10:12 UTC#378
Thanks for your help and explanation Ilnur. You're right, if maps are not usable then GPS is meaningless.
Posted Dec 04, 2017 · 12:58 UTC#379
thanks to Poligraf i manage to put igo navi on the mrz03 by add it to apl and rename but the same problem with the gps. i hope if we can put external gps recivier on the unit to fix that?
Posted Dec 04, 2017 · 13:05 UTC#380
Можно поÑтавить вот такой gps модуль, Ñ Ð¸Ñ… иÑпользую лично Ð´Ð»Ñ Ð¿Ð¾Ð´ÐºÐ»ÑŽÑ‡ÐµÐ½Ð¸Ñ Ðº андроид приÑтавками GY-NEO6MV2 Ðовый NEO-6M GPS модуль NEO6MV2 Ñ Flight Управление EEPROM MWC APM2.5 большой антенны длÑ
http://s.aliexpress.com/jE7jqY3I
(from AliExpress Android)
RX и ТХ контакты у Ð½Ð°Ñ Ð¸Ð¼ÐµÑŽÑ‚ÑÑ Ð² разъёме Ipod 9 и 14 контакт. И авто определить Ñпутников впринцыпе должен подхватить его
Posted Dec 04, 2017 · 13:30 UTC#381
У Ð¼ÐµÐ½Ñ Ð´Ð°Ð¶Ðµ в наличие еÑть такие модули gps , но подключить и проверить пока не могу в ÑвÑзи Ñ Ð½ÐµÑ…Ð²Ð°Ñ‚ÐºÐ¾Ð¹ времени так как уехал в командировку .
КÑтати на данный момент у Ð¼ÐµÐ½Ñ Ñ‚Ð°ÐºÐ¾Ð¹ же модуль подключен Ð´Ð»Ñ Ð¾Ð¿Ñ€ÐµÐ´ÐµÐ»ÐµÐ½Ð¸Ñ Ñпутников
Posted Dec 04, 2017 · 14:50 UTC#382
Posted Dec 04, 2017 · 15:00 UTC#383
Ðо Ð´Ð»Ñ Ñтого в любом Ñлучае думаю надо будет пропиÑать путь команду в уÑтройÑтве к порту gps приемника.
Думаю нам Ñможет в Ñтом помочь тот кто хорошо разбираетÑÑ Ð² программировании
Posted Dec 04, 2017 · 15:55 UTC#384
Попробуйте таким же метододом уÑтановить Total commander
Posted Dec 04, 2017 · 17:45 UTC#385
ЗдравÑтвуйте. Пока не могу наÑтроить com port gps приемника. ПыталÑÑ Ð¿Ð¾Ð´Ñунуть вмеÑто файлы navi.exe- porttool.exe переименовав, запуÑкаетÑÑ Ð¼Ð°Ð³Ð½Ð¸Ñ‚Ð¾Ð»Ð° и виÑит заÑтавка "руку нави" и ничего не проиÑходит. Ð’ ручную. геморно перебирать порты и ÑкороÑть, надо Ñтавить porttool/ Похоже придетÑÑ Ñтавить тотал коммандер, да вот не могу найти проинÑталлированный, только иÑходники. Может еÑть у кого,  а то придетÑÑ ÐµÑ‰Ðµ wmware ce Ñтавить и в нем уÑтанавливать.
П.С. ЕÑть мыÑль, заменить Ñофтину av.exe ÐºÐ¾Ñ‚Ð¾Ñ€Ð°Ñ Ð¿Ñ€Ð¸Ð²Ñзана к кнопке av, дабы Ñменить Ð¸Ð½Ñ‚ÐµÑ€Ñ„ÐµÐ¹Ñ Ð¼Ð°Ð³Ð½Ð¸Ñ‚Ð¾Ð»Ñ‹, еÑть мыÑли подпихнуть avicnet...
Posted Dec 06, 2017 · 09:16 UTC#386
ЗдравÑтвуйте. Ñпешу поделитÑÑ Ñ€ÐµÐ·ÑƒÐ»ÑŒÑ‚Ð°Ñ‚Ð¾Ð¼ ÑкÑпериментов. ÐаÑчет Ñмены Ñзыка, вÑе получилоÑÑŒ заменой файла как опиÑывали Ñ Ñамом начале темы. Язык ÑменилÑÑ, меÑтами кривовато, но терпимо. Далее. Решил попробовать Ñменить оболочку навигашки, в папке prg1/apl удалил файл navi.exe и вмеÑто него Ñкопировал вÑе файлы от навитела, переименовав navitel.exe в navi.exe. Однако, еÑть проблемка, не могу наÑтроить com порт gps приемника. Ð’ данный момент уÑтановил навител 9.6, буду пробовать другие Ñборки.
Привет. Ð”Ð»Ñ ÐºÐ°ÐºÐ¾Ð³Ð¾ Ð²Ð¸Ð½Ð´Ð¾Ð²Ñ Ð±Ñ‹Ð» навител? СЕ 5? У Ð¼ÐµÐ½Ñ ÐµÑть навител 5 и Ñити гид Ð´Ð»Ñ Ð²Ð¸Ð½Ð´Ð¾Ð²Ñ Ð¡Ð•5.
Posted Dec 07, 2017 · 18:04 UTC#387
Windows ce 5/6
Posted Dec 07, 2017 · 18:17 UTC#388
дело не в СЕ5 или СЕ6, проблема в том что Ñпутников не видит, точнее навител не может определить к какому порту привÑзан gps у магнитоллы.
Edited Dec 07, 2017 by Ilnur
Posted Dec 07, 2017 · 20:43 UTC#389
when i run the igo on my mrz he cant find the gps but its getting my local time set. i thing navigation get to the right port but its lock by pioneer. wonder if we can get a developer test mode key then will be acces to more options
Posted Dec 08, 2017 · 09:38 UTC#390
Thank You DZO for your Help , i used the Zip file with key and replaced the scripts USB to SD and it works like charm on my MRZ99
now to another point, i read a lot of threads and tried many times playing any video on my MRZ99 using SD card but all failed.
does anyone know what video formats and audio settings should be done and what is the conversion software you are using  , any help please.
Edited Dec 08, 2017 by Bonanza
Posted Dec 09, 2017 · 20:59 UTC#391
Hi manio112,
I copied all files and directories of 'MapFactor NavigatorFree' Windows CE version to my MRZ02's USER\PRG1\APL (My Unit uses PRG1) folder, also changed the executable name 'Navigator.exe' to 'Navi.exe' but no way, it's not working.
I've found a Windows CE version of IGo, I copied all files and rename main executable as 'Navi.exe'. It's working but I have the same problem that device cannot locate GPS (meanwhile time is correct).
Questions are,
1. If it cannot locate GPS, where this correct time data comes?
2. If it is possible to run IGo, why MapFactor cannot be executed (both are Win CE version)?
Edited Dec 10, 2017 by adzaM
Posted Dec 15, 2017 · 08:10 UTC#392
Hi manio112,
Questions are,
Dear AdzaM, I have also tried Maplorer on my MRZ05 but it does not run at all. I do not have IGO, if you give me the link, I will download and try to get it to work.
Thanks and regards
Posted Dec 17, 2017 · 02:36 UTC#393
I've translated the Japanese language strings for the MRZ99 to English.
I figured out the format of the LNG file, dumped the Japanese, translated all the strings using google translate, then rebuilt the file.
Some of the English is not perfect but it makes the system much more usable.
I've tested it with APP firmware version 3.070200 (installed with platform version 3.000600), other versions may not work.
If the old language file is 93627 bytes long then this will almost certainly work.
To install this, unzip the attachment attachicon.gifmrz99english.zip and put the PF090JPJPN.LNG file on an sd card. (130905 bytes, md5sum is cb3f9cb76330704cc171e2b0acb9f6ad)
Get into testmode by holding the NAVI button (left button with Japanese writing on it) and pressing right..left..right..left..right..left and then release NAVI.
Go to the last entry on the first page (File Maintenance in Japanese) and press MENU (right button with Japanese writing on it)
This opens the file manager which is in English and fairly obvious.
Make a backup of /USER as described elsewhere on avic411.com
Look in /USER to see if there is a file named  PRG.FLG
if there is, then the system uses /USER/PRG1, otherwise it uses /USER/PRG0
You can check the file versions by looking at  /USER/PRGx/PF090APL.HTM (where x is 0 or 1 depending on PRG.FLG)
go to  /USER/PRGx/APL/LANGDATA/
delete  PF090JPJPN.LNG
go to /SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA where the old one was.
Switch off the power and when it restarts, it should be in English....
This worked for me but obviously is not 100% safe, be very careful in the file manager.
Update: There's now an installer that also changes the background and most of the important images with japanese text.
Find it here:
https://github.com/dzo/mrz99/releases
Hi DJO,
This was awesome now ive got an english stereo. I have got one more problem the bluetooth is not working it use to work but now theres an error message saying change the passkey of the machine any chance you can help me out.
Posted Dec 19, 2017 · 11:07 UTC#394
ПоздравлÑÑŽ Ñ ÑƒÐ´Ð°Ñ‡Ð½Ñ‹Ð¼ ÑкÑпериментом! У Ð¼ÐµÐ½Ñ Ñ‚Ð¾Ð¶Ðµ MRZ-90. То еÑть доÑтаточно поменÑть файл PF090JPJPN.LNG. ? И перезапуÑтить ÑиÑтему. Или нужно отÑоединить клейму аккумулÑтора?
Posted Dec 19, 2017 · 11:08 UTC#395
Posted Dec 19, 2017 · 14:19 UTC#396
Hello all my friend
I have pioneer Avic -F860BT iam looking for the test mode fichier
Can some one help me to unlock my radio code i talk me password
Thanks All
Posted Dec 20, 2017 · 06:52 UTC#397
you only need to replace the files. you do not need to remove the battery.
Posted Dec 21, 2017 · 10:55 UTC#398
Please share the link where you downloaded the IGO, I will try on my mrz05 and report back to you.
Posted Dec 21, 2017 · 10:56 UTC#399
Hello all my friend
Thanks All
try the method provided by DZO in earlier posts.
Posted Dec 21, 2017 · 11:09 UTC#400
Hi manio112,
Questions are,
the 'MapFactor NavigatorFree' which I could find, is a file which runs a complete setup on a windows phone and obviously one can not do this on a mrzxx. please inform from where you downloaded the MapFactor NavigatorFree and igo software, so that I can try and report back to you.
Page 16 of 39
