I also Navitel says "not registered version, download card of size up to 100 KB"
dear friend, I could not understand the meaning of "download card of size up to 100 KB"
Hi all of you here.
Those who write in Russian scripts are denying us of vital knowledge. Could they Please write in English for everyone to understand responses or suggestions and avoid asking same questions repeatedly. I had asked before if any one has figured out how to set local time. My unit is MRZ 09. It sets itself back to Janese time zone. Ours is GMT +3 zone. Any help in English will be appreciated.
see post no 380 on page no 26 and read the procedure by Ilnur.
Navitel I launched, the satellites can not see
Navitel - https://mega.nz/#F!IjIUnRqS!471FG5YRg9I4vaMn9ELVNw
Map earth - https://mega.nz/#F!sqpCyKTK!7mHWyZX6fRHoR3iYkpOuVA
It is necessary to determine the com-port number of the GPS and the optimal data exchange speed, our MRZ!
PortTool I did not start, but the total commander was launched.
Here's an english language file for the mrz09, I haven't tested it so let me know if it works.
The mrz09 is from 2011 and has a few extra strings.
Also worked a treat for me as well. I had through trial and error figured out what most controls did, but this is just so much easier having English. Thanks again all.
My MRZ09 is in English.
Hello All,
Can some one have solution for converting Japaneses into English for AVIC-MRZ099 . i have imported Honda vezel and all is in Japaneses. secondly what exactly this device functionality . if all together change it with other DVD system does it made difference to some of built in car functionality.
Any help in this regard will be highly appericated
Hello All,
To change language, use the procedure given by DZO in earlier posts.
Thank you Javed for your reply. i have gone through the all thread what i understand from post #93 the earlier describe procedure will not work on MRZ-099. thats why i am asking if there is any update on it .
secondly for entering in test mode i have no right left button on the device .
Thanks for support.
Thanks for support.
To enter test mode try the procedure given in post # 411.
thank you javed . but as per my limited understanding from post 411 it is evident that procedure is not successful for MRZ-099 . could any one confirm if they tried it on MRZ-099 and managed to change language successfully
highly obliged to your replies and support
thanks
Hi manio112,
I copied all files and directories of 'MapFactor NavigatorFree' Windows CE version to my MRZ02's USER\PRG1\APL (My Unit uses PRG1) folder, also changed the executable name 'Navigator.exe' to 'Navi.exe' but no way, it's not working.
I've found a Windows CE version of IGo, I copied all files and rename main executable as 'Navi.exe'. It's working but I have the same problem that device cannot locate GPS (meanwhile time is correct).
Questions are,
1. If it cannot locate GPS, where this correct time data comes?
2. If it is possible to run IGo, why MapFactor cannot be executed (both are Win CE version)?
I think igo find the gps port but its disconnected bay pioneer software
Hi manio112,
In one of your previous post, you wrote that you have maps for IGo (and total is 10Gig. so cannot share entire file) can you please send me (or share) the map of Cyprus (must be in East Europe region). Thanks in advance.
Answering your question, I assume that the entry in the service menu with full opportunities available with the test mod key. However, using a test mod with a script posted in the beginning of this topic I was very worried. The screen was infinitely in a loop to restart, then all went black. Luckily managed to remove the card and reboot the device without loss
for those who are trying to use navitel the following lines may be helpful.
Who does not connect with the satellites (in the open), ie Navigator is set to COM port and speed than COM1 and 57600 bps, it is necessary:
1. learn the number of COM-port and the optimal exchange rate port navigator. To do this, use. / Utilites / PortTool.exe or see hint below:
2. replace the file. / Navitel.exe to a desired folder. / exe_--
_-------- / COMX / or use on the PC ./Utilites/Patch_Navitel_N-COM_WinCE_v1.1.exe and ./Utilites/Patch_Navitel_Speed-COM_WinCE_v1.0.exe
Who does not start:
- If you record a program on the navigator or flashcards, pressing the button navigation, Navitel does not start, the browser settings must
choose the path run \ Navitel \ Navitel.exe. If there is no choice in the browser start the navigation path, you need to rename \ Navitel \ Navitel.exe on track. To determine the path used in the browser by default with the hint file. / Utilites / Executable path run the software in some navigatorah.pdf. Or using the utility on the PC to find / change the path in the registry WinCE navigator: ./Utilites/CeRegEdit_Setup_0.0.5.2.exe
hi javed akhtar did you manage to run the gps to get signal from satelites?for those who are trying to use navitel the following lines may be helpful.
Who does not start:
Я поделюÑÑŒ опытом по изменению Ñзыка на MRZ90. ПоÑле некоторых манипулÑций мне удалоÑÑŒ Ñменить Ñзык Ñ ÑпонÑкого на английÑкий и даже на кириллицу. ИÑходные данные были взÑты из Ñтой темы. Работа г-на ДЗО Ñделала большой и любознательный ум, заÑлуживающий ÑƒÐ²Ð°Ð¶ÐµÐ½Ð¸Ñ Ð¸ благодарноÑти. Ðо MRZ90 английÑкий и кириллица поднимаютÑÑ Ð¾Ñ‡ÐµÐ½ÑŒ, очень криво. За 2 года работы на ÑпонÑком Ñзыке Ñ Ð¿Ñ€Ð¸Ð²Ñ‹Ðº к перÑонажам, поÑтому вернулÑÑ Ð½Ð° ÑпонÑкий Ñзык, потому что варианты Ñ Ð½ÐµÐ¿Ñ€Ð°Ð²Ð¸Ð»ÑŒÐ½Ñ‹Ð¼ переводом мне нравÑÑ‚ÑÑ Ð³Ð¾Ñ€Ð°Ð·Ð´Ð¾ меньше. Лучше понÑть интуитивно, чем увидеть Ñкран, полный ерунды. Резюме: Ð´Ð»Ñ MRZ90 не подходит. Очень хорошо, что Ñ Ñмог Ñделать резервную копию. И даже Ñо вÑем Ñтим Ñ Ð±Ð»Ð°Ð³Ð¾Ð´Ð°Ñ€ÑŽ Ð¢ÐµÐ±Ñ Ð·Ð° опыт, который Ñ Ð¿Ñ€Ð¸Ð¾Ð±Ñ€ÐµÐ»
Take a look at the condi hackmode thread. I have explained there why you can't use the GPS port. It is already opened by "NPGPSENGINE.DLL" at the point when navi.exe is started and it cannot be opened twice. You either need the "Pioneerus" hack to get access to this port (ask forum user "Sanik") or you need to use an external GPS receiver as described in the condi hackmode thread.
Morus i read yours post and i alredy order the gps module so when i get it i will report if its working thanks for you help. also i try contakt with sanik but no reply from himTake a look at the condi hackmode thread. I have explained there why you can't use the GPS port. It is already opened by "NPGPSENGINE.DLL" at the point when navi.exe is started and it cannot be opened twice. You either need the "Pioneerus" hack to get access to this port (ask forum user "Sanik") or you need to use an external GPS receiver as described in the condi hackmode thread.
HI azdam this the link for maps sorry for delay
magnet:?xt=urn:btih:A78E621785235B71046D5732EA5EF314D406B3F3
Вот бы DZO разобралÑÑ Ð±Ñ‹ Ñ "NPGPSENGINE.DLL". ПожалуйÑта!
That would be DZO deal with "NPGPSENGINE.DLL". You are welcome!
On 18/11/2017 at 10:21 PM, EnoKt said:
I have Pioneer Carrozzeria AVIC MRZ 09. I simply used the automatic updater by DZO which changed most of the stuff from Japanese to English. See post # 59 by DZO. Download the zip file unzip into a flash disk (say 4 GB) , plug in the unit and the rest is installed automatically. Restart to see changes.
I wonder if there is anyone who has managed to set local time in this unit. It always sets itself to Japanese time zone.
I have corrozeria AVIC-MRZ77 is it compatible with aAVIC MRZ 09.
2 hours ago, Miltiades constanti said:I have corrozeria AVIC-MRZ77 is it compatible with aAVIC MRZ 09.
Hi,
May be Mr. DZO will clarify better the above query. Please see post by him on page 2 of these series...Posted December 30, 2016.
Hi! Please tell me how to reset the password when you turn on MRZ99
First to let everyone sure that i have read most of the messages.
I have MRZ05.. I have done and changed language manually. PERFECT!!
Please help...
Moreover, the clock does not work.. I am now working on it.
If someone managed to run map for Europe, please send me message..
MRZ05
I have problem with time as there is no display. I have done the same thing with the video posted but end up with gps problem.
I have problem with bluetooth. Does mrz05 has a built in bluetooth?
I have problem with image. Automatic updater corrects the language but not the image..
Please help..
Here is the pictures of screen..
