cheers kmjp!
AVIC-MRZ99 Custom Firmware / Testmode
hi all ive got an AVIC-MRZ90-2 just wondered if some1 could point me in the right direction of firmware to change it to english and or some firmware from another radio what will work properly as i cant seem to access all the settings options aswell as getting bluetooth and maps to work and help please as im stuck thanks
cheers kmjp!
I'm still waiting for it to come in the mail, but were you able to get updated Japan maps on it yet? That's my main concern, but if I can help extract the files for a translation I'm happy to try and get those.
Unfortunately not being able to copy and paste any files yet. Can't even find the language files! Hope you can find a way to solve the problem ![]()
Hi all, I'm new here. I have a 2012 Pioneer Avic mrz 009 in Japanese. I read all pages and this exactly what I wished! Conversion to English. I have tried to use all files here and i can't get to the test mode because this particular version doesn't have the navigation button, when i insert the SD Card with files it returns
CAUTION!
TEST MODE FAILED STARTING!
[Turn off ACC]
Dear DZO do you have any idea of how to get to the test mode of this particular model? I will glad for any help.
Thank you.
Anyone knows how to change the language on the Avic-mrz02 from Japanese to English?
Hello.
I have MRZ05. Have read all the posts and got to the stage where I have copied the file from the SD card but it does not allow me to paste it to the langdata folder.
The "paste" option is greyed out and cannot be selected.
Can anybody please advise ?
Thank you
Hello.
Thank you
before you copy you have to pres select then copy and navigate to langdata
Hello.
Thank you
Hi, thank you, ... yes I did that, it selects and a small + sign then copy. It still didnt allow the paste function though.
check the dzo youtube video for it i have to play with that long time before figure how to paste. but press select then move to copy then go to top of folder and before you press anything move to enter, then navigate to langdata but you have go straight there
ok thanks I will try. Do you have the link for the youtube ? Thanks
its on this post just go true pagese
Sorry that I am writing in this topic, but someone can tell me - series MRZ asks for code when the battery is disconnected? I need to take it off. Thanks.
Странно, ÑÐµÑ€Ð¸Ñ mrz обычно не запрашивает код Ð´Ð»Ñ Ñ€Ð°Ð·Ð±Ð»Ð¾ÐºÐ¸Ñ€Ð¾Ð²ÐºÐ¸. Сделай фото и выложи Ñюда, ну а мы поÑмотрим
У Ð¼ÐµÐ½Ñ Ð¸ не проÑит, Ñ Ð½Ð° будущее, надо аккум ÑнÑть. СпаÑибо за ответ.
Ðе переживай, можешь Ñмело Ñнимать аккумулÑтор, код не запроÑит
Dear DZO,
I have the same problem of inactive paste option. I have followed all the procedures , watched that youtube video of how to copy paste in test mode, but with no luck. I can copy your file from the SD,but whenever I change the directory, the paste option becomes inactive. I can only copy and paste in the same folder or directory.
Any help?
Ok atlast I have been able to paste but now arises a new problem. After pasting I'm not seeing the new lang file -_+
Anyone?
try again to make copy, then you should go user / prg 0, prg1 / apl / langdata and press paste, it should work. sorry for bad english
My version is mrz09. Should i delete the existing File pf090jpjpn.lng or pf110jpjpn.lng? And replace with new lang file to change japanese to english?
Hey just knocked to thank you all, for all of your insightful posts. I've done it ![]()
Any one figured out how to manipulate the navigation data like this language data file?
I have Pioneer Carrozzeria AVIC MRZ 09. I simply used the automatic updater by DZO which changed most of the stuff from Japanese to English. See post # 59 by DZO. Download the zip file unzip into a flash disk (say 4 GB) , plug in the unit and the rest is installed automatically. Restart to see changes.
I wonder if there is anyone who has managed to set local time in this unit. It always sets itself to Japanese time zone.
Ð’Ñ€ÐµÐ¼Ñ Ð¸ дату уÑтанавливать в 29 пункте, но Ð´Ð»Ñ Ñтого нужно отключить gps антенну и обеÑточить магнитоллу на 3-5 минут.
Hi Ilnur,
Can you give more details/video on how to change the timezone
