AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 12 of 39
Posted Oct 18, 2017 · 11:53 UTC#276
That's what the fixbmpheader.c code does, the mrz99 bitmap format is slightly different to the rgb565 gimp produces. If you run the modified bitmaps through fixbmpheader they should be the correct size.
не могу разобратьÑÑ ÐºÐ°Ðº работать Ñ  fixbmpheader.c
I can not understand how to work with fixbmpheader.c
Posted Oct 18, 2017 · 21:17 UTC#277
It's a C program that takes 2 parameters, the filename of an input bitmap and the filename for an output bitmap. Compile it and from a command line do:
b1853a should then be the correct size.
Posted Oct 18, 2017 · 23:22 UTC#278
ЗдравÑтвуйте. Как перевеÑти на РУССКИЙ Ñзык MRZ06? Где взÑть файлы Ð´Ð»Ñ Ð¼Ð¾ÐµÐ¹ магнитолы? HELP ME!!!
Posted Oct 19, 2017 · 01:09 UTC#279
Post #264 says this works on mrz06 so try it and see, make sure you backup the existing language files first.
Posted Oct 19, 2017 · 08:10 UTC#280
Does anybody know where we can find the MAP file on the MRZ?
I think that if we locate the map file, which is a map of Japan, somebody can edit that and transform it into map of Europe or country or whatever....
Otherwise i need to know how to install IGO or any other navigator on my MRZ 09.
Any ideas?
Posted Oct 19, 2017 · 09:28 UTC#281
Можно и Европу и РоÑÑии еÑли внедрить в mrz android
Posted Oct 19, 2017 · 09:43 UTC#282
Ðе получаетÑÑ, поÑле Ñтого файл не открываетÑÑ. Ðо Ñ Ð½Ð°ÑˆÐµÐ» онлайн конвертер, и выÑÑнил, что правильно конвертировать в 16 бит (5:5:5:1 Hi Color). ПолучаетÑÑ Ð²ÑÑ‘ Ñразу. Проверил.
It does not work, after that the file does not open. But I found an online converter, and found out that it's correct to convert to 16 bits (5: 5: 5: 1 Hi Color). It turns out all at once. Checked.
Posted Oct 19, 2017 · 12:12 UTC#283
ЗдравÑтвуйте. Ð¡ÐµÐ³Ð¾Ð´Ð½Ñ Ñделал backup папки USER Ñвоей MRZ06. ПыталÑÑ Ð¿ÐµÑ€ÐµÐ²ÐµÑти на английÑкий, но ничего не получилоÑÑŒ. Пробовал и в ручную и Ñкриптом, вÑÑ‘ равно ЯпонÑкий Ñзык. ПоÑмотрите пожалуйÑта мой backup, в чем может быть дело?
https://drive.google.com/open?id=0B4xXGSg6VKf0YUtCX0lZUTdNTlE
Posted Oct 21, 2017 · 06:30 UTC#284
Mr Dzo let me thank you for giving my radio MRZ0047 some life. I used the file that you shareon page 7 if am not wrong NA090jp....it worked on my radio that I posted in another forum as MRZ30047zy or nmdp-w59. There are few threads remaining with Japanese. The CD menu and other few.Do you have the final translation for this. Mine is build 06.
Posted Oct 21, 2017 · 06:47 UTC#285
It is version 1.000500
Posted Oct 24, 2017 · 12:38 UTC#286
Hi Mr. Dzo.
I am new in this forum, so bear with me.
My Pioneer Carrozzeria AVIC Mrz09 now reads mostly in English, after following the latest zip file except areas where the   Japanese GPS map is involved. One thing though: Is there a way of correcting time zone to +3 GMT. I am in East Africa. Is any able to do so anyway anyhow?. How about changing FM frequencies to read up to 108 Mhz.?
Many thanks to all of you here in advance.
Posted Oct 29, 2017 · 02:54 UTC#288
Дорогой Дзо!
Я дошел до Ñтого шага:
delete  PF090JPJPN.LNG
go to /SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA where the old one was.
Ðо Ñкопированный Ñ SD файл невозможно Ñделать PASTE в папку LANGDATA (не подÑвечиваетÑÑ PASTE)
Помогите пожалуйÑта
Posted Oct 29, 2017 · 03:12 UTC#289
Dear Dzo!
I reached this step for MRZ99:
"remove PF090JPJPN.LNG
go to / SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA, where was the old one. "
But copied from SD file it is impossible to make PASTE in the folder LANGDATA (not highlighted by PASTE)
help me please
Posted Oct 29, 2017 · 04:12 UTC#290
Dear Dzo!
help me please
Входит в ÑервиÑное меню Ñ Ð¿Ð¾Ð¼Ð¾Ñ‰ÑŒÑŽ testmode и Ñти иконки будут активными
Posted Oct 29, 2017 · 11:14 UTC#291
именно иконка paste не активна
Posted Oct 29, 2017 · 11:15 UTC#292
Posted Oct 29, 2017 · 11:17 UTC#293
Значит вы не правильно делаете copy
Posted Oct 29, 2017 · 19:51 UTC#294
Ñ Ð²Ñ‹Ð´ÐµÐ»ÑÑŽ файл на СД карте, делаю Ñелект, копирую, потом выхожу через меню  в LANGDATA, но уже там иконка паÑте - мёртваÑ
Posted Nov 01, 2017 · 08:51 UTC#295
Dear all,
I can fix MRZ 03,   MRZ 05, MRZ 07 and MRZ 09 as well as others to read ENGLISH instead of Japanese. Also I have a special antenna transformer that can allow the radio to reach all your FM stations for Europe. Further than that I also have the adapter for USB and JACK 3.5 mm etc. I also have maps for Europe which can be easily installed.
The language change is for free, so is the date /time settings.
However you will have to send me the unit and once I fix it I can return it to you.
Drop me a line in a Private Message here as I can not publish my email and I will come in touch with you either via Whatsapp or Viber so please add your number.
The antenna adaptor/converter costs about 20 euro, the adapter for USB and Jack 3.5 mm for your audio/phone is about 10 euro and the maps are between 12 to 20 euros depending on the country, full Europe is about 45. Shipping to Cyprus should not be more than 20 euros. I am NOT selling anything I do this as a hobby but the costs must be covered by you.
I hope this is not understood as an advert because I dont charge anything.
Best
Fanourio
Any ideas?
Dear Fanourio, in your post on 13 Sept 2017, you claimed that you have map change facility with you. And now on 19 Oct 2017 you are seeking advice to change map? Please explain.
Posted Nov 02, 2017 · 09:56 UTC#296
Although I dont feel that I have to explain ANYTHING it is very easy to delete any file from MRZ radios accidentally and never be able to retrieve that file..... before playing it James Bond, did you ever consider that instead of shooting stupid questions? Unlike your type, I am not any scammer as I do not ask for money and I think it was YOU looking for MY help! Well I have news for you my friend, you ARE NOT GETTING ANY! GET A LIFE!
Posted Nov 03, 2017 · 11:14 UTC#297
Dear Fanourio, You took me wrong. I did not want you make angry. I was not playing james bond. I did not shoot any stupid question. Please also consider that I waited for more than 40 days and did not receive your reply. However, your recent post made me surprised, that is why I asked.
Posted Nov 03, 2017 · 11:27 UTC#298
Hi all, I'm new here. I have a 2012 Pioneer avic zh77 in Japanese. I read all 21 pages and am blown away at the mods. Exactly what I wished! Conversion to English.
DZO pardon me if I am mistaken, do I back up the files to a SD card as per AVIC development mod forum then search and replace PF090JPJPN.LNG with your file?
I am not very savy with this mod and feared bricking my unit! I'm based in Auckland.
Posted Nov 03, 2017 · 19:38 UTC#299
I'm pretty sure the zh77 is completely different to the mrz77 so it very unlikely my language file will work. Try getting into test mode and post the langdata files here and I'll take a look at them. Don't replace anything though.
Posted Nov 03, 2017 · 22:55 UTC#300
hi dzo, thanks for your prompt response. I can't use the "test mode file" it "displyed "test mode fail, turn off acc" however pressing Navi and left right X3 got me into a test mode menu with 41 directories/modes - some in Japanese.
jpg of all the directories attached.
I panicked when I realised there is no escape/reset key to get to the main menu.! I turned of the power to reset. phew. Please advise if that was the correct procedure.
Once again thanks, I look forward to further instructions as to which directory to back up and how to proceed.
Page 12 of 39
