AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 23 of 39
Posted Jul 24, 2018 · 03:39 UTC#551
On 7/20/2018 at 7:49 AM, Jay8992 said:
How do you change back to Japanese? Which menu settings?
in navigation, you have the option of language, English or Japanese. But it only changes on the map, it does not change the language of menus.
Posted Jul 24, 2018 · 03:42 UTC#552
On 7/20/2018 at 1:10 AM, Jay8992 said:
where to find it?
Start reading from the very first page.
Posted Jul 24, 2018 · 03:51 UTC#553
On 7/21/2018 at 5:37 PM, Olivier said:
Hi everyone,p
has anyone managed to change the time on the mrz05?
I have used the generic testmode file that DZO posted here and managed to access the menu to set the dummy time.
However, when i try to save the time that I have set, I get a "failed" message
Does anyone knows what could be the cause?
Cheers
Please describe how you are tring to change the time? however, Mr Ilnur has given a method in earlier posts. According to him power off the unit, remove the gps antenna, wait for 20 minutes. power up, the unit will not be able to get gps time, now you can set the time manually. there is also a video link. I have not tried it, if you succeed share it here so that all of us can benefit. Another method can be to change the time zone and time will become accurate automatically, but how to change time zone, I do not know. Best of luck.
Edited Jul 27, 2018 by javed akhtar — Reason: some more info
Posted Jul 24, 2018 · 14:14 UTC#554
On 7/20/2018 at 2:05 PM, dzo said:
OK, Here's a first attempt at a translation for MRZ85. I can't test this so it may not work. Rename it to PF090JPJPN.LNG
PF090JPJPN_85ENG.LNG
Thanks DZO, will try and let you know if it works by saturday. Thank yu
Posted Jul 27, 2018 · 19:21 UTC#555
can anyone explain how to do this on a mrz-099?
Posted Jul 28, 2018 · 16:37 UTC#556
See the post by Marcdane on page 32.
Posted Jul 31, 2018 · 14:09 UTC#557
I tried the files but the translation again wasn't as accurate as expected. But again i realised that my MRZ85 is version 2.0 i think thats why the files may not be working. I just wish I could restore the original  Japanese language so that i use google translate but I deleted the file long time ago.Am sucked up
Posted Aug 01, 2018 · 19:58 UTC#558
Hello,
i downloaded autoupdater made by dzo, and tried to install it with mrz009 but there is nothing.... CAUTION TEST MODE FAILED STARTING, TURN OFF AC. i even dont know how to enter with this device in test mode.
any ideas?
Posted Aug 02, 2018 · 00:52 UTC#559
Thanks for the help. Was able to change the radio language to english even tho is not everything change.
What I want to know now is how to set the time for the clock. Help would be greatly appreciated. Thank you
Posted Aug 02, 2018 · 11:40 UTC#560
Posted Aug 02, 2018 · 20:15 UTC#561
On 22/12/2016 at 18:57, ak1947 said:
Hola
Acabo de cambiar mi MRZ09 a la versión en inglés. Estoy tan feliz de haberlo logrado.
Hay algunos pequeños ajustes necesarios, pero se ve muy bien sin embargo.
Me dejas saber cómo haré estos ajustes y los tendré disponibles aquí.
Gracias
Good afternoon, I have a problem.
I have in AVIC-MRZ09 in Japanese.
I am trying to use the automatic installer, but when turning on it does not recognize the USB input, how to make it boot?
Other pendrive recognizes without problems.
Posted Aug 03, 2018 · 00:59 UTC#562
On 2/11/2016 at 8:45 PM, dzo said:
I've translated the Japanese language strings for the MRZ99 to English.
I figured out the format of the LNG file, dumped the Japanese, translated all the strings using google translate, then rebuilt the file.
Some of the English is not perfect but it makes the system much more usable.
I've tested it with APP firmware version 3.070200 (installed with platform version 3.000600), other versions may not work.
If the old language file is 93627 bytes long then this will almost certainly work.
To install this, unzip the attachment mrz99english.zip and put the PF090JPJPN.LNG file on an sd card. (130905 bytes, md5sum is cb3f9cb76330704cc171e2b0acb9f6ad)
Get into testmode by holding the NAVI button (left button with Japanese writing on it) and pressing right..left..right..left..right..left and then release NAVI.
Go to the last entry on the first page (File Maintenance in Japanese) and press MENU (right button with Japanese writing on it)
This opens the file manager which is in English and fairly obvious.
Make a backup of /USER as described elsewhere on avic411.com
Look in /USER to see if there is a file named  PRG.FLG
if there is, then the system uses /USER/PRG1, otherwise it uses /USER/PRG0
You can check the file versions by looking at  /USER/PRGx/PF090APL.HTM (where x is 0 or 1 depending on PRG.FLG)
go to  /USER/PRGx/APL/LANGDATA/
delete  PF090JPJPN.LNG
go to /SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA where the old one was.
Switch off the power and when it restarts, it should be in English....
This worked for me but obviously is not 100% safe, be very careful in the file manager.
Update: There's now an installer that also changes the background and most of the important images with japanese text.
Find it here:
https://github.com/dzo/mrz99/releases
mrz99English_v2.zip
Thanks a million, I followed the instructions step by step and almost everything was in English now. only remains to see if you can load the maps and other things, we will see if I can do it. Thank you!! Regards from Paraguay!!
Posted Aug 03, 2018 · 06:20 UTC#563
If you are having problems, you can replace the two files manually, as described in earlier posts.
Posted Aug 03, 2018 · 06:26 UTC#564
If you read the earlier posts, you will find that many have tried to load the maps but all have faced some problems. you can also try to install igo, maplorer, mapfactor navigator, navegis or navitel etc. you should also share your experience and problems so that others can help you.
Posted Aug 03, 2018 · 06:56 UTC#565
@dzo my avic-mrz99 keeps turning on an off every couple seconds.. i tried your language fix and it worked thanks much but can you help??? i thinking it the firmware need reinstalling or some thing
Posted Aug 03, 2018 · 09:04 UTC#566
One thing you can try is to delete or create an empty file called "PRG.FLG" in /USER, this will swap to the other application firmware installation but it won't help if the problem is with the base OS. Also, if you start up the unit in engineering testmode, there are some tests it can run but you'll need google translate on your phone to navigate the menus.
Posted Aug 04, 2018 · 13:30 UTC#567
Hello. There was a problem with my carrozzeria mrz07. When i turn it on the morning - black screen and a line of Japanese in the center. And in the lower right corner is the number 06. Turned it off and turned it on again - after that the screen does not turn on at all, but it seems like it flashes black every 3 seconds approximately. The rear view camera also works, it also flashes. The panel opens if you press the button for a long time. The service mode does not enter. Until then, it was not turned on (no source selected), so I can not say whether it's playing or not. I know that the radio plays in the service mode. The case took place in the south, it was hot, could this happen from heating? Help please.
Edited Aug 10, 2018 by serg_nestor1985
Posted Aug 04, 2018 · 13:55 UTC#568
Sorry for text, it is Android.
Posted Aug 05, 2018 · 08:26 UTC#569
i also have the same problem  try to solved it but no success.no program it reads and on the rufht side corner  7 .try to copy user prg1 prg0 but can't  paste it,i.e not able to paste  USER.but NDATA successfully copy& pasted.please help
Edited Aug 05, 2018 by ishlevi
Posted Aug 05, 2018 · 09:08 UTC#570
Thanks. I got it fix by deleting all user data and clearing the ram. I was an option in the test mode.
How can I change the background?? If possible
Posted Aug 05, 2018 · 18:39 UTC#571
has anyone did it for carrozzeria avic zh0009?
my friend has it on japanese
Posted Aug 07, 2018 · 05:11 UTC#572
On 24.12.2017 at 14:04, CameronR said:
On 23.12.2017 at 06:16, ichanner said:
Я просто нашел эту страницу очень счастливой, чтобы увидеть, что сделали вы, ребята. У меня есть японский AVIC MRZ-009 Я надеялся, что это же устройство, что и MRZ09, но это не
У шахты нет левых и правых кнопок (см. Изображение ниже)
Я попытаюсь выяснить, как войти в тестовое меню без кнопок влево и вправо, но любая помощь будет оценена
Я ожидаю, что эта модель также позволит изменить язык.
Я в такой же ситуации. Ни один из ключей тестового режима не работает, и нажатие кнопки не приводит к тому, что MRZ009 переходит в тестовый режим!:грустный:
Если кто-то решил это, пожалуйста, поделитесь.
благодаря!
Кнопки Select, Copy, Paste, Delete не доступны, нужен на флешку файл testmode.key без него редактирование не будет доступно.
Buttons Select, Copy, Paste, Delete are not available, you need the file testmode.key without it there is no editing. I can not find the file, it does not fit from other models(((
Posted Aug 07, 2018 · 12:54 UTC#573
Tak zhe sdelal, no pishet turn off acc
Posted Aug 07, 2018 · 17:01 UTC#574
4 hours ago, buta said:
Testmode.key нужен для mrz009 от других моделей выходит сообщение ошибки. Где взять файл не знаю, уже перепробовал штук 30перепробывал.
Testmode.key is needed for mrz009 from other models an error message is output. Where to get the file I do not know, have already tried pieces 30properbyval
Posted Aug 10, 2018 · 17:11 UTC#575
Can someone suggest this is a problem in software or something with power?
It seems to me that the matter is in the food, since the rear view camera worked with this.
 And after disconnecting the radio from the power supply settings reset and the camera stopped working.
Page 23 of 39
