AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 21 of 39
Posted Apr 18, 2018 · 04:23 UTC#501
On 4/16/2018 at 10:54 PM, shadowman14 said:
could you please upload a new version (with the automatic installer) but for an SDcard? i don't know how to edit the script. please without your familly photo ;)
my model is mrz05.
thanks in advance
Backup your files first. download the zip. unzip all the files. open scriptexec.ini using notepad and change usb to sd and do as directed. If you are not comfortable with this, you can change the files manually. All this is clearly described in previous posts, you only need to read, understand and apply carefully.
Posted Apr 18, 2018 · 04:23 UTC#502
i did it manually.
i copied the 2 language files on the directories on mrz05 and works perfect. the automatic installer didn't work on my mrz05.
thanks a lot dzo and fanourio for the advice of choosing japan language on the navi menus.
is there a way to reduce brightness or turn off display during driving at night ????
Edited Apr 18, 2018 by shadowman14
Posted Apr 18, 2018 · 04:26 UTC#503
15 hours ago, SergVDK said:
Hello, dear friends.
First of all, I want to sincerely thank DZO for the excellent work. The materials were very useful in practice.
Now i have a big problem with my Carrozeria AVIC-MRZ99, which I can not solve on my own.
I put the English language on the instructions from DZO, read the entire forum branch, but did not find a solution anywhere.
I do not have a bluetooth operation, it does not configure and does not connect to devices.
In the settings menu, the system requires a password change, but all windows are inactive, and I do not know how to change it and make it work (photo in attachments).
As far as I understand, it can be done through the firmware, diagnostic menu or something like that.
It can be a replacement for the file responsible for the bluetooth password.
Nowhere in the settings did I manage to change the password and make BT work.
I'll be glad if you can help me at least somehow.
I hope for your responsiveness and sociability.
Приветствую, друзья.
У меня есть проблема с Carrozeria AVIC-MRZ99, которую я никак не могу решить самостоятельно.
Сначала хочу от всей души поблагодарить DZO за прекрасную работу. Материалы оказались очень полезными на практике.
Я поставил английский язык по инструкции от DZO, прочитал всю ветку, но нигде не нашёл решения своей проблемы.
У меня не работает Блютуз, не настраивается и не подключается к сторонним устройствам.
В меню настроек Bluetooth система требует "смены пароля", но все окна - неактивны, и я не знаю, как его поменять и заставить BT работать (фото во вложениях).
Насколько я понимаю, это можно сделать через программное обеспечение, прошивку, диагностическое меню или что-то подобное.
Может быть заменой файла, отвечающего за текущий пароль блютуза?
Нигде в настройках мне не удалось поменять пароль или сделать что-то другое, что бы заставить Bluetooth работать.
Буду рад, если Вы сможете мне хоть как-нибудь помочь.
Надеюсь на вашу отзывчивость и коммуникабельность.
you can try by putting the original files back, configure the blue tooth and then change the language back to english.
Posted Apr 18, 2018 · 07:49 UTC#504
3 hours ago, javed akhtar said:
вы можете попробовать, вернув исходные файлы, настроить синий зуб и затем изменить язык на английский.
Thank you for responding to my request.
I also thought about it, but, as my installer said, it was not working properly before I translated it into English.
I believe that the problem is not this, but still, I'll try.
Please tell me where you can take someone else's backup and try to resurrect my BT?
Posted Apr 19, 2018 · 04:00 UTC#505
23 hours ago, shadowman14 said:
i did it manually.
while in av mode, hold the av button and a menu will appear, here you can adjust brightness. You can turn off display by selecting aux input.
Posted Apr 19, 2018 · 06:37 UTC#506
i will try it. one more question, when i am listening to radio, the navi is on on the background and a japanese girl always speaking to me. is there any way to shutdown navi, or mute this crazy girl? i need my peace of mind when driving with my music
Posted Apr 19, 2018 · 10:14 UTC#507
In the settings menu, you can reduce the volume to zero of this "girl".
Posted Apr 19, 2018 · 12:11 UTC#508
job done! you are the best
Posted Apr 19, 2018 · 19:03 UTC#509
any idea, how to change the clock on mrz05? i found a video in the forum but the test mode menus are complete different
Posted Apr 20, 2018 · 08:05 UTC#510
The video and the nearby posts describe the procedure, try to do something similar and if you succeed inform all others so that everyone can benefit.
Posted Apr 20, 2018 · 21:09 UTC#511
yeah i saw the video, trying to compare it with my menus but no luck. also i can not read some related posts in here, maybe a problem with my fonts, so i missed maybe some useful details
Posted Apr 22, 2018 · 15:40 UTC#512
some posts are in russian, so you can copy and then google translate to read and get benefit.best of luck.
Posted Apr 22, 2018 · 16:44 UTC#513
this in not a recognized (yet) language!! that's why i suppose to be a font problem
Posted Apr 23, 2018 · 08:40 UTC#514
I think we should request the owner of this forum to have a look at this and solve the problem.
Posted Apr 25, 2018 · 12:28 UTC#515
On 18/04/2018 at 5:23 AM, shadowman14 said:
i did it manually.
you can turn of screen by hold navi or menu button for few seconds
Posted May 11, 2018 · 07:43 UTC#516
Hello everyone, forgive me for my English, translate through an interpreter.
I read the whole thread of messages. I have not faced one problem, but no answer. There is a delete button in the menu, but there is no button to copy. Maybe this is related to the firmware, how can I update or change the firmware version?
Posted May 12, 2018 · 08:58 UTC#517
You will have to first select the file to copy, then you can paste
Posted May 13, 2018 · 20:13 UTC#518
I assure you. I choose the file 100%, I can even delete it. Copy can not, does not work, no, not available. Can the old version of the program?
who has such a file? I deleted the file. Give your please."USER\PRG1\APL\MENU\Image.img"
Edited May 13, 2018 by barsyk
Posted May 14, 2018 · 04:13 UTC#519
you can copy this file from PRG0 folder, if not try the attached file
Image.img
Posted May 14, 2018 · 11:57 UTC#520
Hello.
There is mrz009.
How to in to the testmode to change the language.
Testmode.key from DZO is not suitable.
CAUTION!
TEST MODE FAILED STARTING!
[Turn off ACC]
Edited May 14, 2018 by ank0l0g
Posted May 15, 2018 · 11:45 UTC#521
Rus: Поставьте машину на ручной(ножной) тормоз. По русски ручник. Сигнал с ручника должен попадать на AVIC. Во время движения многие настройки запрещены. Так же, у Вас может быть электрическая проблема с сигналом от ручника до головного устройства.
Eng: Place the machine on the handbrake (foot) brake. The signal from the handbrake should fall on the AVIC. While driving, many settings are prohibited. Also, you may have an electrical problem with the signal from the handbrake to the head unit.
Edited May 15, 2018 by MarioFly — Reason: update
Posted May 15, 2018 · 11:59 UTC#522
1. Is it possible to change the language for AVIC-MRZ099?
2. How to switch to test mode, if there is no "left" and "right" button?
Posted May 15, 2018 · 19:47 UTC#523
I have a very serious problem! Deleted the folders PRG1 and PRG0, replaced the files of others PRG1 and PRG0 not my version. Now I have only the logo mazda and so on the circle. I can not get to the service menu "Left, right, left, right, left, right" menu does not work. Previously, it worked. The script does not work either. It turned out brick. What to do?:?:
Posted May 16, 2018 · 08:11 UTC#524
See the post on page 32 by marcdane.
Posted May 16, 2018 · 08:41 UTC#525
if you have mrz05 try these files. try to remove any usb, dvd and sd card. keep the button pressed while turning on the key switch and try left,right........Best of luck.
AIPI_Av.dll
AIPI_Common.dll
AIPI_Download.dll
AIPI_HMIManager.dll
AIPI_Navi.dll
AIPI_PServer.dll
AIPI_SvrAcc.dll
AIPI_Voice.dll
AplCommonLib.dll
AplLib.dll
Av.exe
AvVinCoreBase.dll
Download.exe
HMIManager.exe
ImageControlLib.dll
Guide.CHN
Guide.ENG
Guide.JPN
Guide.KOR
NA090JPDHT.LNG
NA090JPMZD.LNG
NA090JPNSN.LNG
NA090JPSBR.LNG
NA090JPSZK.LNG
PF090JPENG.LNG
PF090JPJPN.LNG
PF110JPENG.LNG
PF110JPJPN.LNG
PF110JPMEN.LNG
PF110JPMTB.LNG
Av.rff
Download.rff
HMIManager.rff
Image.img
Navi.rff
Navi.exe
NSControlLib.dll
NSLib.dll
PServer.exe
RenewalIFLib.dll
SvrAcc.exe
SvrAccLib.dll
SymbolLib.dll
TelLib.dll
Voice.exe
VoiceLib.dll
PF110BOT.PRG
PF110DTV.PRG
PF110DTD.DAT
DFHSMaruGothic.pgf
PF110APL.HTM
PF110APL.VER
PF110BOT.HTM
PF110BOT.VER
PF110DTD.HTM
PF110DTD.VER
PF110DTV.VER
PF110FNT.HTM
PF110FNT.VER
PF110PLT.HTM
PF110PLT.VER
PF110PLT.PRG
PF110RGD.PRG
A11K01KM.WAV
A22K01KM.WAV
MONO11KN.WAV
MONO22KN.WAV
Thumbs.db
OnesegCoreTest.exe
Attached Files (69)
📎 AIPI_Av.dll (76.0 KB)📎 AIPI_Common.dll (68.0 KB)📎 AIPI_Download.dll (32.5 KB)📎 AIPI_HMIManager.dll (136.0 KB)📎 AIPI_Navi.dll (91.5 KB)📎 AIPI_PServer.dll (49.5 KB)📎 AIPI_SvrAcc.dll (39.5 KB)📎 AIPI_Voice.dll (39.5 KB)📎 AplCommonLib.dll (606.5 KB)📎 AplLib.dll (626.5 KB)📎 Av.exe (2.20 MB)📎 AvVinCoreBase.dll (23.5 KB)📎 Download.exe (197.0 KB)📎 HMIManager.exe (690.5 KB)📎 ImageControlLib.dll (91.0 KB)📎 Guide.CHN (17.0 KB)📎 Guide.ENG (17.0 KB)📎 Guide.JPN (17.0 KB)📎 Guide.KOR (17.0 KB)📎 NA090JPDHT.LNG (91.5 KB)📎 NA090JPMZD.LNG (91.5 KB)📎 NA090JPNSN.LNG (92.0 KB)📎 NA090JPSBR.LNG (91.5 KB)📎 NA090JPSZK.LNG (91.5 KB)📎 PF090JPENG.LNG (96.7 KB)📎 PF090JPJPN.LNG (127.7 KB)📎 PF110JPENG.LNG (97.6 KB)📎 PF110JPJPN.LNG (127.7 KB)📎 PF110JPMEN.LNG (97.5 KB)📎 PF110JPMTB.LNG (95.7 KB)📎 Av.rff (348.7 KB)📎 Download.rff (48.8 KB)📎 HMIManager.rff (57.9 KB)📎 Image.img (14.85 MB)📎 Navi.rff (592.0 KB)📎 Navi.exe (8.48 MB)📎 NSControlLib.dll (859.5 KB)📎 NSLib.dll (748.5 KB)📎 PServer.exe (839.0 KB)📎 RenewalIFLib.dll (160.0 KB)📎 SvrAcc.exe (78.0 KB)📎 SvrAccLib.dll (72.0 KB)📎 SymbolLib.dll (59.5 KB)📎 TelLib.dll (19.5 KB)📎 Voice.exe (150.5 KB)📎 VoiceLib.dll (165.5 KB)📎 PF110BOT.PRG (192.0 KB)📎 PF110DTV.PRG (6.61 MB)📎 PF110DTD.DAT (3.4 KB)📎 DFHSMaruGothic.pgf (7.20 MB)📎 PF110APL.HTM (335 B)📎 PF110APL.VER (3.3 KB)📎 PF110BOT.HTM (404 B)📎 PF110BOT.VER (192 B)📎 PF110DTD.HTM (314 B)📎 PF110DTD.VER (192 B)📎 PF110DTV.VER (192 B)📎 PF110FNT.HTM (334 B)📎 PF110FNT.VER (192 B)📎 PF110PLT.HTM (404 B)📎 PF110PLT.VER (1.2 KB)📎 PF110PLT.PRG (29.63 MB)📎 PF110RGD.PRG (497.0 KB)📎 A11K01KM.WAV (163.8 KB)📎 A22K01KM.WAV (325.6 KB)📎 MONO11KN.WAV (223.3 KB)📎 MONO22KN.WAV (451.6 KB)📎 Thumbs.db (5.0 KB)📎 OnesegCoreTest.exe (79.5 KB)
Page 21 of 39
