AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 22 of 39
Posted May 19, 2018 · 23:52 UTC#526
On 5/16/2018 at 7:47 AM, barsyk said:
I have a very serious problem! Deleted the folders PRG1 and PRG0, replaced the files of others PRG1 and PRG0 not my version. Now I have only the logo mazda and so on the circle. I can not get to the service menu "Left, right, left, right, left, right" menu does not work. Previously, it worked. The script does not work either. It turned out brick. What to do?:?:
Put this testmode key onto a usb stick or sd card:
TESTMODE.KEY
And switch on the unit.
If this doesn't bring up testmode then there is nothing much you can do.
If it gets you into testmode, then you will need to find somebody else with the same model as yours and copy their PRG0 folder.
You should never have deleted the PRG folders
Posted May 21, 2018 · 12:00 UTC#527
TESTMODE.KEY
you can run a script that will copy the files from the USB stick to the device. But first, as you said, you need to find the original files.
(I'm not sure about syntax.) ScriptExec.ini :
COLOR 48
ECHO
ECHO  Recovery files
ECHO
SLEEP 3000
ERROR OFF
ECHO ON
COPY -c USB\PRG1 USER\PRG1\
COPY -c USB\PRG0 USER\PRG0\
COLOR 21
ECHO
ECHO
ECHO  Done
ECHO
ECHO
ECHO
SLEEP 5000
RESET
ECHO RESET
RESET 1
Posted May 22, 2018 · 08:57 UTC#528
Dear dzo please find some time for me.
I have a Pioneer Carrozzeria AVIC-ZH0009cs.
Can you help me translate into English?
The fact is that in the folder
NX168 \ PRG0 \ APL \ Resource \ LANGDATA
no files with the .LNG extension
Tell me please where else can you search phrases and words in Japanese for translation?
Here is my NX168  folder.
Sorry for my English, I use a translator.
Edited May 22, 2018 by pppoe1
Posted May 28, 2018 · 08:47 UTC#529
Dear All ,
I have a problem to change the language from Japanese to English on my AVIC-MRZ07
my AVIC-MRZ07 firmware running PLT version 1.000000.
I"d tried as DZO instruction post , and then solved manually but there was no change language to English.
So,Pls, tell me that How can I do for my problem.
Ps; And can I update my PLT version 1.000000 ?
Can Anyone help me... pls;
Posted May 28, 2018 · 10:38 UTC#530
kan, I don't quite understand what you were doing.
Posted May 28, 2018 · 12:34 UTC#531
MarioFly,
Im trying to change the japanese to english on avic-mrz07.
Posted May 29, 2018 · 03:25 UTC#532
14 hours ago, kan said:
MarioFly,
If you have replaced the files in both prg0 and prg1 folder then language will change to english. If not perhaps you have selected english from manu, try selecting japanese.
Posted May 29, 2018 · 09:48 UTC#533
Hello. Can someone share the files PRG0 and PRG1 for mrz07? I already wrote that I do not save the settings. Maybe it's all about the files.
Posted May 29, 2018 · 11:43 UTC#534
Now i got it , as you said that I changed back to japanese in menu setting.
Big thanks ,
Posted Jun 23, 2018 · 18:20 UTC#535
Posted Jul 02, 2018 · 09:24 UTC#536
On 11/3/2016 at 2:45 AM, dzo said:
I've translated the Japanese language strings for the MRZ99 to English.
I figured out the format of the LNG file, dumped the Japanese, translated all the strings using google translate, then rebuilt the file.
Some of the English is not perfect but it makes the system much more usable.
I've tested it with APP firmware version 3.070200 (installed with platform version 3.000600), other versions may not work.
If the old language file is 93627 bytes long then this will almost certainly work.
To install this, unzip the attachment mrz99english.zip and put the PF090JPJPN.LNG file on an sd card. (130905 bytes, md5sum is cb3f9cb76330704cc171e2b0acb9f6ad)
Get into testmode by holding the NAVI button (left button with Japanese writing on it) and pressing right..left..right..left..right..left and then release NAVI.
Go to the last entry on the first page (File Maintenance in Japanese) and press MENU (right button with Japanese writing on it)
This opens the file manager which is in English and fairly obvious.
Make a backup of /USER as described elsewhere on avic411.com
Look in /USER to see if there is a file named  PRG.FLG
if there is, then the system uses /USER/PRG1, otherwise it uses /USER/PRG0
You can check the file versions by looking at  /USER/PRGx/PF090APL.HTM (where x is 0 or 1 depending on PRG.FLG)
go to  /USER/PRGx/APL/LANGDATA/
delete  PF090JPJPN.LNG
go to /SD, copy the new PF090JPJPN.LNG and paste it into LANGDATA where the old one was.
Switch off the power and when it restarts, it should be in English....
This worked for me but obviously is not 100% safe, be very careful in the file manager.
Update: There's now an installer that also changes the background and most of the important images with japanese text.
Find it here:
https://github.com/dzo/mrz99/releases
mrz99English_v2.zip
Hello DZO,
Thanks for the good work you are doing.
I have MRZ 85 and I have tried to change  the language from Japanese to English using MRZ 99 you shared herein. The only problem am experiencing is that the English is not that good and also misleading information from the translated texts. I therefore kindly request you to share with me the specific one for MRZ85 if you wont mind.
Thank you.
Posted Jul 02, 2018 · 22:27 UTC#537
13 hours ago, Mwassaru said:
Hello DZO,
Thank you.
If you post your old PF090JPJPN.LNG file here, I'll see if it's similar to one of the other models or make a new translation.
If you don't have the old file, use one of the others, e.g. PF090JPENG.LNG
Posted Jul 05, 2018 · 12:32 UTC#538
Thanks DZO, bad thing is that I did not do backup for the original LNG in my MicroSD. Could there be a rather similar or close to similar model of MRZ 85 ?
Posted Jul 05, 2018 · 23:06 UTC#539
There will probably be other language files, e.g. PF090JPENG.LNG, just copy one of these over  PF090JPJPN.LNG.
Posted Jul 08, 2018 · 08:50 UTC#540
Hey @dzo
Do you have any way to translate mrz009 into English.
it will be a big help.
Posted Jul 09, 2018 · 02:26 UTC#541
I have a pioneer carrozzeria avic-mrz05... Is there a way to set the language to english???
Posted Jul 09, 2018 · 02:28 UTC#542
@dzo I have a pioneer carrozzeria avic-mrz05... Is there a way to set the language to english???
Posted Jul 09, 2018 · 03:53 UTC#543
Many have already changed to english. please read and follow the instructions in this thread.
Posted Jul 09, 2018 · 13:32 UTC#544
Hi DZO,
Attached is the LNG file available in LANGDATA folder. Please let me know if from it you can make English translation for my MRZ85. Please not that after the MRZ99 LNG file you shared earlier refused to work accurately, I also deleted it and currently am only seeing blank boxes for the headunit since there is no language attached..
PF090JPENG[1].LNG
Posted Jul 11, 2018 · 08:20 UTC#545
Hello,
I would like to ask whether someone found the solution for the navigation of Europe (including Cyprus maps) ?? I am currently having AVIC MRZ06 radio.
Posted Jul 19, 2018 · 20:10 UTC#546
where to find it?
Posted Jul 19, 2018 · 22:11 UTC#547
Find it here:
mrz99English_v2.zip
what's the procedure to install the updates from the link you provided at the end? i have a mrz05
Posted Jul 20, 2018 · 02:49 UTC#548
Big thanks ,
How do you change back to Japanese? Which menu settings?
Posted Jul 20, 2018 · 11:05 UTC#549
On 7/10/2018 at 1:32 AM, Mwassaru said:
Hi DZO,
PF090JPENG[1].LNG
OK, Here's a first attempt at a translation for MRZ85. I can't test this so it may not work. Rename it to PF090JPJPN.LNG
PF090JPJPN_85ENG.LNG
Posted Jul 21, 2018 · 12:37 UTC#550
Hi everyone,
has anyone managed to change the time on the mrz05?
I have used the generic testmode file that DZO posted here and managed to access the menu to set the dummy time.
However, when i try to save the time that I have set, I get a "failed" message
Does anyone knows what could be the cause?
Cheers
Page 22 of 39
