AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 38 of 39
Posted Oct 11, 2022 · 10:43 UTC#926
Thank's. TESTMODE.KEY working with RZ99.
Posted Oct 17, 2022 · 20:51 UTC#927
Hi everyone, in the link below is a folder will all the different testmode modes.
FOR THE MODELS RZ09 AND SIMILAR
CCUNITTEST - from what i remember this mode only has two test options.
SERVICE - normal without copy and paste function.
TECHNICAL - allows copy and paste function along with a bunch of different tests
PRODUCT AUTO
PRODUCT MANUAL
FLEXIBLE - allows you to have your own testmode tests in a file called TESTMENU.ini - i'm not sure on how to actually get the tests into the menu. but maybe i might be able to unlock the internal sd card. im not sure yet.
SCRIPT - runs in parallel with ScriptExec.ini.
still trying to figure out what the DIRECT mode is.
but here is the link below. have fun and report any discoveries with any one of these keys.
**EDIT
SCRIPT MODE DOES NOT WORK!
https://mega.nz/folder/M6InCDqB#4EC_3QArPVqx4m9UPPJxLQ
Edited Oct 18, 2022 by Jet1337x
Posted Nov 14, 2022 · 22:52 UTC#928
On 5/26/2022 at 5:05 PM, Mikehy55 said:
HI ,just joined  and very impressed with the quality of questions and answers . Well I'm about to lower the quality .
Just purchased a japanese import car which has a Carrozzeria AVIC-HRZ099 head unit . I've tried to understand the protocol , as it is all in japanese ,using Google translate on my smart phone but cannot see how to access the HDD.Any help their will be very much appreciated.
Also ,I've downloaded the manuals for this and managed to translate some of the pdf files using Google translate again ,but the main files are greater than 10Mb  and google doesn't want to know .tried to split the files (unsuccesful) ,again any suggestion or help will be appreciated .
Hope I've posted this in the correct subject , Cheers
Hi, any luck with the HRZ 099 one? Can you share translated file?
Thanks.
Posted Feb 03, 2023 · 05:34 UTC#929
2 Jet1337x
Thanks bro! I'll check today!
it's bad of course that scripts don't work
Edited Feb 22, 2023 by crash_rider
Posted Feb 03, 2023 · 12:51 UTC#930
Everything works except scripts
copy paste available!
thnks!
Posted Feb 14, 2023 · 13:48 UTC#931
thnks!
Nor my SD neitehr my USB are recognized although formatted in FAT32 under windows, any suggestions?
Posted Feb 21, 2023 · 02:05 UTC#932
Скрипт работает  Pioneer Carrozzeria RL09
Edited Feb 21, 2023 by Ersh_v
Posted Feb 21, 2023 · 02:27 UTC#933
On 08.10.2022 at 22:44, Jet1337x said:
РЕБЯТА Я РАЗБИЛ PIONEER RZ09 TESTMODE.KEY, МНЕ УДАЛОСЬ РАЗБЛОКИРОВАТЬ ТЕХНИЧЕСКИЙ РЕЖИМ НА ЭТОМ УСТРОЙСТВЕ. ВОТ ССЫЛКА НА КЛЮЧ!!!!!
это может работать для rz05, я думаю!!
https://mega.nz/folder/Fv5FAAxQ#myf0v8DsHwmo_ZHWNkW65A
ДАЙТЕ МНЕ ЗНАТЬ, ЕСЛИ ЭТО РАБОТАЕТ ДЛЯ ВАС!!
Работает RL09
Posted Feb 21, 2023 · 03:31 UTC#934
Works RL09
tell me what files to replace in the firmware to get english
Posted Feb 22, 2023 · 03:11 UTC#935
2 Ersh_v
How did you check? which script was running?
Как проверил? какой запускал script?
Posted Feb 22, 2023 · 03:12 UTC#936
2 amgpuma
Try sdcard!
Posted Feb 22, 2023 · 04:23 UTC#937
1 hour ago, crash_rider said:
2  Ерш_в
Как вы проверяли? какой скрипт работал?
Как заразился? какой запускал скрипт?
I probably didn’t say correctly))) the copy and paste buttons work
Posted Mar 06, 2023 · 00:39 UTC#938
del
Edited Apr 25, 2023 by crash_rider
Posted Mar 06, 2023 · 23:11 UTC#939
Translated into Russian!
Posted Mar 11, 2023 · 07:17 UTC#940
On 3/6/2023 at 5:39 AM, crash_rider said:
Pioneer restorator
Reading files
*.ver ,*.prg ,*.iarc, *.dat (initdb.dat partially)
*.ver files
auto size check, crc files
auto recalculation of cs and file sizes
*.iarc files
full unpacking with restoration of original paths and file names
replacing the image to fit or smaller than the original size (for now)
*.prg files
auto size check, crc file and header
auto recalculation of cs and sizes in file and header
support for JP and EU versions
Generating nb0 and hdr files
nb0 for subsequent unpacking in utilities
hdr to restore the prg file with subsequent recalculation of cs and sizes (selects nb0 and the hdr file (Created automatically when opening PRG) with the same name as PRG should be)
p.s.
Example
In the settings, you can specify the disk where to collect the firmware, followed by editing all CRCs and sizes
For example, in the ini file CopyAllTo=F:\ everything will be collected on disk F and files will be prepared
1. Open PRG, nb0 and HDR files are formed (the files must all be in the same folder)
2.Editing nb0.
3. Select our edited nb0, and wait for the program to create everything itself!
It turns out the finished firmware on the disk
what models does it fit?
Posted Mar 12, 2023 · 01:56 UTC#941
RZ-RW-RQ-ZH
Posted Mar 26, 2023 · 08:55 UTC#942
hello i have avicmrz05 i have connected it to the car and i got an error like this.
 then I copied the files uploaded to the site for mrz99 as in the video.
I deleted the original mrz05 files, after copying the mrz99 files,
I got the error number 7 and the tape does not open at all, can you help?
Edited Mar 26, 2023 by ONURARD
Posted Mar 26, 2023 · 22:12 UTC#943
2 ONURARD
You deleted system files, system file load error (6-7-8), restore files from copy!
Posted Mar 27, 2023 · 04:34 UTC#944
On 3/12/2023 at 6:56 AM, crash_rider said:
RZ-RW-RQ-ZH
is there a video on how to do it?
Posted Mar 30, 2023 · 18:59 UTC#945
On 3/27/2023 at 1:12 AM, crash_rider said:
2 ONURARD
how ? where is the files ? because i didn't get a backup
Posted Mar 30, 2023 · 19:00 UTC#946
+1
Posted Apr 06, 2023 · 09:45 UTC#947
2 ONURARD
Try firmware from other MRZ series...
Go to the engineering menu and copy / paste the firmware files to the PRG0 folder.
Video how to do it? hah......
Lots and lots of time in 010 editor and you'll make another language :)
And all this with my own hands
that's all
Screenshots on dev
https://www.youtube.com/@Prochivka_na_mafon/featured
Edited Apr 06, 2023 by crash_rider
Posted Apr 08, 2023 · 16:04 UTC#948
On 4/6/2023 at 12:45 PM, crash_rider said:
2 ONURARD
that's all
Screenshots on dev
i try mrz07 files but not working. now problem code 7
Posted Apr 11, 2023 · 05:16 UTC#949
On 4/6/2023 at 2:45 PM, crash_rider said:
2 ONURARD
that's all
Screenshots on dev
Если решите когда нибудь поделиться файлами перевода то дайте знать)
Posted Apr 25, 2023 · 01:00 UTC#950
I suspended this activity as it is futile!
There are no people who want to change the language on their devices.
Let them continue to travel with the Japanese language!
Я приостановил эту деятельность так как это бесперспективно!
Нет желающих переделать язык на своих аппаратах.
Пусть и дальше ездят с японским языком!
Page 38 of 39
