New Z2 "bypass/back door" something to check
By ducatiboy · Apr 21, 2007in Hacks/Mods💬 88 posts👁️ 21,815 views
Page 4 of 4
Posted Apr 26, 2007 · 23:43 UTC#76
My idea is to wait for a true bypass...that will work regardless...
those of you that have this working.. please dont take any offence
Posted Apr 27, 2007 · 01:55 UTC#77
it only worked for me for about 5 miles before i got the error. the wierd thing with mine is even when i hit the reset button, my status screen still shows "3d hybrid", it doesnt reset. i lose all presets and stuff, but the speed pulse is still a really high number (cut my VSS so its not incrementing any more though) and the status doesnt reset.
Posted Apr 27, 2007 · 03:25 UTC#78
Well, for the last post...clear all 3 options under 3D calibration (click each one separately) and also click restore all defaults then reset and that should do it. As far as my bypass, I'm at 250 miles with no probs but it certainly now sounds for sure mine will go out. What the heck is this thing looking for at random distances, times, speeds? One thing is definite. This unit was made to watch video and NAV without going out regardless of the forementioned items. Every unit is designed to work in park, with ebrake, no GPS, no VSS signal, and now no int. gyro input. How can one replicate these while driving without triggering the system? It's seeming utterly impossible somehow with such random findings. The EDDC driver must be looking for changes in the GPS and int. gyros and random times, speeds, etc. If it detects an illegal value like ebrake on and GPS moving it shuts off....but why so random from vehicle to vehicle. It obviously isn't designed to check once, but continue monitoring as long as the unit is on. The int gyros are prob involved to detect an illegal value as well. As mentioned, if its analog to digital it could be highly variable. Or, another possibility, the EDDC doesn't always report to shut off video until you get X number of illegal checks. Whatever, it seems you can't win unless you shut off the GPS and who knows maybe even then the gyros would still cause problems.
Got to have a perm software or diff hardware mod it so 99% seems. Until then, I'll just reset my unit when I have too. :)
Posted Apr 27, 2007 · 14:54 UTC#79
If you restore defaults, does it erase the HD library of added music?
Thats the only thing I have not done to try and get the video to work for more than 20 miles
Posted Apr 27, 2007 · 18:24 UTC#80
Timvan,
It won't erase the stored music or at least it hasn't for me the 1 or 2 times I reset it. Check this post by Shooter. Interesting......to say the least. Works like mine. I wonder how far he's tested it and the unit has calibrated and what accessories he has. Is he mentioning anything different than what others have tried...like disconnecting the reverse wire? Could a metal wire connection to the unit cut (like the VSS) cause the video outage? Hmmm...the more people post success/failures the more likely a hardware fix while others smarter than me work on the software end. There is a fix...........so close yet so far.
http://www.avic411.com/forum/viewtopic. ... d8d34541b1
Posted Apr 27, 2007 · 18:43 UTC#81
Beachdoc
I read that by shooter.. I hope it works ...
I would think that the unit should/would be able to return to original though
Posted Apr 30, 2007 · 18:58 UTC#82
tried and spent 3 1/2 hours. it worked untill i slowed down to 5 mph and went back to oem message. please help have pissed off customer. thanks mark
Posted Apr 30, 2007 · 22:56 UTC#83
Maybe you should explain the way it works before you sell it. That way they either wait for the bypass or they don't buy it.
Posted May 02, 2007 · 00:42 UTC#84
My unit now repeatedly flashes the illegal parking brake connected screen after 350 miles :( Ok let's get this thing fixed! Let's change the code, files, or whatever. I'm in for the long haul.
Posted May 02, 2007 · 02:08 UTC#85
All good things must come to an end...... ya my z2 was bypassed for about 350 miles and sure shit I got the parking brake error, so I will have to reset mine tomorrow, sounds like in some of the other forums they are comparing the z1 and z2 hardrives so hopefully we will figure something out soon
Posted May 03, 2007 · 20:32 UTC#86
So not so sure whats going on here but just thought I would inform you guys, at 350 miles it gave me the parking brake error, because I started my car without my switch grounded, well I have not reset the unit since I bought it, but now if I turn my car off with the brake grounded and start it with it on, the unit is bypassed, so basicly I never have to touch anything, I dunno if its a fluke or what but im over 950 miles and it's still bypassed I just leave the brake grounded...... any questions about anything im glad to help, although I dont know much........
Posted May 04, 2007 · 00:40 UTC#87
im sorry guy but i personally think the whole back door hack is a fluke because it only seems to work on 50% of the people here on this forum
Posted May 04, 2007 · 01:19 UTC#88
It's way less than 50%, I think there are only 2 people that have been successful with this trick. I suppose it could be a glitch or something, or there is something about the trick that isn't being described properly. It almost seems that in the procedure that was described, no one knows exactly what triggers the system to work this way.
Page 4 of 4
