2015 Avic Z120 map update
By kellinaradway · Oct 03, 2015in Hacks/Mods💬 256 posts👁️ 81,230 views
Page 2 of 11
Posted Oct 20, 2015 · 23:42 UTC#27
Hmm...Now if I turn on the car it says "No SD Card.  Insert SD card to continue"  black screen.  Any idea how to get out of this mode?
Posted Oct 20, 2015 · 23:54 UTC#28
Oh craps....Unplug the neg battery doesn't do anything.  I'm stuck in the "No SD card available.  Insert SD card to continue".     Help!!!
Posted Oct 21, 2015 · 00:11 UTC#29
Okay...found this thread by Pionara which rescued my a$$.  I'm going to post a link here in case someone get into the same craps I just did...
http://avic411.com/index.php?/topic/35109-avic-f10bt-99-installed-wrong-sd-card-insert-right-sd/&do=findComment&comment=258286
Anyways, I think I have enough fun for today and I'm going to hang back for awhile.  I almost $hit a brick a few minutes ago when I couldn't get out of that "No SD card..." issue..  Whew!!!
Posted Oct 21, 2015 · 18:06 UTC#31
Yes. I used the cardinfo file from that thread and it let me update. However when you say " yes, update" it'll say "Incorrect SD card...etc" and will get stuck. There is a thread I posted up on top to "un-stuck" yourself. But again why would you want to go through it again if you knew it won't work.
Edited Oct 21, 2015 by randomwalk101
Posted Oct 21, 2015 · 18:52 UTC#32
I am presumming we have to have the 2013 cardinfo.cif to get the radio into the update mode.
So what I am seeing is the Z130bt (the unit I have) has a 2015 map part number of T1000-23348 from here : http://www.navigation.com/is-bin/intershop.static/WFS/Navteq-Site/Navteq/en_GB/documents/Pioneer/Pioneer%2011-12%20High%202015%20Manual%20T1000-23348.pdf
When I go into Alldata.htm within the update folder I see part number T1000-23346
Is there any kind of checking prior to the update?
I am thinking the radio goes into update mode, the update is verified and that's where the hang up is. Is there any type of log to view the update failure?
Posted Oct 21, 2015 · 19:09 UTC#33
I think verinfo.dat needs to be changed out. Can anyone elaborate on what this file does?
Posted Oct 21, 2015 · 20:01 UTC#34
Yes. The verinfo was taken from the 2015 Europe map thread (made by Pionara??). I'm not sure what it does...perhaps someone with more knowledge in this area can help.
Posted Oct 22, 2015 · 18:10 UTC#35
For Z130, Z140, and Z150 head units:  You need the 2015 CARDINFO.CIF and the 2015 VERINFO.DAT file. Maybe someone from you EU forum would be willing to upload the files.
Posted Oct 23, 2015 · 12:54 UTC#36
I agree jfwalsh!
Posted Oct 23, 2015 · 22:14 UTC#37
Anyone else having issues not being able to control your ipod with the head unit and bluetooth audio not working after applying this update?
Posted Oct 24, 2015 · 00:12 UTC#38
What version Bluetooth are you running?
Posted Oct 25, 2015 · 00:38 UTC#39
3.32
Posted Oct 25, 2015 · 01:40 UTC#40
3.32
That's the latest update, not sure why your having problems.
Posted Oct 25, 2015 · 04:59 UTC#41
I don't know why either so I downgraded back to the 2013 update and everything was working as it should.
I redownloaded the 2015 map update package and reapplied it and I had the same issues.
Posted Oct 25, 2015 · 12:50 UTC#42
I ran a binary file comparison of all BT FIRMWARE files between the 2013 map upgrade, 2013 (5.1) update, and 2015 map upgrade. They are all identical. SO whatever problem you are having has nothing to do with the 2015 FIRMWARE (BT).
Edited Feb 15, 2017 by RonS
Posted Oct 25, 2015 · 13:06 UTC#43
I have an iPod wired and have no problems. Are you trying to use BT? That will prevent some things from working since Apple doesn't support the Audio/Video Remote Control Protocol (AVRCP). For example Aha and Pandora must use the cable for iPhone/iPod.
There have been several people (myself included) who have had BT audio problems with Android v5 & 6 and AVIC BT 3.32. Falling back to the 2012 FIRMWARE seemed to fix some of those issues.
I found my problems go away if I am on some other (non-BT) audio source when the AVIC boots and starts playing. Then, after I see the BT connection message, I switch to the BT source (such as Pandora). But that is with my Android phone. Don't know if iStuff has the same issue.
Posted Oct 25, 2015 · 14:22 UTC#44
The F Series (Europe) guys posted their CardInfo mods to make it work with older models. I guess whoever contributed their 2015 update had bought the version for the newer models such as AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT). So their CardInfo mod was to support older ones like For those with Avic F10BT, F20BT or F920Bt.
I wish I understood more about the format of Cardinfo. Long ago pionara was doing some reverse-engineering and documented the internal hardware model labels that are used within CardInfo . Here is an abbreviated list of what he found:
  • X07UNC (Z110BT)
  • X05EUR (F310BT)
  • X05UNC (U310BT)
  • X27EUR (F920BT)
  • X27UNC (X920BT)
  • X30EUR (F20BT)
  • X30UNC (Z120BT)
  • X71EUR (F30BT)
  • X71UNC (Z130BT)
  • X72EUR (F930BT)
  • X72UNC (X930BT)
  • X14EU0 (F40BT)
  • X14UC0 (Z140BH)
  • X15EU0 (F940BT)
  • X15UC0 (X940BT)
I  should point-out that CardInfo.cif is just a text file. The format is very cryptic and I could not find much on how to decode it. Maybe its buried in some thread I didn't find. However those 6-character labels above are present. The F series guy's mod was to use a text editor to replace the newer unit's labels with the older unit's labels. That is:  original link:
Open the original CARDINFO.CIF in text editor, search and replace this:
KJJARRH8R51UX72EUR   (label X72EUR)
With
X07EURX27EURX30EUR  (labels X07EUR, X27EUR, X30EUR)
Note that this is just a small segment of the entire text file, which always seems to be 300 characters long.
HOWEVER I examined the European Cardinfo file and it seems to be a different format. The US/CN version has the above labels spaced out around the file with a bunch a mysterious characters between.  See attachment for hex dump of US/CAN Cardinfo.
So, for any enterprising, adventurous, and somewhat skilled Z1130/140 owner out there (or the X series equivalents), you might try taking a stab at moding the Z120/X920 US file. Just make sure you have a backup of /USER. Sorry, I can't try since my HU is a Z110 and it is already updated.
Notes: I'm not sure if a particular CardInfo is tied to a specific release (2015 US/CN vs EU, or 2013 vs 2015). As has been discovered - you can get past the "Update" prompt and still get the wrong SD detected. Maybe all those mysterious characters relate to a specific set of files?
All the Cardinfo files start with "#PIONEER" but from there on the format seems different. I wonder if the next character indicates a format? Or maybe a region? Maybe nothing in particular?
Maybe, all those mysterious letters and numbers is just to obfuscate the file - maybe they are meaningless noise. That would explain why the Euro mod worked - just adding the desired model labels and keeping the file length at 300.. Just an idea worth testing.
Like I've said before, pionara has much more experience in decoding these files. I was hoping he'd help out here.
Edited Oct 25, 2015 by RonS
Posted Oct 25, 2015 · 18:16 UTC#45
I have my ipod wired and I cannot control it through the head unit after applying the 2015 update. I'll try falling back to the 2012 bluetooth firmware and see if that fixes my bt audio issue, but this will not fix my issue of not being able to control the ipod through the head unit. I'll report back if the 2012 bt firmware fixes my issue.
Thanks for all the help.
Posted Oct 25, 2015 · 18:21 UTC#46
The attached CARDINFO will work for 130BT/140BT by prompting "Update:  Yes/No"....However, when you go past that, it'll say "Incorrect SD card" ...
CARDINFO.zip
Edited Oct 25, 2015 by randomwalk101
Posted Oct 25, 2015 · 19:16 UTC#47
Then why post it? What Cardinfo file was this based on? It begins with "#PIONEER3" instead of our "PIONEERQ". My theory is that some of those characters after PIONEER" relate to the UPDATE image.   Try making the mod with the US 2015 Cardinfo file. Just replace the Z110bt label "X07UNC" with "X71UC0" (Z130bt) and "X30UNC" with "X14UCO" (Z140bh).  If that works, the X series guys can replace "X27UNC" with "X72UNC" (x930bt) and maybe randomly replace some 6 characters with" X15UC0" (X940BT). I think it is important to keep the file size to 300 bytes.
Posted Oct 25, 2015 · 19:25 UTC#48
Did you set Settings/AV System Settings/App Connection to Wired?
Posted Oct 25, 2015 · 19:51 UTC#49
Yes, this setting has always been set to Wired. Thanks for the help though. Downgrading to the 3.24 bt firmware didn't fix my issue either. I guess I'll just have to stick with the 2013 map update.
Posted Oct 25, 2015 · 21:36 UTC#50
The attached CARDINFO will work for 130BT/140BT by prompting "Update:  Yes/No"....However, when you go past that, it'll say "Incorrect SD card" ..ThT
This CARDINFO.CIF file is from the 2012 (v4.0) update. Even though it will work for the Z110BT, Z120BT, X920BT, and Z130BT as shown by the HEX dump, it won't work with the 2015 update because it is searching for version 4.0 (2012) update, therefore the "Incorrect SD card" error.
Edited Oct 25, 2015 by jfwalsh99
Page 2 of 11
