Ok..good news.
BlakeStone was nice enough (and so is kellinaradway) to upload the complete update 2015 map for Z140BT (and newer units). Basically just download that and replace the verinfo file from pionara and it'll update.
Go here:
Ok..good news.
Go here:
I was curious what the differences were between the Z120 and Z140 updates were (other than CardInfo), so I ran pionara's perl script in the Z140 Update directory using the Z120's manifest file (ALLDATA.VER). Oddly the only differences were in UPDATE\NDATA (which I assumed were just maps). I had expected that most differences would be in USER\PRG ( the application programs ), but they were identical.
Attached is the log of the NDATA crc file verification.
Summary of NDATA differences:
So besides having 86 different NDATA files, there were 8 more files for the Z120. So these differences must somehow explain why we couldn't just mod CardInfo and use pionara's VERINFO.DAT and install the Z120 release on the Z130/Z140. But that trick seemed to work for the 2015 European upgrade. ![]()
I also should add that the nag screen bypass works great as well on the 140BT. Thanks for posting the info Rons.
Just wondering - is this strictly for Z120 ? and cannot be used to Update the Z140-BH maps ?
Ok read it all- -I guess it works on Z140-BH
Hey man, is it possible for you to post -step by step -what you did with your install so as to avoid any errors because I am also running Z140-BH and dont want the system to screw up or lock out. I did download VEINFO.DAT file and 2015 MAPS CIF - what other files do I need ? also downloaded the main file from the first post. What else is needed ?
but what exactly you did from step 1 until install started working perfectly?
oh Wait the original link is not working anymore ? any alternative link?
I have an iPod wired and have no problems. Are you trying to use BT? That will prevent some things from working since Apple doesn't support the Audio/Video Remote Control Protocol (AVRCP). For example Aha and Pandora must use the cable for iPhone/iPod.
There have been several people (myself included) who have had BT audio problems with Android v5 & 6 and AVIC BT 3.32. Falling back to the 2012 FIRMWARE seemed to fix some of those issues.
I found my problems go away if I am on some other (non-BT) audio source when the AVIC boots and starts playing. Then, after I see the BT connection message, I switch to the BT source (such as Pandora). But that is with my Android phone. Don't know if iStuff has the same issue.
I have experienced the same issues. I had to downgrade my software to 5.0 2013 Update but I kept the firmware at 3.32. When i updated to 2015 with 3.32 It seems as if the Bluetooth will not hold the connection and only plays my music for about 3 seconds before stopping and disconnecting. I am running an iphone 5s on IOS 9.0.2. Simply downgrading my software back to 2013 but keeping the BT firmware at 3.32 works. Means something is up with the 2015 software.
This seems more complicated than it is because there are two different AVIC series that use this upgrade: Z-series (Z110/120/130/140) and X-series (x920/930/940). Each series has its own forum. Most of us have been reading both forums ( plus the F-series one) since the knowledge needed is spread out and it is a common solution. To complicate it even more, there are two different sets of files for the US/CAN 2015 upgrade. One set only works with the older units (Z110, Z120, x920) and the other works with newer units (z130, z140, x930, x940).
With previous upgrades (normally released annually) we only needed one set of files (UPDATE, FIRMWARE directories) and only needed to place on the SD the CardInfo.CIF file for the older or newer units. For some reason that didn't work this year. Many of the UPDATE files differ between the older and newer units. I still don't understand why.
Keep in mind that you are reading a thread in the Hacks sub-forum which is a work-in-progress - not a how-to procedure. It presumes a certain level of expertise. However it seems that the messy details have finally been sorted-out. We now have a very simple process which only requires a little knowledge on using your computer - basically how to download, extract the compressed files, and copy them onto your installation SD.
Unfortunately links to files sometimes get stale. They all do eventually. For the time being, get your files here:
Then extract the files, copy UPDATE, FIRMWARE, and CardInfo.CIF to the root of a freshly formatted FAT32 SD, and insert it into your unit.
Let's try to keep this thread on topic. I'm sure it will get cluttered-up enough with upgrade problems. They always do. It seems that both Android and iPhones are having BT issues - maybe we'll see a patch release from Pioneer.
Keep in mind that you are reading a thread in the Hacks sub-forum forum which is a work-in-progress - not a how-to procedure. It presumes a certain level of expertise. However it seems that the messy details have finally been sorted-out. We now have a very simple process which only requires a little knowledge on using your computer - basically how to download, extract the compressed files, and copy them onto your installation SD.
- z110bt, z120bt, x920Bt - older units
- z130bt, z140bh, x930bt, x940bh - newer units
It worked !!
Million thanks. -if it weren't for people like you this forum would be dead. Thanks a lot again for active support and helping us newbies out.
I loaded this on my X930BT earlier today. Everything seem to update smoothly. However, my iPod cable no longer work with iPhone 6S. It can only charge but does not detect a device. Any recommendation?
Thanks all!
Thanks all!
Try this. Seems like a common issue with the Z130/x930. http://avic411.com/index.php?/topic/81751-avic-z130-2015-update-broke-ipod-wired-connection/&do=findComment&comment=336468
Hi Guys, its been awhile! I downloaded RonS's newer units link and unzipped and put the UPDATE, FIRMWARE, and CardInfo.CIF to the root of a freshly formatted FAT32 SD just as instructed... I have a X940BT and teh update starts but after 1%, if halts and an error pops up that says "Incompatible SD Card, Please enter another SD" or something like that. Now that my HU is in update mode, the error keeps coming up when I turn on the unit. Any suggestions?? I read the whole post and it seems some had teh same issue but it also semms that it was rectified and RonS link would work?? Any help would be appreciated!
It might actually be an incompatible SD so you could get another 4 to 8 GB one very cheap and try that. Larger capacity or new fast ones seem to be problematic. It also could be a problem with the files. Are you using a Mac? The file extraction program might not be working right.
If you just want to abort the update altogether, you'll need to get into TestMode and delete \USER\SYSTEM\Download\StartKnd.log.
Then remove your TestMode SD (or USB stick), and it should restart into regular mode on next power up.
Hi RonS,
Its on a HIGH-SPEED 8GB microSD HC card... Should I buy another 4GB? Non high speed? What kind does the real Navteq Update SD have? Maybe I'll match that!
Just to confirm, the newest links update should work for my X940BT? The UPDATE, FIRMWARE and CARDINFO.dat in the root dir of the SD. I did not transfer the Compatibility.txt file. I did have a few issues with downloading the .zip file... It downloaded about 850MB then said it was download completed. I try a few times and then finally it I downloaded the full 2.45GB. I thought maybe it capped at 1GB per zip file but eventually the full zip file downloaded. There there another link I can use or can you send it PM. This would confirm that I have the complete download...
Thanks for the prompt response and I really appreciate the help.!
Hi RonS,
I always use a plain-jane 4GB one. I think when you buy the Navteq one, it comes on a 4GB microSD w/adapter. I also got a "short" download the first time. Don't know why. Worked right the second time.
Ok, I'll go to malwart and get a cheapy 4GB microSD except i checked online and I couldnt find a non HC card?? Is it even possible to find and buy a non HC microSD any more?... If they don't have a 4GB, 8GB should work right?
I did a full format (windows) FAT32 and it worked...
Ok, I'll go to malwart and get a cheapy 4GB microSD... If they don't have a 4GB, 8GB should work right?
Yup. I'm not saying that larger (4,8,16) ones won't work, but I know HC cards are different technology. I had a microSD 16GB that wouldn't work - so I stay w 4-8GB to be safe.
UPDATE: I just reviewed the Z120 and Z140 User's manuals and they do say the units are capable of SDHC. The older units only say up to 16GB. So that might not be the issue. But others have had to try different SDs to get it to work. More people have file extraction issues. Some un-zip programs work differently - especially with nested directories in the archive. 7-Zip seems to work good on PCs. Most of the problems seem to be with Macs. They often have to run Windows in a VM.
I also checked out the protocol/standard for microSD. microSD has a max of 2GB, SDHC is 2gb or more.. Then there is SDXC which is 64, 128 etc. The class however is the speed at which the data is transferred. My CLASS10 min write at 10mb/s, I just found a class 4 (4mb/s) and i'll try that. If not, I'll try to unzip with a different software.
So, I tried and was unsuccessful... I still have the incompatible SD error... I'll try to download the zip file again and use another unzip program to see if that's the issue. By the way, has anyone actually try to update this file to 940BT sucessfully?
UPDATE: I tried and tried again... This time I got to 2% so once I passed 1% I thought "Yay", then it wouldn't go pass 2% and got the error again...
So I then proceeded to use the TESTMODE and delete the \USER\SYSTEM\Download\StartKnd.log. and rebooted my HU. Except... There is no maps! Therefore, I have to get his HU running again.
Any help again will be appreciated.
So I decided to try download the ZIP file again and start from scratch. This is nervewrecking...
So.. How many NDATA files are is supposed to be in the UPDATE folder for the x940BT?? I have 106 in the zipped folder...
I had this sd card error and it was all in how I unzipped and created the sd card.
What ended up working for me was the full sd card format to fat32 with purposely selecing the 16k allocation unit size
I also unzipped the zip file to my pc desktop with winrar and then individually copied to the microSD card, the FIRMWARE folder first and then the Update folder next and finally the correct CardInfo.cif file.
So finally it worked!!! It must of been the way it was extracting the zip file. I used 7zip and it worked! Thanks for all the suggestions RonS! And for all the effort, the maps don't have my new area!! Go figure. Hope the next update will!
