I have never seen such a large group of ingrates in my life. It's no wonder the site is pretty much dead! A bunch of freeloaders if you ask me!
There are those at any site, but the main reason I continue with most sites is for the few that you know appreciate what you have contributed and for the knowledge learned. It's pretty much like the whole rest of the world, but you have to keep going and can't let it get you down.
I know it sounds like I am the perpetual optimist, but far from that. I am the guy that always expects the worst and sometimes you're pleasantly surprised here and there when it turns out otherwise.
Ok, that all aside, I do want to thank you as I think I've figured out that all of the versions apparently were built off of your first donation. I was able to download the "newer" version and put back the proper cardinfo file for the "older" version.
Download the file pack for the newer ones, Click on this link LINK and download the old CARDINFO.cif file and replace the one in the original download with the one from the second download and you will be good to go. Just worked for a Z110 I bought on the cheap.
Your suggestion worked just fine, installed with no issues. Thank you. Also thanks for the nag fix file, I will be installing that tomorrow if I get time.
Also thanks to Pionara, RonS, and the many others who worked on this project.
Now hopefully after I disconnect power it will recognize my iPhone again. Right now it just comes up and nothing can connect to it. Seems the power disconnect fixed many peoples problems. Crossing my fingers....
On a side note, since some were having trouble, I used 8gb micro SD cards w/ adapter for almost every update and/or moding on this thing. They are not the "high speed" variety and I format with windows "default" allocation size option.
