2015 Avic Z120 map update
By kellinaradway · Oct 03, 2015in Hacks/Mods💬 256 posts👁️ 81,230 views
Page 8 of 11
Posted Feb 07, 2016 · 20:02 UTC#176
Thanks for the reply - MUCH APPRECIATED!
All righty then just a few nomenclature questions and I'll give it a go......[inserted in blue below]
Go for it. Just be careful, Testmode is tricky and powerful. If you still have the 2015 zip file (or the SD you used for the update), you don't need to backup the existing Navi.exe file. Be aware that you can't overwrite an existing file - it will silently ignore the command. Use my post #4 as a guide for Testmode operation
So I recommend:
  • from your computer format an SD FAT32 and copy to it the Testmode.key and new Navi.exe..........got that
  • take the SD to your headunit, turn it on,  and insert it. If Testmode doesn't start after a about 5 seconds, cycle the power (ignition key)........ not sure what you mean by cycle? turn ignition off and on
  • navigate to /USER directory...........like the video
  • figure out which PRG directory is the "active" one. If /USER/PRG.FLG doesn't exist, use PRG0, otherwise PRG1............what is .FLG - PRG.FLG? It is an empty file that tells which of the two PRG directories is being used (PRG0 or PRG1).
  • open the "active" PRGn directory...........PRGn is? Either /USER/PRG0 or /USER/PRG1
  • open the APL directory..........APL is? A directory in either USER/PRG0 or /USER/PRG1
  • select and delete the current Navi.exe (optionally, you could copy/paste it one directory up as a backup - then delete)........the rest of it, very much like the video instructions, basically replacing the Navi.exe by cutting and pasting
  • navigate to the SD, select Navi.exe and Copy
  • go back to your /USER/PRGn/APL and Paste. Verify its there.
  • eject SD and cycle the ignition key
 Thanks again. Very much appreciate the guidance and help!
Edited Feb 07, 2016 by RonS
Posted Feb 10, 2016 · 05:08 UTC#177
Hi RonS,
Does this work on the X920BT?  Sorry, if this was answered before. I browsed though several threads and read conflicting information.
If it does work, I have already downloaded the "2015 USA CANADA MAP UPDATE.zip" from here: z130bt, z140bh, x930bt, x940bt - newer units  and will follow veron_fat's steps.
Hi,
Just wanted to follow up everything works. The download link and instructions were great and does indeed work on the X920BT. Many thanks to all the contributors and RonS for your help!
Posted Feb 15, 2016 · 22:09 UTC#178
Ok is I updated to the 2015 update all went well on my Z120BT now my Sirius won't work has this happen to anyone else?
Posted Feb 15, 2016 · 22:37 UTC#179
I know nothing about Sirius but I feel that the 1st step when weirdness occurs after any update should be to "cold boot" by disconnecting the battery for a couple minutes.
Edited Feb 17, 2016 by RonS
Posted Feb 17, 2016 · 03:26 UTC#180
Thanks Ron ill try that an then post back.
Posted Feb 18, 2016 · 03:24 UTC#181
Thanks to everyone to that made these updates so easy to implement!
Thank you, thank you, thank you!
Posted Feb 21, 2016 · 15:30 UTC#182
Confirmed disconnecting the battery did the job every thing works like a champ. THANKS ALOT RonS !!!!!! You are the man an a big thanks to everyone on this forum that helps us NOOBS not be NOOBS. Again THANKS RonS !!!!!
Posted Mar 17, 2016 · 23:58 UTC#183
i know i'm a bit late to this party but does anyone have a working link for the 2015 maps?
**EDIT**
going through all of this I did find a working link for my Z140BH.  After reading through all this I "assume" that the most current procedure is just a matter of popping this onto a formatted SD card UNEDITED and booting off the SD card to install?
Thanks much guys
Oh and how can I contribute a little for the time/effort of those who made this happen?
Dave
Edited Mar 18, 2016 by TT_Vert
Posted Mar 18, 2016 · 01:44 UTC#184
Ran into a bit of a problem.  I updated to the 2015 maps and updated bluetooth w/o any problem.  Problem now is that I press app connection as it's greyed out and I can no longer see any phone apps (Pandora/AHHA, etc).  App connection says iPhone if that matters (I have an android based phone)..  I am going to try to install the 5.1 firmware that is designed for head units that have the Navteq update.   I had 4.0 prior to the map upgrade.   However version under service info screen states 6.0000 is that a firmware version?
**EDIT**
Was able to get in and change it using the 5.1 FW but after i change it despite the phone being connected or not it then is greyed out again and unable to be changed.  Worse yet, when I open pandora it controls my phone but plays it on my phone speaker, same thing happens even when using the bluetooth audio.  So in essence, even though BT is connected audio goes through phone speaker.  In BT settings on phone it only allows BT for call audio and when I move the switch to on for media audio it instantly turns it off. Power cycling, factory reset, reinstall of 2015 maps and BT FW update as well as removing and re-pairing HU from my phone HU did not help.   Anyone have any advice?  I may try the 2013 maps and BT FW to see if it helps.
**UPDATE**
I had it working (Temporarily).  I suspect there is something awry with the 2015 bluetooth FW for the 140.  I went back to 2013 maps and it still didn't work.  I then went ahead and updated the BT FW from 3.32 to 3.32.  So the same firmware but the only difference was the source.  2013 Maps 3.32 works fine, 2015 Maps 3.32 does not work. I then tried to install 2015 maps over the existing 2013 version and utilize the 2013 version 3.32 BT FW but now i'm back where I was an even rolling back to 2013 maps and installing 3.32 BT FW over the top of the 2015 BT FW doesn't fix it :(
**UPDATE 2**
Just installing 2015 maps w/o BT FW still screwed up BT audio playback.  Tried to install 2013 version  of FW 3.32 and then an then the 2015 version and neither would work.  Reverted to 2013 maps and 2013 v. 3.32 BT FW and all is well.  Very odd but I'm not going to fret over it at this point, I've spent too much time messing with this tonight but I did learn a lot about this system so thanks for that.
Tried
Dave
Posted Mar 18, 2016 · 03:41 UTC#185
Sorry to bother you Ron but can you tell me where i can find the 2012 Firmware?  I also have issues w/ bluetooth audio after upgrading to 2015 maps.  I have a Z140BH if that matters.  I would have PM'd you but they appear to be disabled.
thanks
Dave
I have an iPod wired and have no problems. Are you trying to use BT? That will prevent some things from working since Apple doesn't support the Audio/Video Remote Control Protocol (AVRCP). For example Aha and Pandora must use the cable for iPhone/iPod.
There have been several people (myself included) who have had BT audio problems with Android v5 & 6 and AVIC BT 3.32. Falling back to the 2012 FIRMWARE seemed to fix some of those issues.
I found my problems go away if I am on some other (non-BT) audio source when the AVIC boots and starts playing. Then, after I see the BT connection message, I switch to the BT source (such as Pandora). But that is with my Android phone. Don't know if iStuff has the same issue.
Posted Mar 18, 2016 · 14:02 UTC#186
thanks
Dave
No, I don't know where to get it unless some old link still works. However I don't think the 2012 f/w works on a Z140. Didn't the Z140 come out in 2013?
Posted Mar 18, 2016 · 16:29 UTC#187
I really have no idea.  I'm just grasping at straws trying to get Bluetooth audio working again.
Dave
Posted Mar 18, 2016 · 18:45 UTC#188
Final update.  Well I had some "anomalies" with my Z140BH which I chronicled above.  Ended up having to go back to 2012 BT FW 3.24 to get BT audio to work again but still using 2013 maps.  I have to manually click connect in pandora to get it to connect to my phone but I'll take it.  When I went to replace the navi.exe file I had no .flg files in either PRG0 or PRG1.  I checked modified dates of navi.exe and replaced that exe with the most recently modified one but it didn't work.  After a bit more research I found that if you do not have that .FLG file then your HU apparently uses the PRG0 directory which actually was the case for me.  So if you have a Z140 and no .FLG file in the PRG0/PRG1 file its safe to say you replace the file in PRG0.
Dave
Posted Mar 18, 2016 · 19:37 UTC#189
Dave
PRG.FLG, if present, would  be in /USER. I assume you are talking about installation of the nag-screen hack (patched Navi.exe). To be clear - don't just copy in some patched file that you downloaded unless you know that it is the same version you are using. Best practice -   once you have determined the "active" PRG directory, patch a copy of that Navi.exe (and keep a copy of the original just in case).
Posted Apr 09, 2016 · 16:08 UTC#190
This seems more complicated than it is because there are two different AVIC series that use this upgrade: Z-series (Z110/120/130/140) and X-series (x920/930/940). Each series has its own forum. Most of us have been reading both forums ( plus the F-series one) since the knowledge needed is spread out and it is a common solution. To complicate it even more, there are two different sets of files for the US/CAN 2015 upgrade. One set only works with the older units (Z110, Z120, x920) and the other works with newer units (z130, z140, x930, x940).
With previous upgrades (normally released annually) we only needed one set of files (UPDATE, FIRMWARE directories) and only needed to place on the SD the CardInfo.CIF file for the older or newer units. For some reason that didn't work this year. Many of the UPDATE files differ between the older and newer units. I still don't understand why.
Keep in mind that you are reading a thread in the Hacks sub-forum forum which is a work-in-progress - not a how-to procedure. It presumes a certain level of expertise. However it seems that the messy details have finally been sorted-out. We now have a very simple process which only requires a little knowledge on using your computer - basically how to download, extract the compressed files, and copy them onto your installation SD.
Unfortunately links to files sometimes get stale. They all do eventually. For the time being, get your files here:
Then extract the files, copy UPDATE, FIRMWARE, and CardInfo.CIF to the root of a freshly formatted FAT32 SD, and insert it into your unit.
Just as an FYI, I installed this on my x940bt and all seems to work well.  However, you can no longer get into the App version screen by holding in the upper left.  Not sure why that would be.
I'm curious of the process by which getting the latest maps onto these newer systems. My background is hacking the old 80/90 and D3/N3 Nav systems, in particular doing the 40R (remote control, not touch screen) patches up to CNDV-90MT.  I know the new ones require you to use use a code to download the latest maps, and that somehow the devices are encrypted/locked but since its just Windows CE figured there was an easy way to just overlay newer data on the OS image in one of the proper partitions...eventually.   Granted, I still wish I could make my own KWI files for the D3 head for newer maps.
Edited Apr 09, 2016 by kheller2
Posted Apr 11, 2016 · 03:43 UTC#191
Ok so a BIG,BIG,BIG thanks to everyone that put all the hard work an time into this for us.
I have updated my frimware from 2.003 to 6.000 an to the 2015 USA CANADA MAP on my Avic Z120BT. I can not confirm about the other units but for the Z120 it was a piece of cake to do. I am by no means savvy at stuff like this so if I can do it anyone can. It is very straight forward and easy to do. If you read over this whole thread you will get all the answers you need.  An again a big thanks to everyone. I am very GRATEFUL TO YOU ALL!!!!!
So this is what I did for my Avic  Z120BT.
1. Downloaded this, click the blue link here for newer units    z130bt, z140bh, x930bt, x940bt - newer units
2. Once you have finished the download extract the files if need so. I didn't have to as Im on a Mac. You may have to extract the files if you are on a PC not sure about that.
3.Then open up the 2015 USA CANADA MAP UPDATE folder you downloaded. Find the CardInfo.CIF file then open the file with a text editor. Delete all the text and replace it with this info below. Copy from the # to the G in the text below.
#PioneerQPRX2MP00IUYJSO2NFRJA6QYICEG003IC1TD9OA3KWJTKXX9C3SCQX30UNCVY6O2C7W7QW14BK0OJDGF1K5X07UNCP79T4YGYNGVDX27UNCTNEPNWPBS1H4INT15XKYQ6XBLHEWPEWXN7342Q1WW8HWKXNLRWELALK6KIJU0PO17P3BF1UJXB8RHUYU9IL91RRBYIK15QVAEHTFQECMSSHF21XXJRTYY6U4XOMA7SPEUP21BCGQHT9EYQ4RV3WSUEC1JNSPIIMD61GDEYIKWC9EUCJKX8JICMVCG
4.  Then Copy  the UPDATE, FIRMWARE folders and the edited CardInfo.CIF  to the root of a freshly formatted FAT32 SD card larger then 4GB.
5. Then insert it into your unit an then hit ok to update. This will take about 25 minutes to do an you must leave the vehicle running to update.
6. After your uint boots back up an you finish the units setup go into the bluetooth setting an then hit update firmware. This will take about 10 to 15 minutes to finish.
DONT FORGET TO THANK THE OTHER USERS FOR THIER TIME IN MAKING THIS HAPPEN.
I was digging around on the site again because I was wanting to see what you guys were all up to and if there were any updates on the software for these units. I have been on the fence about upgrading my unit to a newer unit because I have loved this unit since I got it, except for the fact that Pioneer never does updates and makes us pay for map packs BS IMO, but you guys always surprise me with your skills keep at it and thank you for doing what you all do in your free time to support the users and members of this site!
Posted Apr 12, 2016 · 05:26 UTC#192
thanks to everyone in this thread, just bought a 2013 subaru brz and got everything working with the non nag mod on my X930BT =)
Posted Apr 30, 2016 · 20:09 UTC#193
This works perfectly. Thank you to everyone involved!
Edited Apr 30, 2016 by rican_s4
Posted Apr 30, 2016 · 20:16 UTC#194
From post #140
I guess you people didn't read the rest of this thread. Use the Z140 link (which works - I just tested). Unzip on your hard drive, then open up the CardInfo.CIF file with a text editor. Delete all the text and replace with:
(no returns or line-feeds) and save it. It should be exactly 300 bytes long. Copy it all to an SD. Should install just fine.
Edited Apr 30, 2016 by RonS
Posted Apr 30, 2016 · 20:19 UTC#195
From post #140
Thank you! I read that just after I posted.
Posted May 05, 2016 · 16:28 UTC#196
Anyone have working link for Older Units?
Posted May 05, 2016 · 20:07 UTC#197
Read post #140
To make it easier, I have attached the CardInfo,CIF file for the Z110, Z120 units. Just rename it to CardInfo.CIF and replace the one in the root of your SD.
CARDINFO.txt
Edited May 25, 2016 by RonS
Posted May 24, 2016 · 16:22 UTC#198
I just did the update this morning, my Z120 now running on firmware 6.0 !!
The only tricky part was to use the good CARDINFO.cif   ( I've use the same from my 2013 update ! ) copy/paste !
After the update, I also notice that I've lost bluetooth signal --> UNPLUG YOUR BATTERY AFTER UPDATE !
!!!  I would like to thanks everyone on this thread ( especially RonS ;)    )
:eek:8)
Which terminal do you unplug? Positive, negative or both? If both, any particular order?
I also updated to the 2015 maps and I am experiencing BT issues - My iphone 6 would pair but no music through the speakers....
Posted May 25, 2016 · 02:08 UTC#199
To follow up on my own question, I disconnected both, starting with the negative, then positive + 5 min wait. Then positive and negative back.
It worked! Thanks.
Now at least I can hear BT music through my speakers - no BT calls nor Navigation TTS through the speaker
Posted May 26, 2016 · 18:38 UTC#200
Hi RonS,
              First off, thanks to you and your cohorts for the sterling work in making these updates available to us tech mortals.  I wanted to add a little clarity to the Pandora over BT issue.  iPhones do have AVRCP (as of iphone 3G I think), the AVRCP allows basic functions like Next Track, Last Track, Play, Pause and some basic browsing.  It is this AVRCP functionality that allows Track Skip/Pause of Pandora over BT when the source is "BTAudio".  When the source is "Pandora" SPP (Serial Port Profile) is required for interface over BT.  Apple iOS does not support SPP, iPhones will need to be wired and will not interface over BT.  I think it is SPP that opens up the more advanced two-way communication allowing access to station lists, thumbs up and thumbs down.
The following is a list of BT profiles supported on iPhone 4 and later, note there is no SPP support.
Hands-Free Profile (HFP 1.6)
Phone Book Access Profile (PBAP)
Advanced Audio Distribution Profile (A2DP)
Audio/Video Remote Control Profile (AVRCP 1.4)
Personal Area Network Profile (PAN)
Human Interface Device Profile (HID)
Message Access Profile (MAP)
Page 8 of 11
