2015 Avic Z120 map update
By kellinaradway · Oct 03, 2015in Hacks/Mods💬 256 posts👁️ 81,230 views
Page 7 of 11
Posted Jan 09, 2016 · 19:14 UTC#151
thank you , RonS, will try it today
BTW , do you think I need to backup my unit? if yes, please kindly advise how to do that .Sorry I am old  :-(
Posted Jan 09, 2016 · 20:05 UTC#152
Not a bad idea but most people don't do it. It isn't that easy learning Testmode. There's a video on Youtube -> TESTMODE
To get into TestMode, download SuperTestMode.zip from here -> testmodekey; extract TestMode.key, put it on an SD and insert it.
Posted Jan 10, 2016 · 00:23 UTC#153
I guess you people didn't read the rest of this thread. Use the Z140 link (which works - I just tested). Unzip on your hard drive, then open up the CardInfo.CIF file with a text editor. Delete all the text and replace with:
#PioneerQPRX2MP00IUYJSO2NFRJA6QYICEG003IC1TD9OA3KWJTKXX9C3SCQX30UNCVY6O2C7W7QW14BK0OJDGF1K5X07UNCP79T4YGYNGVDX27UNCTNEPNWPBS1H4INT15XKYQ6XBLHEWPEWXN7342Q1WW8HWKXNLRWELALK6KIJU0PO17P3BF1UJXB8RHUYU9IL91RRBYIK15QVAEHTFQECMSSHF21XXJRTYY6U4XOMA7SPEUP21BCGQHT9EYQ4RV3WSUEC1JNSPIIMD61GDEYIKWC9EUCJKX8JICMVCG
(no returns or line-feeds) and save it. It should be exactly 300 bytes long. Copy it all to an SD. Should install just fine.
Many thanks, RonS
New to here, and this is the first time to do this.
Download the Z140 file and I have modified the cardinfo.cif follow your direction.
But what the next step? should I
1. Format a SD card in FAT32 type?  I only have a 32G ,is it OK?
2. Copy the firmware folder,update folder  modified CARDINFO.CIF to the root of SD card
3. Insert to the Z120 unit
4. it will automatic update , wait to finish
is that all I need to do?
if I need to update the bluetooth, is any other file I need to download?
my unit is original Z120 with 2.003 version. toooooo old  :mrgreen:
Thanks for help
Hi RonS,
Does this work on the X920BT?  Sorry, if this was answered before. I browsed though several threads and read conflicting information.
If it does work, I have already downloaded the "2015 USA CANADA MAP UPDATE.zip" from here: z130bt, z140bh, x930bt, x940bt - newer units  and will follow veron_fat's steps.
Posted Jan 10, 2016 · 00:31 UTC#154
Hi RonS,
Yes it should work on x920, z110, z120, and of course (without modification to CardInfo) x930/940 and  z130/140
Posted Jan 10, 2016 · 05:44 UTC#155
it works,many thanks, RonS
but the BT phone call still bad :shock:
Posted Jan 17, 2016 · 09:34 UTC#156
Or let first start by saying thanks to everyone who had a hand in making this work!!!  im sorry if is has already been answered but Im new to this an just want to make sure I'm reading all this all right.
I have a BT Z120 and it is on V.2003. I want to update it with the 2015 new maps an all the other goodies. Im not to sure which file to download or what to do. I have read over the thread an just want to make sure Ive got it an I download the right files..  Thanks for the help.
Ok so I have the  Z120BT an I download the 2015 USA CANADA MAP UPDATE for  z130bt, z140bh, x930bt, x940bt - newer units.
Then make the modification to the  CardInfo.cif file to this
Then put  the FIRMWARE, UPDATE, CARDINFO onto a fresh formatted SD Card to update the maps then go into blue tooth to update that.
If I missed something please let me know. Thanks for all the hard work to make this work an to everyone that takes the time to help us Noobs. Is there a Kitty fund for the next map update?
Edited Jan 17, 2016 by crazyfingers
Posted Jan 17, 2016 · 21:13 UTC#157
Ok so a BIG,BIG,BIG thanks to everyone that put all the hard work an time into this for us.
I have updated my frimware from 2.003 to 6.000 an to the 2015 USA CANADA MAP on my Avic Z120BT. I can not confirm about the other units but for the Z120 it was a piece of cake to do. I am by no means savvy at stuff like this so if I can do it anyone can. It is very straight forward and easy to do. If you read over this whole thread you will get all the answers you need.  An again a big thanks to everyone. I am very GRATEFUL TO YOU ALL!!!!!
So this is what I did for my Avic  Z120BT.
1. Downloaded this, click the blue link here for newer units    z130bt, z140bh, x930bt, x940bt - newer units
2. Once you have finished the download extract the files if need so. I didn't have to as Im on a Mac. You may have to extract the files if you are on a PC not sure about that.
3.Then open up the 2015 USA CANADA MAP UPDATE folder you downloaded. Find the CardInfo.CIF file then open the file with a text editor. Delete all the text and replace it with this info below. Copy from the # to the G in the text below.
4.  Then Copy  the UPDATE, FIRMWARE folders and the edited CardInfo.CIF  to the root of a freshly formatted FAT32 SD card larger then 4GB.
5. Then insert it into your unit an then hit ok to update. This will take about 25 minutes to do an you must leave the vehicle running to update.
6. After your uint boots back up an you finish the units setup go into the bluetooth setting an then hit update firmware. This will take about 10 to 15 minutes to finish.
DONT FORGET TO THANK THE OTHER USERS FOR THIER TIME IN MAKING THIS HAPPEN.
Posted Jan 19, 2016 · 17:38 UTC#158
First off, thank you guys for making these updates available!!
I've updated the maps/bluetooth using the files from the 'newer' units even though I have the older z110bt. I've now got the firmware showing 6.000.
I have a couple of questions though that I didn't see in this thread:
- Directly after the update, I had the icons for Pandora and Aha. I was getting the same iPod issues (blank screen) so I performed a battery reset on the unit. The iPod controls now work, but the icons for Pandora and Aha are gone. (EDIT: I don't have the 'App Connection' button but was able to get these icons back)
- I've noticed that there are still big chunks of maps missing (my home address is not showing even though the complex was built 10+ years ago. (Is this because HERE Maps aren't updated?)
Any suggestions?
Thank you in advance!
Edited Jan 19, 2016 by Jefe2323
Posted Jan 19, 2016 · 21:31 UTC#159
Any suggestions?
Try zooming-in more. Secondary side streets don't always show up (even when you are driving on them)unless you are zoomed-in pretty close. Did your home street show-up on the old maps?
Posted Jan 19, 2016 · 23:48 UTC#160
Ron,
I zoomed in but it still doesn't recognize a lot of the side streets. I've gone to the HERE Maps website and they don't show up either unless you're in 'satellite' mode. I'm assuming that it's a HERE problem and not the update? On a much older version of the maps the street did show up.
I apologize for all of the questions, but...
Also, I've noticed that my Android phone (Galaxy s5) does not connect automatically to Bluetooth with 'phone and media' but just with 'phone'. I have to go into Bluetooth audio and connect manually. I'm using 3.22 and have seen other posts saying that rolling back to a previous version might work. Is that my only solution?
Posted Jan 20, 2016 · 14:29 UTC#161
Ron,
I have a Google Nexus 5 and am running BT 3.32 (the latest) on my AVIC. Once in a while I have BT audio streaming issues but it works most of the time. I found it always works if my AVIC audio source is something other then BT, Aha, or Pandora when I boot up. I wait until I get the phone  "connected" message on the HU before switching to a BT source. BTW, 3.22 isn't a version I'm familiar with. Did you mean 3.24 - or maybe you meant 3.32?  I don't know what software you were running before the v6 (2015) upgrade. Have you tried 3.32?
Edited Jan 20, 2016 by RonS
Posted Jan 21, 2016 · 00:36 UTC#162
Sorry, I misspoke earlier. I AM running 3.32 and my phone will always connect to Bluetooth PHONE AUDIO but I have to manually connect to MEDIA AUDIO every time. For example, I have to go to BT source, hit 'connec't, then it gives me the 'follow the instructions on your phone' message. I then have to go to my phone settings and click 'media audio.'
Edited Jan 21, 2016 by Jefe2323
Posted Jan 21, 2016 · 01:06 UTC#163
Does anyone know where to buy the Maps SD cards at for the Z120BT
Edited Jan 21, 2016 by crazyfingers
Posted Jan 21, 2016 · 13:04 UTC#164
Here
Posted Jan 21, 2016 · 14:35 UTC#165
Go to Settings/AV Settings and make sure "App Connection" is set to Bluetooth. BTW, I was having a similar problem yesterday - and my HU was doing weird things - like playing my wired ipod's music when I selected Pandora - instead of connection to the phone.  Somehow my HU setting for App Connection got set to Wired. After setting it back to Bluetooth, I also re-pair my Android phone to the HU. Now it is working as expected.
Posted Jan 23, 2016 · 16:18 UTC#166
Thanks Ron
Posted Jan 30, 2016 · 21:23 UTC#167
with this update, would a z120 obtain the z150's backup camera gridlines (when car put into reverse and equipped with a camera)? if so, what do they look like? I couldn't find any pictures on the web. thanks!
Posted Jan 30, 2016 · 23:48 UTC#168
You try looking in the manual for this upgrade? 2015 Manual T1000-23346
See page 28
Posted Feb 01, 2016 · 20:28 UTC#169
ok....so I'm not sure how to give thanks on this forum, but to all the heavy lifters on here, thanks SO MUCH.... I have no idea how you guys go about figuring how to edit the hex table to make changes, but THANKS SO MUCH!
This is actually the second time I've benefited from your expertise (the first being an update a few years back on the same x9310bt unit to the 4.001 firmware).
However, I have a question that I can't seem to track down at all.  In the last update (which was in 2013), there was a mod to enable a SAFE MODE toggle.  I'm pretty sure that the offsets that the original values were located that are now different, so I'm wondering if anyone can point be in the right direction?
If it helps, the original offsets from that update  were 15aef0 from 02 00 56 E3 to 09 00 56 E3 and 15aee0 from 01 10 A0E3 to 00 10 A0 E3.
I did a search for those values in the hex table, but they show up multiple times, so I'm loath to start editing them randomly without knowledge of what i'm doing.......
Posted Feb 03, 2016 · 18:01 UTC#170
Thanks to all of y'all who have been kind enough to spend the time making these modifications, helping those that need assistance, and continuing to run this site. As the last guy said, I've benefited twice now from this site and its contributors.
Thanks again!
Posted Feb 06, 2016 · 00:19 UTC#171
Edited Feb 06, 2016 by kellinaradway
Posted Feb 06, 2016 · 00:29 UTC#172
Posted Feb 07, 2016 · 00:35 UTC#173
G'Day -
I've been reading, reading, reading and absorbing as much as I can on my own before pestering anyone here with more questions. HUGE THANKS to all who have taken their time and contributed so generously to the education of the timid and uninitiated - like me!
I have an AVIC Z140BH.
With all of the instruction and available media I have been successful in installing the 2015 updates. I would now very much like to remove the OK nag screen and think I have found the easy-reader version but would be very appreciative if someone could ya or nay my perception:
It appears that MPTonyT's post # 128 the available download is the already amended Navi.exe file, [presumably this is the finished product that Ron S. was describing how to achieve in post #2], along with the test.key to actually enter the system and replace the original. Ron S. The navigation video link has me emboldened enough to give it a go - of course backing up everything first! - if someone knowledgeable could give me a nod of approval.
thanks in advance!
Posted Feb 07, 2016 · 16:00 UTC#174
G'Day -
thanks in advance!
Go for it. Just be careful, Testmode is tricky and powerful. If you still have the 2015 zip file (or the SD you used for the update), you don't need to backup the existing Navi.exe file. Be aware that you can't overwrite an existing file - it will silently ignore the command. Use my post #4 as a guide for Testmode operation
So I recommend:
  1. from your computer format an SD FAT32 and copy to it the Testmode.key and new Navi.exe
  2. take the SD to your headunit, turn it on,  and insert it. If Testmode doesn't start after a about 5 seconds, cycle the power (ignition key)
  3. navigate to /USER directory
  4. figure out which PRG directory is the "active" one. If /USER/PRG.FLG doesn't exist, use PRG0, otherwise PRG1.
  5. open the "active" PRGn directory
  6. open the APL directory
  7. select and delete the current Navi.exe (optionally, you could copy/paste it one directory up as a backup - then delete)
  8. navigate to the SD, select Navi.exe and Copy
  9. go back to your /USER/PRGn/APL and Paste. Verify its there.
  10. eject SD and cycle the ignition key
That should do it.
Posted Feb 07, 2016 · 19:22 UTC#175
Thanks for the reply - MUCH APPRECIATED!
All righty then just a few nomenclature questions and I'll give it a go......[inserted in blue below]
So I recommend:
  1. from your computer format an SD FAT32 and copy to it the Testmode.key and new Navi.exe..........got that
  2. take the SD to your headunit, turn it on,  and insert it. If Testmode doesn't start after a about 5 seconds, cycle the power (ignition key)........ not sure what you mean by cycle?
  3. navigate to /USER directory...........like the video
  4. figure out which PRG directory is the "active" one. If /USER/PRG.FLG doesn't exist, use PRG0, otherwise PRG1............what is .FLG - PRG.FLG?
  5. open the "active" PRGn directory...........PRGn is?
  6. open the APL directory..........APL is?
  7. select and delete the current Navi.exe (optionally, you could copy/paste it one directory up as a backup - then delete)........the rest of it, very much like the video instructions, basically replacing the Navi.exe by cutting and pasting
 Thanks again. Very much appreciate the guidance and help!
Page 7 of 11
