unityracing Posted March 17, 2008 Report Share Posted March 17, 2008 Ok, so first off, I have an AVH-P6800DVD. As you know its very similar in design to the avic units. When run off the high level outs (speaker wires) it sounds great. When attached to the rca's I get alt/engine whine bad. Checked all grounds, good. Regrounded everything, to the battery, then a common point for all items, then to just different bare metal places. Tried the ground the rca shield trick, no go. Even tried hooking the head unit up to a different car for power, still not good. Also all of this was done with all pioneer accessories disconnected from the head unit to eliminate them as a problem. Also tried ground loop isolators and no help there. Sound goes away when the rcas are disconnected from the head unit (OR) from the amps. I've read on here (searched for the last 3 hours) about an rca fuse ??? Never heard of one on any device with rcas. I'm thinking maybe bad caps in the power supply of the head unit ?? HELP! I want to resolve this so I can sell it and get a d3/z1/z2 for my new ride. The p6800dvd doesn't have external remote jacks that I need for my steering wheel controls Used to be a local installer but im stumped! FWIW - the current setup : 97 eclipse gst spyder avh-p6800dvd avg-vdp1 i pod adapter gex-p920xm diamond audio d3400.4 diamond audio d3600.1 Quote Link to post Share on other sites
smug01 Posted March 18, 2008 Report Share Posted March 18, 2008 I have a D3 with basically the same problem on my Lexus LX450. For mine, though, the alternator whine is reduced almost completely if the chassis of the stereo is not in contact with the vehicle metal...wierd stuff. Let me know if you have any luck. I am thinking this "microfuse" may be the culpret as well. Quote Link to post Share on other sites
95ImpSS Posted April 28, 2008 Report Share Posted April 28, 2008 Ok, so first off, I have an AVH-P6800DVD. As you know its very similar in design to the avic units. When run off the high level outs (speaker wires) it sounds great. When attached to the rca's I get alt/engine whine bad. Checked all grounds, good. Regrounded everything, to the battery, then a common point for all items, then to just different bare metal places. Tried the ground the rca shield trick, no go. Even tried hooking the head unit up to a different car for power, still not good. Also all of this was done with all pioneer accessories disconnected from the head unit to eliminate them as a problem. Also tried ground loop isolators and no help there. Sound goes away when the rcas are disconnected from the head unit (OR) from the amps. I've read on here (searched for the last 3 hours) about an rca fuse ??? Never heard of one on any device with rcas. I'm thinking maybe bad caps in the power supply of the head unit ?? HELP! I want to resolve this so I can sell it and get a d3/z1/z2 for my new ride. The p6800dvd doesn't have external remote jacks that I need for my steering wheel controls Used to be a local installer but im stumped! FWIW - the current setup : 97 eclipse gst spyder avh-p6800dvd avg-vdp1 i pod adapter gex-p920xm diamond audio d3400.4 diamond audio d3600.1 Have you been able to resolve this issue? You described my current situation with my Z2 perfectly! Quote Link to post Share on other sites
TwlVoltz Posted April 28, 2008 Report Share Posted April 28, 2008 what kind of RCA's also where is the power wire next to rca or other side of vehicle??? Quote Link to post Share on other sites
95ImpSS Posted April 29, 2008 Report Share Posted April 29, 2008 what kind of RCA's also where is the power wire next to rca or other side of vehicle??? In my case, I have tried 2 different sets of RCAs (both Monster cable). My power wire from the battery is run along the driver's side of the vehicle in the channel under the door sills. My RCAs, XM IP-Bus cable & amp remote turn on wire are routed along the passenger side of the car under the door sills. Quote Link to post Share on other sites
HiFiSi Posted April 29, 2008 Report Share Posted April 29, 2008 Not that it would cause much if any interference, but I always run my turn on lead on the same side as the power wire. Because it's got an electrical current running through it I don't want it anywhere near the RCA's. If you have an mp3 player or portable CD player or something that has RCA outputs on it you can hook it to the inputs on the amplifier and see if the noise is still there using an alternate audio source. Quote Link to post Share on other sites
bird_dog0347 Posted May 2, 2008 Report Share Posted May 2, 2008 I have the exact problem with my D3. I too have tried everything, and I too get no whine when not using the RCA's. I have tried two different amps, lots of RCA's speaker wire, ground locations, etc. When my amp is hooked up to the factory speakers, but the RCA is not connected, there is no whine. As soon as the RCA is connected and it is started back up, it whines like crazy. Even when it is not in the dash (held in my hand) so the chassis is not touching metal so that cannot be it. I tried isolators, ground wires on the RCA's, EVERYTHING. Quote Link to post Share on other sites
superjet Posted May 2, 2008 Report Share Posted May 2, 2008 Go to Best Buy, buy the Peripheal ISVE-61 4 channel line out converter, use that off the high level speaker outputs, turn the gains to 1/4, then rca plugs on the output side going to the 4 channel amp. Problem solved. Use this converter, not a cheap one online. You could also use two ground loop isolators, but it will kill your midrange. Quote Link to post Share on other sites
bird_dog0347 Posted May 2, 2008 Report Share Posted May 2, 2008 I thought about a LOC the other night... If that worked and there was no noise, it would prove a problem on the HU and I would think Pioneer would cover that under warranty... I will return the GLI I bought and get a LOC and try that. Quote Link to post Share on other sites
bird_dog0347 Posted May 3, 2008 Report Share Posted May 3, 2008 Just wanted to let you guys know, I tried the LOC last night and it works now without any whine. Quote Link to post Share on other sites
95ImpSS Posted May 3, 2008 Report Share Posted May 3, 2008 What if you're only trying to power a sub? I'm using the speaker outputs from the Z2 to power the door speakers...and am only trying to use the subwoofer output RCAs to power my subwoofer's amp. Is there a solution for me? Thanks. Quote Link to post Share on other sites
bird_dog0347 Posted May 4, 2008 Report Share Posted May 4, 2008 I had mine like that for a while... I just turned on the LPF on my sub amp, besides, my sub won't play that high pitched sound. Quote Link to post Share on other sites
Nowakezone Posted May 6, 2008 Report Share Posted May 6, 2008 Here is your fix. I did this yesterday and poof all fixed. Seem as though Pioneer has this problem. http://www.caraudio.com/forum/showthread.php?t=198477 Quote Link to post Share on other sites
95ImpSS Posted June 5, 2008 Report Share Posted June 5, 2008 I bought the RCA inserts, grounded them, and ran my subwoofer RCAs through them before going to the amp. The whining noise increased exponentially. Does this mean that my engine whine/noise is being introduced from the chassis? What do I look for? Quote Link to post Share on other sites
HiFiSi Posted June 5, 2008 Report Share Posted June 5, 2008 WTF are RCA inserts??? Quote Link to post Share on other sites
