rharms77 Posted April 8, 2008 Author Report Share Posted April 8, 2008 So why would the 3.5mm plug I got from walmart work, but not the same 3.5mm plug I had to buy from a small electronics shop not work. Are the configurations on the plug ends different from each other? If so, then I understand. I had no concern over video or anything, I just wanted to play music. Thanks for all the replies! Quote Link to post Share on other sites
WhiteBird00 Posted April 8, 2008 Report Share Posted April 8, 2008 So why would the 3.5mm plug I got from walmart work, but not the same 3.5mm plug I had to buy from a small electronics shop not work. Are the configurations on the plug ends different from each other? If so, then I understand. I had no concern over video or anything, I just wanted to play music. Thanks for all the replies!Because items sold at Wal-Mart are higher quality? (no that couldn't be it ) I guess the one you got from the electronics store was defective in some way. Sometimes a difference as apparently insignificant as how pointed the tip is can cause a plug not to make proper contact in the jack. And then the same plug might work fine in a different device. A few years ago I had a satellite radio connected to a cassette adapter in two different vehicles. With one, everything worked fine but with the other I lost the left channel audio until I swapped adapters. Quote Link to post Share on other sites
rharms77 Posted April 8, 2008 Author Report Share Posted April 8, 2008 Haha, ok maybe its just a defective cable. I guess its off to high quality walmart to get another one! Quote Link to post Share on other sites
BuffaloSS Posted April 11, 2008 Report Share Posted April 11, 2008 I've got a pair of cables that won't work either. One is a relatively expensive RadioShack cable with gold plated plugs, and the other is some generic male/male. Neither one works. Stupid pioneer! Quote Link to post Share on other sites
Join the conversation
