jschmid8706 Posted April 16, 2008 Report Share Posted April 16, 2008 Those with the AVIC D3 BTB200 for bluetooth...where did you put the power source to? did you directly hook it up to the battery? in the manual it just says connect to terminal always supplied with power regardless of ignition switch.... just connect it straight to the batter? Quote Link to post Share on other sites
whtcrxghst Posted April 16, 2008 Report Share Posted April 16, 2008 Just tap into the power wire for the deck Quote Link to post Share on other sites
jschmid8706 Posted April 16, 2008 Author Report Share Posted April 16, 2008 that wouldnt be the ACC it would be the one that says battery 12 v i think its yellow for me? Quote Link to post Share on other sites
06f150stx Posted April 16, 2008 Report Share Posted April 16, 2008 i taped into the cig. lighter Quote Link to post Share on other sites
HiFiSi Posted April 16, 2008 Report Share Posted April 16, 2008 The radio has 2 power wires going to it. One is switched from the ignition, and one is constant power. IIRC, red = switched, yellow = constant. Quote Link to post Share on other sites
NY99Q45t Posted April 16, 2008 Report Share Posted April 16, 2008 The radio has 2 power wires going to it. One is switched from the ignition, and one is constant power. IIRC, red = switched, yellow = constant. Those colors are correct. Quote Link to post Share on other sites
Sprawl Posted April 17, 2008 Report Share Posted April 17, 2008 The radio has 2 power wires going to it. One is switched from the ignition, and one is constant power. IIRC, red = switched, yellow = constant. Those colors are correct. WHich of the two power supplies should the BT receiver be plugged into. I have plugged mine into the switched power and not the constant. I'm wondering if this is causing my connection problems. the receiver is working fine but i have to manually reconnect my phone everytime i getinto the car to fully use it Quote Link to post Share on other sites
HiFiSi Posted April 17, 2008 Report Share Posted April 17, 2008 The yellow/constant power wire. It needs constant power to keep it's memory, which would definitely lead to connection problems. The on/off switching is done via the IP-BUS cable. Quote Link to post Share on other sites
