TLTC Posted May 2, 2008 Report Share Posted May 2, 2008 Just got in Z2 and am ready for install! The info is on the site, I've read it, BUT I have read so much info that I have now confused myself ... thus the BLONDE QUESTION: Steps To Install a Z2 (Manufact: May 2007) with 2008 Updated System & Maps: 2 wire bypass ONLY TA DA! OR 2 wire bypass download z2 bypass update install update reset system TA DA! OR WHAT... Quote Link to post Share on other sites
Hyperite Posted May 2, 2008 Report Share Posted May 2, 2008 Sexy blonde? I hope so, cuz i don't understand your question. Quote Link to post Share on other sites
TLTC Posted May 2, 2008 Author Report Share Posted May 2, 2008 HAHA! I told you I confused myself! That's pretty bad! My question was regarding doing the 2 wire bypass and having the system work, however, IF you take the time to read the Sticky, it clearly reads :: FOR ALL UNITS MADE SINCE 2006 OR ANY UNIT UPDATED WITH THE BLUETOOTH UPDATE CD" Somehow, I believe myZ2 would fall into that catagory... so all I have to do is the 2 wire bypass, then CHECK and RECHECK wires to be sure they are in the harness CORRECTLY, TIGHTLY, and GROUNDED. Is this correct oh Master of the Z2? (You know you ROCK) Quote Link to post Share on other sites
garrettoomey Posted May 2, 2008 Report Share Posted May 2, 2008 You only need the 2 wire bypass. Forget the BT, etc updates. Does not apply to your Z. Quote Link to post Share on other sites
TLTC Posted May 2, 2008 Author Report Share Posted May 2, 2008 Do I still need to burn the image to the disc and install it to get the bypass to function properly? That is where I got confused... Quote Link to post Share on other sites
garrettoomey Posted May 2, 2008 Report Share Posted May 2, 2008 If you have the 2008 maps and system update, then you will not need to burn any images. Install per instructions, do the 2 wire bypass, done... Quote Link to post Share on other sites
TLTC Posted May 2, 2008 Author Report Share Posted May 2, 2008 That's what I thought. Guess the blonde is wearing off now. Quote Link to post Share on other sites
CaptainInsaneO Posted May 2, 2008 Report Share Posted May 2, 2008 Guess the blonde is wearing off now. What a shame. Quote Link to post Share on other sites
whtcrxghst Posted May 3, 2008 Report Share Posted May 3, 2008 When you say "updated with 2008 maps" that means you have put the Z3 image on your HD right? Otherwise you will need the update to get your May 2007 deck bypassed with the 2-wire method. Quote Link to post Share on other sites
TLTC Posted May 4, 2008 Author Report Share Posted May 4, 2008 No, I haven't even installed the Z2 yet. The company told me that I could order the Z2 or the Z2 with the 2008 updated maps and system which costs a little more. Quote Link to post Share on other sites
garrettoomey Posted May 4, 2008 Report Share Posted May 4, 2008 How much more? Quote Link to post Share on other sites
TLTC Posted May 5, 2008 Author Report Share Posted May 5, 2008 $160ish. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted May 31, 2008 Report Share Posted May 31, 2008 $160ish. itd cost you roughly $20-$30 less to buy an unlocked z3 drive on ebay. and it comes with all the 08 maps Quote Link to post Share on other sites
