cali007 Posted November 3, 2008 Report Share Posted November 3, 2008 thats interesting! i guess if you have a good list of cams its ok. How did you get this working w/o messing with the data.zip after upgrading to 2.0? Does it at least show icons for the cams? Quote Link to post Share on other sites
gjas18 Posted November 4, 2008 Author Report Share Posted November 4, 2008 The speedcams just worked. I already had the file in there before the update and apparently is wasn't overwritten. Now the music is ATT instead of muted. All I had to do was set the voice prompts back to ATT (setting was reset after the update.) With the cam warnings everything appears normally in relation to the warnings, just the cam locations can't be edited on the unit anymore. Basically Borism's speedcam interface unlock is no longer functional (at least until one of us has the time to unlock it again) Quote Link to post Share on other sites
BorisM Posted November 4, 2008 Report Share Posted November 4, 2008 Speedcam warnings themselves are controlled by a line in SYS.TXT and I believe the upgrade did not touch it, so as long as it has been turned on and you still have speedcam data, it will keep working. I am working on putting back cam editing, just did not have enough time to finish it yet... Quote Link to post Share on other sites
ArthurJGuy Posted November 7, 2008 Report Share Posted November 7, 2008 Have you tried the data feed from trapster.com it is free, and updated daily by users in your area. Quote Link to post Share on other sites
BorisM Posted November 7, 2008 Report Share Posted November 7, 2008 What format is their feed in? Quote Link to post Share on other sites
ArthurJGuy Posted November 7, 2008 Report Share Posted November 7, 2008 CSV Quote Link to post Share on other sites
BorisM Posted November 7, 2008 Report Share Posted November 7, 2008 Neat. CSV could be easily converted into format iGO uses if it is not fine as is... Quote Link to post Share on other sites
ArthurJGuy Posted November 7, 2008 Report Share Posted November 7, 2008 They show more then just red light cameras, which if it could be updated OTA would be usefull. Known location of a cop recently Locations cops generally hide red light cams I think something else also but I forget. It's free to sign up and check it out. Quote Link to post Share on other sites
BorisM Posted November 7, 2008 Report Share Posted November 7, 2008 Doing OTA update wouldn't be very easy, and iGO only updates internal speedcam database on startup. Having a fresh list of danger areas would be good enough, IMHO. Quote Link to post Share on other sites
ArthurJGuy Posted November 7, 2008 Report Share Posted November 7, 2008 I agree, its better than nothing. Quote Link to post Share on other sites
kerosene Posted November 8, 2008 Report Share Posted November 8, 2008 I dont understand this how do we install the speed cameras Quote Link to post Share on other sites
forbitel Posted November 16, 2008 Report Share Posted November 16, 2008 I finally got the speed warning working, i guess it doesn't work over "fly over" mode, but when I'm actually driving, it DOES WORK. I got the speed camera database from http://www.trapster.com in csv, it is a really good database, very accurate at least on my area. It is daily updated by the own users, positions get voted so they increase the level of confidence of that camera type/position, anyways i think it is a good database and really easy to convert to IGO format. By the way if anyone wants the file that i converted from Trapster, let me know. The file include cameras from all over the mainland 48-states of US, i have only verified my area and it is looking very accurate over here. This is user collaboration based database, this means users add, modify, delete camera position and type (static, redlights, possible hidden police points, etc) I changed the classification to comply with the igo format (speed camera = '1' static, redlight = '3' redlight cameras, and hidden police points = '5' mobile cameras) this data base is as good as many user collaborate to build it, so, people start creating your FREE account and lets build a nice speedcamera database for our AVIC... I'll try to convert/update the database as soon as i can, since the site is constantly updating. Installation: - copy both txt files to the /IGO/content/speecamera/ folder on you avic, while you are in testmode. (they are already converted to IGO format) - Restart the unit. it will take a little longer to start up (only the first time) since the unit has to build its own data based on the content of txts (it will do it by itself, so nothing to do here, just wait about 2-4mins) - test if you can see the camera on the map. Note: I have only tested the location on my are and looks good, let me know how it looks for your area? trapster-speed-us-0_11-15-08.txt trapster-redlight-us_11-15-08.txt Quote Link to post Share on other sites
djzach Posted November 18, 2008 Report Share Posted November 18, 2008 How do you convert from the trapster format to the .txt format you have here? Quote Link to post Share on other sites
djzach Posted November 18, 2008 Report Share Posted November 18, 2008 Also, If I already have a different Speed and Red Light .txt files, do I add the trapster ones or replace them??? Basically does it combine them or use the most recent one? Quote Link to post Share on other sites
BorisM Posted November 18, 2008 Report Share Posted November 18, 2008 I haven't seen Trapster files yet, but the iGO format is very simple: Header: X,Y,TYPE,SPEED,DIRTYPE,DIRECTION X - Longitude (E/W) Y- Latitude (N/S) TYPE: 1 - Static camera 2 - Traffic Light 4 - Section Camera 5 - Mobile Camera SPEED - speed limit of the camera DIRTYPE: 0 - All directions 1 - One direction (as per Direction field) 2 - Both directions (DIRECTION and opposite) DIRECTION - Camera angle. 0 = North, 180 = South, etc. I imagine that iGO will combine TXT files you give it. It converts them all to internal format anyway... PS Just looked at Trapster files posted here -- looks exactly like what we need... Quote Link to post Share on other sites
