how22 Posted September 19, 2008 Report Share Posted September 19, 2008 I would like to know why the navigation is around 70 feet off.I grounded the break wire and the speed censor is hook up Quote Link to post Share on other sites
redgar Posted September 19, 2008 Report Share Posted September 19, 2008 The accuracy is mostly dependent upon the GPS signal you are receiving. What accuracy level does your gps status screen show (see pages 123-124 or your manual)? You may need to reconsider the placement of your gps antenna. Quote Link to post Share on other sites
schaferc Posted September 19, 2008 Report Share Posted September 19, 2008 why is it you cant find the right folder to post in? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted September 19, 2008 Report Share Posted September 19, 2008 the best/most concealed placement is on your dash by the windshield or right by your rear window. You can put it outside, but I wouldnt. I have mine behind my regisration and inspection stickers at the bottom corner of the window. cant even notice it and perfect signal. Quote Link to post Share on other sites
wasntme Posted September 19, 2008 Report Share Posted September 19, 2008 The best is actually outside the car. The antenna is designed to be outside the car. That is why it is magnetic and sealed. That is also why all factory GPS antennas are outside the vehicle. As for being off in distance it will never be very close. The satellites are locked by the government. Civilians only are able to get a piece of the available GPS signal. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted September 19, 2008 Report Share Posted September 19, 2008 The best is actually outside the car. The antenna is designed to be outside the car. That is why it is magnetic and sealed. That is also why all factory GPS antennas are outside the vehicle. As for being off in distance it will never be very close. The satellites are locked by the government. Civilians only are able to get a piece of the available GPS signal. I said best AND concealed. It's not really hidden when its outsidfe your car. Whether it's made for being outside or not, the front dash by the windshield will work just as good. As long as there is no metal above the antenna obstructing the signal you should be fine. Quote Link to post Share on other sites
bitman Posted September 19, 2008 Report Share Posted September 19, 2008 i fully disagree that the signal is the same as being in side the car or on the roof. i tested both and on the roof is a major upgrade in signal. especially when driving in a city with high buildings. Quote Link to post Share on other sites
HiFiSi Posted September 19, 2008 Report Share Posted September 19, 2008 My antenna is INSIDE my dashboard and I get great signal. Enough that the navigation is never off, even by a little bit. Quote Link to post Share on other sites
lava10t2 Posted September 19, 2008 Report Share Posted September 19, 2008 i know it's not the same, but for satellite radio, have the receiver on the outside was a huge improvement over having it on the dash. That being said though, mine is on the dash and it's not that big of a deal, the "dot" on my screen is only about a second behind me. Quote Link to post Share on other sites
djhuab Posted September 20, 2008 Report Share Posted September 20, 2008 i fully disagree that the signal is the same as being in side the car or on the roof. i tested both and on the roof is a major upgrade in signal. especially when driving in a city with high buildings. i had mine outside when i first had it installed but i hated the way it looked so now its under the dash and the signal is exactly the same. Quote Link to post Share on other sites
bashed1 Posted September 20, 2008 Report Share Posted September 20, 2008 As for being off in distance it will never be very close. The satellites are locked by the government. Civilians only are able to get a piece of the available GPS signal. If you're referring to the SA (Selective Availability) signal that the U.S. military used to inject into the civilian-side GPS signals, that was turned off years ago (during Clinton's administration). We now receive the same, unaltered signal that the government gets - only they spend much more (of our) $$ on more sensitive receiving equipment than we can afford. Quote Link to post Share on other sites
