Chuck88 Posted October 1, 2010 Report Share Posted October 1, 2010 Got it! But you might have trouble when cranking the car to start because of the voltage drop ... I don't know for sure though. After all, what are you trying to achieve? Do you have the F500 or F700 or F900 unit? I have a X710 unit and I don't have the reset-and-go-back-to-square-one problem. Quote Link to post Share on other sites
redrotor Posted October 2, 2010 Report Share Posted October 2, 2010 don't worry car battery should hold more juice to handle both .hh I have a f700. I Quote Link to post Share on other sites
Chuck88 Posted October 3, 2010 Report Share Posted October 3, 2010 I have a f700. Then you shouldn't have the font resetting problem, except when you enter the Testmode. Quote Link to post Share on other sites
redrotor Posted October 3, 2010 Report Share Posted October 3, 2010 what? f700 have ssme ressting problem.if the power is interupted in certain period of booting it resets to factory defaults. I thought this is same problem on all avic 700 900 90.maybe 500. Quote Link to post Share on other sites
Chuck88 Posted October 4, 2010 Report Share Posted October 4, 2010 what? f700 have ssme ressting problem.if the power is interupted in certain period of booting it resets to factory defaults. I thought this is same problem on all avic 700 900 90.maybe 500. I got a X710 that is a replicate of the F700 with FW 3.0. I got this lost font problem maybe 2 times every 3 months, no big deal, problem during unsuccessful booting (interrupted like you said). But is it worth that battery backup electronics? I doubt so! I just reload the font with Testmode. Quote Link to post Share on other sites
redrotor Posted October 17, 2010 Report Share Posted October 17, 2010 finally sucessfully installed dealey timer. now anytime avic start boot up it'll have 1 minute to finish booting. but looks like when I crank the engine voltage drop is too big avic can't continue booting.but bigger battery might help. anyway now I can turn the key to close the window and turn off right away and avic will still finish the booting so I don't have to install the font again. the kit I order from ebay was not suitable for my needs so I had to build from scratch.I use general NE555 timer circuit with relay. I think this is not the perfect solution but sure it'll reduce the chance. Quote Link to post Share on other sites
redrotor Posted October 17, 2010 Report Share Posted October 17, 2010 I found another interesting thread. http://avic411.com/index.php?/topic/19417-ignition-mod-on-f900bt/page__st__45 this will prevent crank restarting and with timer it should be perfect. now I'll have to install backup battery. Quote Link to post Share on other sites
redrotor Posted October 17, 2010 Report Share Posted October 17, 2010 now I found software solution. http://avic411.com/index.php?/topic/27524-modify-your-f-series-base-os-and-registry/ I think this is permanent solution without hardware mod.only link for editor is dead. I emailed the member who sucessfully installed.so hope he can help me.. Quote Link to post Share on other sites
redrotor Posted October 19, 2010 Report Share Posted October 19, 2010 OK I finally installed perment solution. I was gona install second backup battery but found software solution. EEgeek realeased Wince moder and pretty easy to use. I modifed registry and add font file.and voila it stay working after resets. just flow above link and read second page it's really easy. Quote Link to post Share on other sites
F900BT Posted December 9, 2011 Report Share Posted December 9, 2011 Does anyone know if this works on F30BT? I currently have the F900BT, but considering buying the F30Bt. Quote Link to post Share on other sites
Happy168 Posted April 14, 2015 Report Share Posted April 14, 2015 Hello Redrotor or Anyone I have been trying to get a permanent solution to have Asian Fonts. I tried to use EEGeek's avic-modder to add some entries to WINCEIMG.BIN but fail. If possible, can you please give me a simple guild? e.g. what exact entries I need to add for Asian fonts. Thank you very much in advance! Eric Quote Link to post Share on other sites
Happy168 Posted April 22, 2015 Report Share Posted April 22, 2015 Bump.. can anyone help me.. how to get Asian Fonts permanently on the F700bt? Thanks! Quote Link to post Share on other sites
Happy168 Posted May 3, 2015 Report Share Posted May 3, 2015 bump bump.. just hoping someone can pop by... help me to out with to apply asian font on the F unit =) Quote Link to post Share on other sites
Happy168 Posted May 25, 2015 Report Share Posted May 25, 2015 any 1 ?!?! bump =) thx Quote Link to post Share on other sites
Aashi Posted May 8 Report Share Posted May 8 On 11/13/2008 at 11:30 PM, sombutsi said: FYI, change number in step 2 to hexidecimal before you change the number Hi friend Thank you so much for this news. Quote Link to post Share on other sites
Join the conversation
