ceger Posted February 21, 2009 Report Share Posted February 21, 2009 Thank you Boris for all your hard work, I just tested out the speed cam in Knoxville TN and it works Perfect. Now maybe i'll pay attention and not get anymore tickets. You're welcome. I would not necessarily assume that it a) lists _all_ the cameras and camera speed limits are accurate. Still, better than nothing. I am having an issue whenever I try to get the Speedcam mod going. I have loaded dumpystig's items, moved in the place and setting UI files from your zip, updated the SYS.txt to have the speedcam enabled under debug and copied the large speedcam.txt file you posted into the flash's APL2/IG0/CONTENTS/speedcam directory. Every time I boot the system it shows the "System Startup In Progress. Please Wait" message for 5 minutes and then proceeds to reboot over and over. When I go back in to check the APL2/IG0/CONTENTS/speedcam directory, I see a new file is made (I assume the database file it creates) along with the speedcam.txt file and pre-existing speedcamupdate file. Not sure what is going on or if I am missing something, but the only thing I can do at that point is rollback to a data.zip and sys.txt with no speedcam. Any help appreciated. Ceger Quote Link to post Share on other sites
dumpystig Posted February 21, 2009 Report Share Posted February 21, 2009 Hey Ceger, I'm sure Boris will sort it out, tbh I aint got a clue LOL. How you gettin on with the mods, everything else running ok with them? Quote Link to post Share on other sites
ceger Posted February 21, 2009 Report Share Posted February 21, 2009 Hey Ceger, I'm sure Boris will sort it out, tbh I aint got a clue LOL. How you gettin on with the mods, everything else running ok with them? getting nowhere fast. Ceger Quote Link to post Share on other sites
dumpystig Posted February 21, 2009 Report Share Posted February 21, 2009 Hmm, is it just the Speedcam mod your having trouble with, or you got other probs too? Quote Link to post Share on other sites
N-S-E-W Posted February 21, 2009 Report Share Posted February 21, 2009 You pretty much described a crash. Paste the contents of the crash file on here, as long as it's not 10 pages long. I think the most current instance would be the top portion. It may provide clues as to why it crashed. The file should be in apl2 as a text file titled "crash". Quote Link to post Share on other sites
ceger Posted February 21, 2009 Report Share Posted February 21, 2009 You pretty much described a crash. Paste the contents of the crash file on here, as long as it's not 10 pages long. I think the most current instance would be the top portion. It may provide clues as to why it crashed. The file should be in apl2 as a text file titled "crash". Did not know that. I'll take a look. Thanks. Ceger Quote Link to post Share on other sites
ceger Posted February 21, 2009 Report Share Posted February 21, 2009 You pretty much described a crash. Paste the contents of the crash file on here, as long as it's not 10 pages long. I think the most current instance would be the top portion. It may provide clues as to why it crashed. The file should be in apl2 as a text file titled "crash". It says "WinCE CallStack snapshot (function names unknown - map file \My Flash Disk\APL\..\APL2\iGo\ezrider.map not found):" Looking at my flash backup, I never had that file, so some modification for the SpeedCam must be calling it? Crash.txt file attached. Ceger crash.txt Quote Link to post Share on other sites
ceger Posted February 21, 2009 Report Share Posted February 21, 2009 Dumpystig, Did you do an EZRider.exe updates for maps and such that the SYS.TXT file or something might be referencing? Ceger Quote Link to post Share on other sites
N-S-E-W Posted February 21, 2009 Report Share Posted February 21, 2009 There's a broken link somewhere. At least this may help the real experts in diagnosing the problem. Quote Link to post Share on other sites
dumpystig Posted February 21, 2009 Report Share Posted February 21, 2009 Dumpystig, Did you do an EZRider.exe updates for maps and such that the SYS.TXT file or something might be referencing? Ceger No, EZRider remains untouched. All my mods are in the DATA.zip, >project.config< and >pioneer.ui< But I'm thinking, as I also did the mods for getting more sky/better horizon which involved slight alteration of >iGO/SYS.TXT< if this could be causing the prob your having EDIT- I just read your earlier post and it seems you already had the SYS.TXT covered Quote Link to post Share on other sites
ceger Posted February 21, 2009 Report Share Posted February 21, 2009 Dumpystig, Did you do an EZRider.exe updates for maps and such that the SYS.TXT file or something might be referencing? Ceger No, EZRider remains untouched. All my mods are in the DATA.zip, >project.config< and >pioneer.ui< But I'm thinking, as I also did the mods for getting more sky/better horizon which involved slight alteration of >iGO/SYS.TXT< if this could be causing the prob your having I pretty much rolled back the place and setting UI files from BorisM's zip and everything worked just fine, but I cannot access speedcam setting options. BTW, your mod looks awesome! BorisM, do you need to have the updated EZRider.exe for using the speedcam controls? Ceger Quote Link to post Share on other sites
BorisM Posted February 21, 2009 Report Share Posted February 21, 2009 EZRider.map file that crash log refers to is a debugging file that converts memory addresses to function/variable names etc. Used only for debugging, and NavNGo are the only people who have it. So no problem here (other than crash). If you do get a speedcam.spdb file in speedcam directory, then this piece is fine. You can leave it there. Try backing out changes one by one (SYS.TXT, DATA.ZIP changes) until you get it to a point where it does boot. Then we will know where the problem is... Quote Link to post Share on other sites
bryan95502 Posted February 21, 2009 Report Share Posted February 21, 2009 Hi, I would like to try the Data.zip, what is the username for the FTP. It wont let me enter just a pw. Thanks!! Quote Link to post Share on other sites
counterfeit1204 Posted February 21, 2009 Report Share Posted February 21, 2009 Hey Ceger I was having the same problem as you did, and i think i got a fix for it. Did u use BorisM's speedcam.txt(pasted) into ur igo/content/speedcam folder? I just replaced the Boris's data w/ old data which was "Red_Light_Camera_us.txt", and "Speed_Trap.txt" from http://www.avic411.com/forum/viewtopic.php?t=19523 and my 700 began to operate as it usually did. i guess i've made a mistake when i was making speedcam.txt data provided by BorisM. Anyways, really wanna say thank u to all of AVIC411 members, especially to Boris, Mavs & dumpystig Quote Link to post Share on other sites
