djgoofywhitekid Posted June 10, 2009 Report Share Posted June 10, 2009 I'm not getting the connection between the satellite receivers having certain features (or not) and the HD Radio receivers not having the features we're describing with the F series. If the P10 and the P20 works with an FH- or DEH-series, that would indicate that the F-series IS the issue. Quote Link to post Share on other sites
jonbruce Posted June 12, 2009 Report Share Posted June 12, 2009 I agree - just returned by p10 for a p20 Thanks a lot for the vid! Saying your P20 is the same as the P10 is an insult to the P20. The problems with the P10 seem enough for me to try the P20 over the P10. Quote Link to post Share on other sites
b2747 Posted June 13, 2009 Report Share Posted June 13, 2009 I just installed a Pioneer AVIC F-90BT in my F250. What I need to know is what do I need to receive Sirius and HD radio? I need all the help I can get, Any and all replays will be greatly appreciated. Thank You. Quote Link to post Share on other sites
Horizon Posted July 27, 2009 Report Share Posted July 27, 2009 New poster here and past lurker Anyway I just picked up the Avic - F700bt and I just ordered the P20 from Amazon....has anyone tried this since the last firmware update? I know it doesn't say anything in the update notes but maybe it is fixed for some odd reason? Are you guys with the p20 still enjoying HD Radio? AVIC F-Series Firmware Update Change HistoryApplicable models: AVIC-F90BT, AVIC-F900BT, AVIC-F700BT, AVIC-F7010BT Ver 2.006 CHANGE HISTORY: - Fixes the case that Automatic Time Correction does not change time - Updates XM channel icon graphics - Enhances reliability during firmware update process Quote Link to post Share on other sites
my_black_RS5 Posted July 31, 2009 Report Share Posted July 31, 2009 Still no fix for the blank presets? Other than that, the P10HD works fine imho. Quote Link to post Share on other sites
christy123 Posted August 2, 2009 Report Share Posted August 2, 2009 I just ordered p10 for f90bt not realizing p20 was already available. Should i get p20 instead. is there any significant difference between the two? after going through this thread it seems that the consensus is that there isnt much. I am getting my f90bt installed in a week or so..i would rather put a P20 if it better than p10 Quote Link to post Share on other sites
my_black_RS5 Posted August 3, 2009 Report Share Posted August 3, 2009 I just ordered p10 for f90bt not realizing p20 was already available. Should i get p20 instead. is there any significant difference between the two? after going through this thread it seems that the consensus is that there isnt much. I am getting my f90bt installed in a week or so..i would rather put a P20 if it better than p10 I haven't used the P20 but the P10 works as expected with the exception of visible presets. It basically only shows you the numbers and which FM band you're viewing. I only wish you could manually set the preset text somehow. Quote Link to post Share on other sites
Horizon Posted August 3, 2009 Report Share Posted August 3, 2009 Just installed the p20 over the weekend and I like it just again have the same issue with blank presets (f700bt) and the only other thing I notice is the audio goes analog to digital a lot, also has a tendency for the volume to go up and down ever so slightly, does anyone know how to boost the signal? Quote Link to post Share on other sites
phyzfer Posted October 26, 2009 Report Share Posted October 26, 2009 Hi everyone. I just installed the p20 on a f700bt. I too have the same issue with the presets that everyone else is having a problem with. I agree with another post here...this is completely unacceptable. Anyways, once all the presets are in (with the f700bt, I have 3FM bands), I expect to just switch through all my presets from the main screen. I do have another issue though that is quite annoying, since it seems like nobody else has this problem. I have absolutely no AM reception. I select HD as the source and then switch my band to AM...but get nothing..Does anyone know why this might be? thanks! Quote Link to post Share on other sites
cigga24 Posted October 26, 2009 Report Share Posted October 26, 2009 Did you try a BSM search while in AM? Quote Link to post Share on other sites
phyzfer Posted October 26, 2009 Report Share Posted October 26, 2009 What is that? A BSM Search? I tried googling, no dice. Is this something that needs to be done for AM to work? Quote Link to post Share on other sites
cigga24 Posted October 26, 2009 Report Share Posted October 26, 2009 On the AM screen > function > BSM > on All it does is programs your AM presets to the best signal match. Just an easy way to see if you got channels. Quote Link to post Share on other sites
phyzfer Posted October 26, 2009 Report Share Posted October 26, 2009 Do I do this from within the HDRadio icon? I was under the impression that since my HDRadio is using the antenna my AM/FM band icons from AV Sources are disabled. (in fact I tried looking for stations and it didnt work). I'll try BSM. Could it be a bad HDRadio? Does the p20 support AM? Quote Link to post Share on other sites
cigga24 Posted October 27, 2009 Report Share Posted October 27, 2009 I have a P10 and mine does AM and AM HD just like the FM. I also used the antenna splitter because i use MSN which uses the FM signal. Yes do this within the HDRadio icon. You have to press Band i think 4 times to get to AM. Quote Link to post Share on other sites
phyzfer Posted October 27, 2009 Report Share Posted October 27, 2009 Cigga, thanks for the information. So the fact that I'm not getting any AM within the HDRadio Icon is bad (probably faulty p20, I'm thinking). Also, where can I find an antenna splitter? I'm thinking of using one to get regular FM/AM as well as HD. Someone mentioned they bought one on crutchfield, but I didn't find anything there. thanks! Quote Link to post Share on other sites
Join the conversation
