haloevo Posted May 8, 2009 Report Share Posted May 8, 2009 Hey folks, I've been reading around the AVIC411 boards for a couple of weeks now, and like what I see... There are some pretty nice modifications out there for the F500BT that I didn't know about before reaching these boards. Anyway, the reason for my post this morning is because I'm having difficulties installing the F500BT & ND-G500 combo I recently purchased. Right now I've got the F500BT installed through the cig lighter/aux connection, but when it comes to the ND-G500 Amplifier, I've got no idea what I'm doing. See, what's confusing me is this... The main wires coming from the amp has THREE different connections... One being the ISO Connectors, and then, the two other connectors which read 'To Car Stereo'. Can someone help me out, as to where to install all of these wires? If it help, I have a 2001 Chevy Impala.... Pretty basic vehicle. I've got an aftermarket deck in the car now, and don't care if it has to go, or if it stays. Thanks in advance for any help given! Quote Link to post Share on other sites
dumpystig Posted May 8, 2009 Report Share Posted May 8, 2009 Yup, the harness is a nightmare! It works like this: - Headunit speaker output > Harness speaker input - Harness speaker output > Car speaker connector (which your h/u was originally connected to) - Power connections: +12V permanent, +12V accessory, -12V (ground) - Handbrake (connect directly to ground, not to handbrake) - Reverse wire (optional, I just taped mine up) If you need any more specific advice, let me know - Quote Link to post Share on other sites
y2kwht150 Posted June 10, 2009 Report Share Posted June 10, 2009 So is the speaker wires on ISO connector output or input? Quote Link to post Share on other sites
Specter Posted June 10, 2009 Report Share Posted June 10, 2009 It isn't so hard to install really. What you need is a parrot connector. It will connect to those weird connectors on the amp and allow you to plug them into your car. What you want to find is a parrot connector for a 2001 chevy impala. I bought one from this site for a 2001 4runner. Connected it to the amp cable and plugged it right into my car and into my car stereo without cutting a single wire. That assumes that your after market radio is not hard wired to your car. If your car stereo is installed by using a plug in connector you are set. You have to verify that the original OEM connector on your car is still intact. The parrot connector will simply go between the ISO connectors on the amp cable and make them fit your cars connector. on one end you plug it into the cars plugins and on the other end you plug the cable from your stereo into the parrot connector. That is it. done. http://www.hawkexpress.com/index.cfm?fu ... t_ID=53321 The GM-GMC Harnesses QCGM-2 Non-Bose should fit your car if you don't have Bose. You may have to call for pricing. tell them you saw it for $20 in a google product search. That is what it is listed at. I got mine for $18. http://www.quickconnectproducts.com/Fin ... php?id=176 this site will help you find the connector you need. I ordered from hawkexpress because they are cheaper and they shipped it the very next day. Quote Link to post Share on other sites
EriksAVIC Posted June 10, 2009 Report Share Posted June 10, 2009 The Parrot connectors make installing the F500BT and amp SOOO much easier. I hacked the amp cable up a bit, I didn't want 60ft(I exaggerate )of cabling sitting in my dash. I bought my parrot kit from this website: http://store.cellularsurge.com/pcqcgm-2.html Was pretty cheap and arrived in a decent amount of time. Great service, I recommend them. If you need a different connector for a different vehicle, go to this website to look up what connector you need: http://www.quickconnectproducts.com/Find/find.php then just put in the P/N that comes up into the website above and do your thing. Good luck. Erik Quote Link to post Share on other sites
gates59 Posted January 16, 2010 Report Share Posted January 16, 2010 Anybody know of a good place to buy the qcgm-2 adapter in canada or maybe cheap in the us. Quote Link to post Share on other sites
gates59 Posted February 8, 2010 Report Share Posted February 8, 2010 Anyone from northern ontario looking for a QCGM-2 iso connector. I don't want mine never installed. Quote Link to post Share on other sites
