andr2000 Posted December 3, 2009 Report Share Posted December 3, 2009 sorry, but are you 100% sure that data r1272 does work and r1273 does not? thanks Quote Link to post Share on other sites
Jfinley0 Posted December 3, 2009 Report Share Posted December 3, 2009 sorry, but are you 100% sure that data r1272 does work and r1273 does not?thanks  I will try again and get back to you. Jimbo Quote Link to post Share on other sites
andr2000 Posted December 3, 2009 Report Share Posted December 3, 2009 then, pls try this one: http://www.4shared.com/file/164776302/97b8f5c6/data_usa_no_screensaver.html it doesn't have changes of r1273 file Quote Link to post Share on other sites
Jfinley0 Posted December 3, 2009 Report Share Posted December 3, 2009 then, pls try this one:http://www.4shared.com/file/164776302/97b8f5c6/data_usa_no_screensaver.html it doesn't have changes of r1273 file  This file works. Looks like you found the problem! Now can I get the latest update? Thanks for looking! I thought I was crazy! Jimbo Quote Link to post Share on other sites
andr2000 Posted December 3, 2009 Report Share Posted December 3, 2009 that one at 4shared is the latest, but w/o screen saver  thank you very much for your support!!! now I have to understand how did that simple screen saver feature brake the things  last test for today: http://www.4shared.com/file/164785161/cb8aefab/data_usa.html can you pls try this one? thanks Quote Link to post Share on other sites
Jfinley0 Posted December 3, 2009 Report Share Posted December 3, 2009 that one at 4shared is the latest, but w/o screen saver thank you very much for your support!!! now I have to understand how did that simple screen saver feature brake the things  You are welcome! I just love this mod and always looking forward to the latest updates. Jimbo Quote Link to post Share on other sites
andr2000 Posted December 3, 2009 Report Share Posted December 3, 2009 please, can someone else also try this file http://www.4shared.com/file/164785161/cb8aefab/data_usa.html does it work or still you see the unit rebooting? thanks Quote Link to post Share on other sites
BorisM Posted December 3, 2009 Author Report Share Posted December 3, 2009 can someone pls try this data: http://www.4shared.com/file/164486061/5e6958dc/data_usa.htmlit has only one change reverted that may cause rebooting. but anyway, it does work in Ukraine/Russia  BTW, Boris forgot to mention these changes in the latest release: - nearest POI list is now optimized for 40 pixel icons - there is a sound played on road shields show - current date on screen saver screen - speed cameras triangle signs, like "give way", were unproportionally stretched  Hmm, May be I missed one update, because speedcams is the only change that is outside of the spoiler tag on 4PDA... Quote Link to post Share on other sites
greenleaves Posted December 3, 2009 Report Share Posted December 3, 2009 please, can someone else also try this filehttp://www.4shared.com/file/164785161/cb8aefab/data_usa.html does it work or still you see the unit rebooting? thanks Yes, the unit reboots itself. Â The no_screen saver version works great. No reboot. Quote Link to post Share on other sites
andr2000 Posted December 3, 2009 Report Share Posted December 3, 2009 please, can someone else also try this filehttp://www.4shared.com/file/164785161/cb8aefab/data_usa.html does it work or still you see the unit rebooting? thanks Yes, the unit reboots itself.  The no_screen saver version works great. No reboot. hm.... I did expect some problems with other big changes. bit I did not expect any with such a change as screensaver. it does work in Ukraine/Russia, but it doesn't in the US ok, guys - thanks for helping. for now, you can use no_screensaver version: it has all the changes the latest version has, but screen saver  BTW, if it reboots in an emulator as well, can someone pls post save folder of it? Quote Link to post Share on other sites
BorisM Posted December 3, 2009 Author Report Share Posted December 3, 2009 BTW, if it reboots in an emulator as well, can someone pls post save folder of it? Â This one worked in the emulator on the first try. Didn't save route and POI visibility settings when I did exit (test mode configured in sys.txt) but it restarted after that, which is better than the previous data.zip I was testing in emulator. Â Thanks! Quote Link to post Share on other sites
Jfinley0 Posted December 5, 2009 Report Share Posted December 5, 2009 that one at 4shared is the latest, but w/o screen saver thank you very much for your support!!! now I have to understand how did that simple screen saver feature brake the things  last test for today: http://www.4shared.com/file/164785161/cb8aefab/data_usa.html can you pls try this one? thanks  Hi ANdr2000: I would like to have my sign post cover my icons when it appears on the map. Right now, my icons are showing thru the sign post. What can I do to change it? Thanks Jimbo Quote Link to post Share on other sites
e39m5 Posted December 7, 2009 Report Share Posted December 7, 2009 I do not have the digital TTF in my igo. Just to be clear, I want to add the font file itself rather than the zip, right? Â Thanks, e39m5 Quote Link to post Share on other sites
BorisM Posted December 7, 2009 Author Report Share Posted December 7, 2009 I do not have the digital TTF in my igo. Just to be clear, I want to add the font file itself rather than the zip, right? Thanks, e39m5  For the font, yes. Copy DIGITAL.TTF file to APL2\IGO folder. Quote Link to post Share on other sites
BorisM Posted December 15, 2009 Author Report Share Posted December 15, 2009 December 15 update from Andr2000 (Firmware 3.x) Â + Added button to return to Navigation screen from Route Planning screen + Integration with Avic_Net Quote Link to post Share on other sites
Join the conversation
