Guest MrBrent Posted May 21, 2006 Report Share Posted May 21, 2006 I don't know for a fact but I have been told that the amp for the Shaker 500 is behind the kick panel on the drivers side. Quote Link to post Share on other sites
Herknav Posted May 23, 2006 Report Share Posted May 23, 2006 All the sources I have heard and read, (Crutchfield, several forums, WOM), say the F-150 kit is dabomb and fits totally clean. Quote Link to post Share on other sites
BMWJ17 Posted May 29, 2006 Author Report Share Posted May 29, 2006 Well, I have finally gotten the Z1 installed in the 06GT and what a great stereo it is and alot more. Thank you all fo the input along the way. Quote Link to post Share on other sites
05Stang-GT Posted February 27, 2007 Report Share Posted February 27, 2007 Just ordered the regulator from Steve....I'm too lazy to build one...traded the Crown Vic in on a 05 Mustang GT with the shaker 500 ....have the wiring harness/F150 Kit on order from Crutchfield so should have it installed soon! Thankfully I think I can use the Z1-Ford adaptor I already had for the Vic and just have to make up the amp connection one. Quote Link to post Share on other sites
BigFloppy Posted February 27, 2007 Report Share Posted February 27, 2007 Good luck with the Stang, I know you'll enjoy it [img]http://www.bigfloppydonkeyballs.com/mustang/front1.jpg[/img] [img]http://www.bigfloppydonkeyballs.com/mustang/BackStripe1.JPG[/img] [img]http://www.bigfloppydonkeyballs.com/mustang/selector.JPG[/img] Quote Link to post Share on other sites
05Stang-GT Posted February 28, 2007 Report Share Posted February 28, 2007 Thanks! BTW, does the F150 kit have everything you need to install it? I had to improvise with the Vic...there was nothing but the wiring harness available. Quote Link to post Share on other sites
BigFloppy Posted March 1, 2007 Report Share Posted March 1, 2007 I think the F150 kit has everything you need.. it should come with 2 connectors. a wide one that powers front/rear speakers and a small one that powers the subs Quote Link to post Share on other sites
05Stang-GT Posted March 1, 2007 Report Share Posted March 1, 2007 I was actually talking about the facia kit, not the wiring kit, should have made that a bit more clear.... Quote Link to post Share on other sites
BigFloppy Posted March 1, 2007 Report Share Posted March 1, 2007 No worries with the Fascia kit as you can see from the picture I posted of my Z1 (even though I've only got a lowly 2005 V6) :D Quote Link to post Share on other sites
05Stang-GT Posted March 2, 2007 Report Share Posted March 2, 2007 Does the Z1 bolt/screw into the facia somehow? The kit and the car are both waiting for me back home but Im on the otherside of the freakin country now and its killin me lol....will be back tomorrow. Quote Link to post Share on other sites
aznsmartass24 Posted March 2, 2007 Report Share Posted March 2, 2007 could you shrink your signature picture? It takes up the entire screen! Quote Link to post Share on other sites
BigFloppy Posted March 2, 2007 Report Share Posted March 2, 2007 The fascia kit bolts to the side of the Avic, then the plastic surround bolts to the main console in the car Easy, no brainer Quote Link to post Share on other sites
05Stang-GT Posted March 3, 2007 Report Share Posted March 3, 2007 [quote name="aznsmartass24"]could you shrink your signature picture? It takes up the entire screen![/quote] You must have a small screen :P I'll work on it. By the way...where did people find the VSS wire in an 05 mustang gt w/shaker 500? It had speed sensative volume, so it has to be at the radio harness, but its not on the pin it was on in the 03 C.V...... Quote Link to post Share on other sites
aznsmartass24 Posted March 3, 2007 Report Share Posted March 3, 2007 Pm cntv79. He is an installer so he should know. Quote Link to post Share on other sites
05Stang-GT Posted March 3, 2007 Report Share Posted March 3, 2007 Called Crutchfield....apparently Ford no longer uses a pulsed voltage for the speed sensative volume and now use a digital signal...had to tap the VSS at the ECU....all done now except for the Reverse Sense lead, but in no hurry to do that since I don't have the backup camera. Quote Link to post Share on other sites
