i630 Posted February 20, 2007 Report Share Posted February 20, 2007 XP actually has an extractor. I always unzip DLed folders just in case. Quote Link to post Share on other sites
ducatiboy Posted February 20, 2007 Report Share Posted February 20, 2007 XP actually has an extractor. I always unzip DLed folders just in case. When you had the iso file, you used that to burn the disk, you didn't burn a disk with that file on it did you? When you stick that disk into the computer do you see 100's of files? Or is it just the single ISO file? And when I said to extract the files.... I did not mean the zip file you downloaded, once you unzip the file, take the iso and extract the files in that into a directory and then burn those files with nero or whatever, sometimes that method works better for people. Quote Link to post Share on other sites
i630 Posted February 21, 2007 Report Share Posted February 21, 2007 Well then. I was confused. I was talking about just the single ISO file. I burned that to a disc. So that must be why it isn't working. So I will have to extract all the files from that 1 ISO file then. Quote Link to post Share on other sites
ducatiboy Posted February 21, 2007 Report Share Posted February 21, 2007 Well then. I was confused. I was talking about just the single ISO file. I burned that to a disc. So that must be why it isn't working. So I will have to extract all the files from that 1 ISO file then. No actually you can open a burning program and tell it to burn image and then select that image. And it will create a cd with a ton of files on it with all the correct settings from that iso file. Or you can extract the iso further into it's separate files and burn all those. If your disk has one file and it's *.iso, then that's your problem. Read this post: http://www.avic411.com/forum/viewtopic. ... c&start=22 Quote Link to post Share on other sites
i630 Posted February 21, 2007 Report Share Posted February 21, 2007 I got it. My z1 is already updated, so I will have to go back to the drawing board. Quote Link to post Share on other sites
academia Posted February 23, 2007 Report Share Posted February 23, 2007 Downloaded from Rapidshare and 411.Com and the AVIC-1Z does NOT recoginze the disk. Is there a workaround? James Quote Link to post Share on other sites
ducatiboy Posted February 23, 2007 Report Share Posted February 23, 2007 Downloaded from Rapidshare and 411.Com and the AVIC-1Z does NOT recoginze the disk. Is there a workaround?James No work around needed. Generally they work when burned correctly. What did you do? http://www.avic411.com/forum/viewtopic. ... &start=187 When you stick the CD into the PC what does it look like? What's the directory and file structure when you look at it on a PC? Does it look like this? http://www.avic411.com/forum/viewtopic. ... 9&start=90 If a PC can't see it the Z1 can't either. Make sure you are burning the ISO not a dvd data disk with the ISO as a file on it. http://www.avic411.com/forum/viewtopic. ... c&start=22 Quote Link to post Share on other sites
rsghowellnj Posted February 23, 2007 Report Share Posted February 23, 2007 I downloaded the ISO image and created the CD. When I put the CD into my AVIC-Z1 it says that a CD has been inserted but I don't know how to get the installation to start. Any help would be appreciated. Quote Link to post Share on other sites
aznsmartass24 Posted February 23, 2007 Report Share Posted February 23, 2007 Hit the MAP button COOCHO! Quote Link to post Share on other sites
rsghowellnj Posted February 23, 2007 Report Share Posted February 23, 2007 Hit the MAP button COOCHO! Thanks ... that worked like a charm. And it FIXED my ECHO Finally !!!!! Quote Link to post Share on other sites
i630 Posted February 23, 2007 Report Share Posted February 23, 2007 Hit the MAP button COOCHO! Thanks ... that worked like a charm. And it FIXED my ECHO Finally !!!!! What phone do you have? My Z1 is updated, but the echo still plagues me. Quote Link to post Share on other sites
deniax Posted February 25, 2007 Report Share Posted February 25, 2007 Will the Bluetooth download fix also work on the European model? It's called the AVIC-HD1BT here. I'm afraid if I flash the unit I can't access the European maps anymore Also, if, for whatever reason, I want to go back to it's original state, before the update, is this possible? Thanks! Quote Link to post Share on other sites
ducatiboy Posted February 25, 2007 Report Share Posted February 25, 2007 Will the Bluetooth download fix also work on the European model? It's called the AVIC-HD1BT here. I'm afraid if I flash the unit I can't access the European maps anymore I would bet against it, but I don't know anyone who has tried it. Also, if, for whatever reason, I want to go back to it's original state, before the update, is this possible? Thanks! Only by unlocking the hard drive and making an image of the drive while hooked to the PC. Check the stickys about hdd in the hacks/mods section. Quote Link to post Share on other sites
djmixmac Posted February 26, 2007 Report Share Posted February 26, 2007 If its a european unit, then doesnt Pioneer Inc. of Europe have their own Customer support which would provide their own version of the bluetooth update disc? I would check! Quote Link to post Share on other sites
deniax Posted February 26, 2007 Report Share Posted February 26, 2007 I've already called them, but they don't know of any update except for the Gracenote one Quote Link to post Share on other sites
Join the conversation
