DoDouble Posted September 4, 2010 Report Share Posted September 4, 2010 I was tooling around with my F90BT and found a live speed read out under the satellite info/strength panel. Is there any place on the Z120BT that will give a real time read of the speed of the vehicle? I would like to verify my speedometer changes. Thanks! Quote Link to post Share on other sites
VBLUE42 Posted September 4, 2010 Report Share Posted September 4, 2010 Yes. Under connection status in the navi settings. Quote Link to post Share on other sites
DoDouble Posted September 4, 2010 Author Report Share Posted September 4, 2010 Yes. Under connection status in the navi settings. Awesome, thank you! Quote Link to post Share on other sites
random1 Posted September 22, 2010 Report Share Posted September 22, 2010 Yes. Under connection status in the navi settings. I have a speed pulse readout there, and some other info - Illumination, pkg brake, etc., but no speed readout. This is on a Z120BT. Quote Link to post Share on other sites
VBLUE42 Posted September 23, 2010 Report Share Posted September 23, 2010 Then your VSS wire is not connected. Quote Link to post Share on other sites
random1 Posted September 23, 2010 Report Share Posted September 23, 2010 Then your VSS wire is not connected. Hmmm. What is speedpulse then? That generates numbers while moving, 0 while stationary. I had a professional install, which is why I don't know one way or the other. It's only been a week or so, so I'll definitely go back to have it connected. Quote Link to post Share on other sites
VBLUE42 Posted September 23, 2010 Report Share Posted September 23, 2010 Well I guess I stand corrected then. The speed read out may be on another navi settings screen. Its been a while so I cant remember. Quote Link to post Share on other sites
JasonH Posted September 23, 2010 Report Share Posted September 23, 2010 The speed readout is in the top left corner in the 3D calibration status menu. Quote Link to post Share on other sites
wxman13 Posted September 23, 2010 Report Share Posted September 23, 2010 On my 120Bt the speed reading is on the 3d calibration page. Quote Link to post Share on other sites
random1 Posted September 23, 2010 Report Share Posted September 23, 2010 On my 120Bt the speed reading is on the 3d calibration page. Didn't see it there either. Really odd! Quote Link to post Share on other sites
DoDouble Posted September 23, 2010 Author Report Share Posted September 23, 2010 Yes. Under connection status in the navi settings. I have a speed pulse readout there, and some other info - Illumination, pkg brake, etc., but no speed readout. This is on a Z120BT. Quote Link to post Share on other sites
random1 Posted September 23, 2010 Report Share Posted September 23, 2010 Yes. Under connection status in the navi settings. I have a speed pulse readout there, and some other info - Illumination, pkg brake, etc., but no speed readout. This is on a Z120BT. You have a speed readout on that screen?? Not just the speedpulse number? Quote Link to post Share on other sites
mswscco Posted September 24, 2010 Report Share Posted September 24, 2010 Speed shows on the 3D calibration page, but you can't access that page while the vehicle is moving. When your speed is zero, you can go the page and your speed will show once you start moving again. But if you exit the page you won't be able to see it until your next stop. Quote Link to post Share on other sites
RonS Posted September 24, 2010 Report Share Posted September 24, 2010 Speed shows on the 3D calibration page, but you can't access that page while the vehicle is moving. When your speed is zero, you can go the page and your speed will show once you start moving again. But if you exit the page you won't be able to see it until your next stop. I'm guessing that doesn't apply when the bypass is installed? Quote Link to post Share on other sites
VBLUE42 Posted September 25, 2010 Report Share Posted September 25, 2010 I'm guessing that doesn't apply when the bypass is installed? That is correct. You can access any page while in motion if you have performed the bypass. Quote Link to post Share on other sites
